#11
"Doug" wrote in message
oups.com... In general, here is what I do. If I am being vectored, there is almost never a procedure turn. Yup, AIM 5-4-9a explicitly exempts vectoring situations from the PT requirement. If I am aligned with the FAF, then there is no sense in making a procudure turn or hold, so I go on in. It makes sense, it is safe and it works. So that is what I do. That does sound sensible (if you're at the prescribed altitude, as well as being aligned with the course); but I'm not sure if it's technically legal to skip the PT if the chart has a PT, unless you're being vectored or there's a NoPT designation for your IAF or feeder route. --Gary |
Yossarian wrote:
I was using a Frasca 141 sim today with an instructor when this question came up. Fullerton CA (KFUL) VOR-A approach. At WILMA on V64, flying the full approach. Do you need to turn outbound at the VOR for the procedure turn? Instructor says no because a Victor airway leads to the IAF. I say yes because even though that's true, "No PT" is not listed on that feeder route. If, after evaluating that the altitude/heading that your arrival ends up at the IAF/FAF will not require a procedure turn for alignment or altitude considerations, the best solution would be to advise ATC that you wish to make a straight in approach rather than fly the published procedure turn. If that is not practical you should advise ATC that you plan to make the published procedure turn. Either decision should be passed on to ATC for traffic separation and aircraft control. (it also has the benefit of helping insure ATC won't file some procedural violation against you). -- Darrell R. Schmidt B-58 Hustler History: http://members.cox.net/dschmidt1/ - |
"Darrell S" wrote in message
news:ytloe.568$qr.464@fed1read06... If, after evaluating that the altitude/heading that your arrival ends up at the IAF/FAF will not require a procedure turn for alignment or altitude considerations, the best solution would be to advise ATC that you wish to make a straight in approach rather than fly the published procedure turn. If that is not practical you should advise ATC that you plan to make the published procedure turn. Either decision should be passed on to ATC for traffic separation and aircraft control. (it also has the benefit of helping insure ATC won't file some procedural violation against you). Not necessarily. According to the FARs and the AIM, the only way ATC can exempt you from an otherwise required PT is if they vector you to final. Otherwise, the regs apparently call for you to execute the PT; and (as discussed in another thread here recently) you must comply with the regs even if ATC gives you a clearance that is contrary to the regs. --Gary |
wrote in message ...
[...] The reason the course reversal is required in the cited case at KFUL is because going straight in from V-64 requires a course change entering the final approach segment that well exceeds the maximum course change at the FAF of 30 degrees permitted for VOR IAPs. A procedure turn requires a course change of over 130 degrees (including getting back onto the outbound course). And then of 180 degrees. You can fly the transition at the same altitude allowed for the procedure turn. How is the procedure turn better? Like it or not that is the criteria. Keep in mind that TERPs is simplistic criteria in the sense that it tries to make one size fit all in most aspects of IAP construction. Well, I can agree with that. From a practical point of view, however... It seems likely that when radar coverage is available, vectors will be given. This allows no procedure turn to be flown. If radar coverage is not available, how is anyone going to know if you've flown the procedure turn? I would think that from an enforcement point of view, the cases where a procedure turn is theoretically required, but where the pilot could ever be cited for not flying one, are pretty far and few between. From a safety point of view, not flying the procedure turn appears to be the superior approach, at least in this case. Pete |
"Jose" wrote in message
... Well, required in the sense of geometry or what? Yes, in the sense of geometry. If you have to turn around, you have to turn around. And since the procedure turn =shape= is not usually prescribed (except that it happens on one side of the course) it's just a sexy u-turn. The *inbound* turn is usually not prescribed. The outbound leg is required to be flown along the depicted route. In the case of the example here, that requires a greater than 130 degree right-hand turn from the transition route. You only get to make up your turn on the way back in. If the procedure allowed one to simply fly a standard-rate right-hand turn after crossing the VOR, to return to the inbound leg, I might not have as big an issue with the idea that the procedure turn is required. That's still more complex, but it's reasonably efficient, does result in one being established on the inbound course earlier, and is much less likely to wind up with the airplane outside protected airspace (because there's a lot less maneuvering going on). But it doesn't. It requires that one first turns outbound, gets established on the outbound course, and only then reverses course (again) to come back inbound. Not quite. As you quoted: "A procedure turn is the maneuver prescribed when it is necessary to perform a course reversal..." It doesn't say "only when it is necessary", and the quote does not imply it's the =sole= purpose of the PT. It's the introductory sentence to the entire section on procedure turns. I don't think it's a stretch *at all* (as opposed to some of my other interpretations) to believe that they are describing *exactly* why a procedure turn exists. Pete |
On Sat, 4 Jun 2005 11:13:47 -0700, "Peter Duniho"
wrote: It seems likely that when radar coverage is available, vectors will be given. This allows no procedure turn to be flown. If radar coverage is not available, how is anyone going to know if you've flown the procedure turn? Anyone who listens to the tapes, assuming radio coverage? At least around here whenever I'm flying a full procedure ATC always requests "report procedure turn inbound". |
Since it's such a nice day, I'm going to quibble. Where is it written that
