Looking for help with designs for making tow out gear for a Blanik
	L-13. Has anybody already done this? Suggestions or contacts from those that have would be appreciated. Thanks Tom Idaho  |
			 We used to have two Blaniks. We made a trailer for the complete glider, with a tilting mechanism and a hand winch to load the glider, and with two lifting arms to support the wings. It worked fine on a hard surface, and was even usable on grass (rigid axle, no suspension). You just had to drive slowly! We had one glider airborne when the towcar went a bit too fast... When we sold the Blaniks, we sold the trailer to another club, where it still performs well with older glider types. See the fotoalbum of http://www.dewouw.net/zweefvliegsectie/ , look under "op de piste". The picture is named "Ka 6 nat". (sorry, I couldn't get the direct link to work) -- stephanevdv ------------------------------------------------------------------------ Posted via OziPilots Online [ http://www.OziPilotsOnline.com.au ] - A website for Australian Pilots regardless of when, why, or what they fly -  |
Tom's Blank's tie-down is located about 4,000 feet from the end of Nampa's
	runway 29. I believe the original post is asking a source for a wing-wheel and tail dolly. Or maybe there are other options that would allow towing an assembled Blanik behind his jeep. Wayne http://www.soaridaho.com/ "stephanevdv" wrote in message ... We used to have two Blaniks. We made a trailer for the complete glider, with a tilting mechanism and a hand winch to load the glider, and with two lifting arms to support the wings. It worked fine on a hard surface, and was even usable on grass (rigid axle, no suspension). You just had to drive slowly! We had one glider airborne when the towcar went a bit too fast... When we sold the Blaniks, we sold the trailer to another club, where it still performs well with older glider types. See the fotoalbum of http://www.dewouw.net/zweefvliegsectie/ , look under "op de piste". The picture is named "Ka 6 nat". (sorry, I couldn't get the direct link to work) -- stephanevdv ------------------------------------------------------------------------ Posted via OziPilots Online [ http://www.OziPilotsOnline.com.au ] - A website for Australian Pilots regardless of when, why, or what they fly -  |
Wayne Paul wrote:
	Tom's Blank's tie-down is located about 4,000 feet from the end of Nampa's runway 29. I believe the original post is asking a source for a wing-wheel and tail dolly. Or maybe there are other options that would allow towing an assembled Blanik behind his jeep. Wayne http://www.soaridaho.com/ One of the members at our club has built an elaborate rig to allow him to tow his L13 the 2km to our launch point. The long walk to freedom was getting irritating... I will see about some pictures on the club website. Consists of a glass fibre cradle under the fuselage with a hub (off a Renault Scenic) providing the pivot to the wheel. Wheel is a 5" pneumatic on a scissor mount with gas struts. The wing wheel also consists of a 2 piece glass fibre shell that clamps over the tip of the wing. The wheel is again on gas struts. We have a pretty rough field, so it is important to put the suspension in, and still drive very slowly. (First gear, a little over walking speed) Even so you sometimes see big impulses transmitted to the structure, captured on the accelerometer... "stephanevdv" wrote in message ... We used to have two Blaniks. We made a trailer for the complete glider, with a tilting mechanism and a hand winch to load the glider, and with two lifting arms to support the wings. It worked fine on a hard surface, and was even usable on grass (rigid axle, no suspension). You just had to drive slowly! We had one glider airborne when the towcar went a bit too fast... When we sold the Blaniks, we sold the trailer to another club, where it still performs well with older glider types. See the fotoalbum of http://www.dewouw.net/zweefvliegsectie/ , look under "op de piste". The picture is named "Ka 6 nat". (sorry, I couldn't get the direct link to work) -- stephanevdv ------------------------------------------------------------------------ Posted via OziPilots Online [ http://www.OziPilotsOnline.com.au ] - A website for Australian Pilots regardless of when, why, or what they fly - -- Bruce Greeff Std Cirrus #57 I'm no-T at the address above.  |
The Air Force Academy team at Hobbs is flying L-23s and have a pretty
	neat tail dolly setup as their ships have non-swivelling tailwheels. I'll try to take some photos and post them online as well. -Tom  |
| Thread Tools | |
| Display Modes | |
| Lak-17a landing gear problem | Raphael Warshaw | Soaring | 0 | July 1st 04 05:25 PM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 1 | November 24th 03 03:46 PM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 2 | November 24th 03 06:23 AM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 0 | November 24th 03 04:52 AM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 07:24 AM |
