Sidewinder engineering stoy/divide by zero
Old June 2nd 05, 08:35 PM
John S. Shinal
Noah Little wrote:
You can be pretty sure it wasn't intentional. When you're programming
with variables, it can happen that one of them becomes zero due to
unforseen conditions. Of course, a wizardly programmer will both forsee
the possibility of those conditions and also include tests to trap
errors (like zeros in embarrassing places), but sometimes in the old
days memory was extremely tight, not permitting such "luxuries," and
then not all programmers are wizards.
I'm inclined to think early marques of the AIM 9 used analog
computing rather than 1s and 0s.
----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
Old June 2nd 05, 09:44 PM
Charlie Springer
On Thu, 2 Jun 2005 07:40:35 -0700, Eunometic wrote
(in article .com):
Dozens more in my copy of 'electronic analog computers by Korn and
Korn of 1956
I think I have Volume II but it is in storage. Is that the complete name?
(Love analog). I have an initial condition/gain block in storage as well. 100
ten turn Beckman pots with a bunch of shafts and clutches to set them up for
a specific solution.
-- Charlie Springer
Old June 2nd 05, 09:54 PM
Charlie Springer
(in article .com):
The limitation of the AM seeker lies in the performance of the AM
detection (here x-axis) circuits, as the average signal from the
detector becomes quite weak in one direction thus producing poor
tracking performance in this axis. A scheme to resolve this is what is
termed frequency modulation (FM), whereby the number of spokes varies
with the radial distance from the centre of the reticle.
What do you call the no spokes version where you need to know the angular
position of the reticle? Say, from a synchronous motor's phase. I tried to
make one for tracking stars once long ago with a PMT. I still want to make
one work.
-- Charlie Springer
Old June 3rd 05, 04:42 AM
leadfoot
Do you have more data on the nature of the divide by zero?
I beleive it was a structrural problem not an electronic problem
Remember the fix was to place a crossmember in the missile.
Old June 3rd 05, 06:39 AM
Eunometic
(in article .com):
one work.
-- Charlie Springer
I'm not sure I understand what you mean. There were 'rossete scans'
that ended up in latter versions of sidewinder thse use a sort of
rotating and oscialting mirror. These also ended up in early German
infrared seekers intended for terminal homing on the Wasserfall missile
but actually derived from infrared imaging systems such as "Spanner".
The Basic AM seekers consists of a rotating transparent disk the half
segment of which is 'greyed' out with a fine speckled pattern of dots
to let in half the infrared light, the other half might consist of a
few dozen spokes. As it rotatres the infrared image produces either a
steady flat signal from the greyed portion or a series of high
frequency pulses from the spokes. The average instensity is the same.
A low pass and high pass filter distinquises the two and the phase
relative to the position of the disk determin the angle though not the
distance from the center. In one of the German versions intended for
the X-4 missile the disk did not rotate but the whole missile did
instead. A single gyroscope spun up at launch by a gramm of gunpowder
acting through a commutator kept track of "up"
Sidewinder I believe never had gyroscopes but used little wind driven
turbines in the tail acting as gyroscopes that mechanically acted on
little tail elevators to roll stabalise the missile. It rotated so
slowly it didn't matter to the seeker. Brilliant.
FM seekers are like AM ones only have another ring (or two or three)
with a different spoke pattern around the disk to widen the acquisition
angle but make the tracking more precise.
I think rossete scans took over a long time ago due to their higher
resistence to jamming and now imaging array systems.
The British Redtop missile (used on the lighting inteceptor) used a
different more sophisticated pattern. Its rotating disk 12 scimitar
spokes each of which had a different curve and width to the scimitar as
it widened toward the periphery. Thus the phase determined the angle
and the 'length' of the pulse the distance from the central axis. I
guess you'd call it 'phase modulation'.
I guess you could used 4 infrard photodetector arranged in a pie shape,
you even buy these from electronics suppliers such as RS components,
but the usual problem with these is that each must have exactly the
same gain and chracteristics.
Old June 3rd 05, 05:03 PM
Harry Andreas
In article , nafod40 wrote:
niceguy wrote:
What idiot would attempt to divide by zero?
God. That's how we get black holes.
I'd like to see that equation.
Harry Andreas
Engineering raconteur
Old June 3rd 05, 05:30 PM
Charlie Springer
On Thu, 2 Jun 2005 22:39:21 -0700, Eunometic wrote
(in article . com):
There is a tracker form with a reticule that is half transparent and half
opaque and spun by a synchronous motor, so there is a reference for the
position of the reticle over time. The amount of time and the angle over
which the target is obscured generates the error signal. When perfectly
centered the signal is constant (half is always blocked).
If I could center it well enough, I could half mask the secondary of a
Cassigrain and spin it. I just find the analog solution more satisfying than
a digital image tracker.
I thought the turbine wheels in the fins of the Sidewinder were stabilizers
and generators, so it didn't need any batteries. I may be thinking of
something else.
-- Charlie Springer
Old June 3rd 05, 05:34 PM
Charlie Springer
(in article . com):
The slots or pattern may have formed the front end of a chopper amplifier,
which was the common way to work with infrared sources in the instrument
business at the time. Was there an internal reference IR source and detector
and a difference circuit? This might elliminate ECM and other common mode
noise.
-- Charlie Springer
Old June 3rd 05, 11:30 PM
Guy Alcala
(in article . com):
something else.
Not generators. The AIM-9B-J used a gas-grain generator for power.
Guy
Old June 4th 05, 03:21 AM
Eunometic
I think its not to hard to derive. If gravity is so high that escape
velocity (eg for a missile) excedes the speed of light you get it. The
fitgerald-lorentz contraction equations.
http://en.wikipedia.org/wiki/FitzGer...tz_Contraction
Square root of (1-(v^2/C^2)) produces infinit contraction at this
speed. I.E. light can't escape and objects have zero lenght and
infinite mass.
FS Aeronautical engineering textbooks for sale john hawkins Home Built 0 March 26th 05 09:53 PM
FS Aeronautical engineering textbooks for sale john hawkins General Aviation 0 March 26th 05 09:53 PM
Navy enlistment questions Atcrossroad Naval Aviation 53 September 23rd 04 10:43 AM
Is possible to pair a Saitek X35 throttle and a MS Sidewinder Pro? Riccardo Simulators 3 December 24th 03 06:07 PM
PS Engineering Report Jeff Owning 44 December 7th 03 11:24 PM