you have to track the inbound course when outbound? IOW (I sense that you fly in the Northwest, specifically western Washington), if I am coming from the west to shoot the ILS into Paine, and my outbound turn over RITTS takes me east of the extended runway/localizer, I am perfectly justified in flying parallel to the localizer if I want to....the protected airspace is plenty wide. I have seen dozens of instrument students work themselves into a frenzy trying to get established outbound on the inbound, if you catch my drift (no-wind conditions g). Bob Gardner "Peter Duniho" wrote in message ... "Jose" wrote in message ... Well, required in the sense of geometry or what? Yes, in the sense of geometry. If you have to turn around, you have to turn around. And since the procedure turn =shape= is not usually prescribed (except that it happens on one side of the course) it's just a sexy u-turn. The *inbound* turn is usually not prescribed. The outbound leg is required to be flown along the depicted route. In the case of the example here, that requires a greater than 130 degree right-hand turn from the transition route. You only get to make up your turn on the way back in. If the procedure allowed one to simply fly a standard-rate right-hand turn after crossing the VOR, to return to the inbound leg, I might not have as big an issue with the idea that the procedure turn is required. That's still more complex, but it's reasonably efficient, does result in one being established on the inbound course earlier, and is much less likely to wind up with the airplane outside protected airspace (because there's a lot less maneuvering going on). But it doesn't. It requires that one first turns outbound, gets established on the outbound course, and only then reverses course (again) to come back inbound. Not quite. As you quoted: "A procedure turn is the maneuver prescribed when it is necessary to perform a course reversal..." It doesn't say "only when it is necessary", and the quote does not imply it's the =sole= purpose of the PT. It's the introductory sentence to the entire section on procedure turns. I don't think it's a stretch *at all* (as opposed to some of my other interpretations) to believe that they are describing *exactly* why a procedure turn exists. Pete |
"Bob Gardner" wrote in message
... Since it's such a nice day, I'm going to quibble. Where is it written that you have to track the inbound course when outbound? IMHO, that's in the definition of "procedure turn" (97.3(p)). "The outbound course, direction of turn, distance within which the turn must be completed, and minimum altitude are specified in the procedure". Note that they say "outbound course", not "outbound heading". To me, this means you are required to fly exactly that course (inasmuch as you are required to fly the procedure turn at all). I don't disagree that there are situations in which it's perfectly safe to parallel the outbound course. Your example at KPAE is a fine one. But if someone believes that the regulations require the full procedure to be flown even when no course reversal is actually necessary for the approach, they darn well better believe that the regulations require flying the outbound *course* as depicted, rather than just the outbound heading. That seems much more explicitly stated than the presumed requirement to fly the full procedure. Pete |
Lots of posters are spouting ideas, regs, AIM citations, etc. but have not
looked at the approach plate. So lets do that. 1st... What is your flight plan route? Wilma is NOT part of the approach. It is a feeder for the airport. 2nd... If you filed to Wilma, then the airport and went lost communications and were IFR you would have to fly to an IAF and then commence the approach. ATC would expect you to fly to Seal Beach and fly the procedure turn. 3rd... If you are under ATC control, they would likley either vector you to final or tell you to fly to Seal Beach and then intercept final and probably tell you to to that at 1500 feet so you would be in the proper postion to descend to MDA for the circle to land. "Peter Duniho" wrote in message ... "Yossarian" wrote in message . 97.142... I was using a Frasca 141 sim today with an instructor when this question came up. Fullerton CA (KFUL) VOR-A approach. At WILMA on V64, flying the full approach. Do you need to turn outbound at the VOR for the procedure turn? Instructor says no because a Victor airway leads to the IAF. I say yes because even though that's true, "No PT" is not listed on that feeder route. You'll need a true expert to answer the question with certainty. However... I agree with your instructor. AFAIK, there is NEVER a requirement to make a procedure turn. The "NoPT" exists to prohibit a procedure turn, not to tell you when you are required to make one. Obviously, if you're going the wrong way, you need a course reversal at some point. But that's a practical requirement, not a regulatory one. In the case of the approach from ALBAS, not only is there clearly no need for a procedure turn, they've even gone so far as to put the IAF way out there. While I'm not an expert in the TERPS, I suspect that there's something in there that stipulates when "NoPT" is used; probably any arrival 30 degrees or less from the final approach course gets a "NoPT" (the arrival from ALBAS just barely squeaks by). If the approach designer had been given the latitude to put "NoPT" on any arrival where he thinks a procedure turn is unnecessary, we'd probably see that on the arrival from WILMA too. I would agree that in general, it would be nice to be established on the final approach course at the FAF. But again, I'm not aware of any requirement for this. Assuming you can cross the FAF at the FAF (which should never be in question), and then immediately establish yourself on the final approach course (which should be no problem in this case), I don't see any problem. As far as I can tell, the procedure turn on that approach is for pilots who are coming at the VOR from the opposite direction. For example, someone who flew the missed approach. Of course, lacking the "NoPT", you are of course welcome to fly the whole procedure turn. But you're looking at 45 seconds or so just to get established outbound parallel to the final approach course, and that's not counting the time spent flying back to it (and then, of course, the time for the procedure turn itself). I'm betting not many people fly the procedure turn coming in from WILMA. I'm a little curious as to how this question is on r.a.piloting, but not on r.a.ifr. I've cross-posted for your benefit (and quoted your entire post for theirs). ![]() Pete |
On Sat, 4 Jun 2005 22:50:57 -0700, "Peter Duniho"
wrote: To me, this means you are required to fly exactly that course Yes, but "course" only refers to "The intended *direction* of flight in the horizontal plane measured in degrees from north." It does not refer to a particular ground track. On the other hand, there are "Some procedure turns are specified by procedural track. These turns must be flown exactly as depicted." Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Sports class tasking | [email protected] | Soaring | 12 | April 25th 05 01:32 PM |
Agent86's List of Misconceptions of FAA Procedures Zero for 15 Putz!!! | copertopkiller | Military Aviation | 11 | April 20th 04 02:17 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
Instrument Approaches and procedure turns.... | Cecil E. Chapman | Instrument Flight Rules | 58 | September 18th 03 10:40 PM |
