Do I need DME or ADF in an IFR-certified GPS panel?
Old June 8th 05, 05:51 PM
George Patterson
Thomas Borchert wrote:
but how many would there be where the GPS could not legally replace the
DME? Those are only the very few where the DME is not in the database.
It's my understanding that the DME box in the plane measures distance from a
VOR. All VORs should be in the database.
George Patterson
Why do men's hearts beat faster, knees get weak, throats become dry,
and they think irrationally when a woman wears leather clothing?
Because she smells like a new truck.
  #32
Old June 8th 05, 05:56 PM
George Patterson
Doug wrote:
Also, I think Marker Beacons are nice to have,
though not legally required for ILS's. It is good to have that aural
warning at the middle marker.
IIRC, there are also approaches that have lower minimums for the ILS with an MBR
than without.
George Patterson
  #33
Old June 8th 05, 06:01 PM
Mark Hansen
Actually, it measures distance from a DME or TACAN facility, not from
a VOR. It can use a VOR/DME or VORTAC, but not a VOR.
George Patterson
Mark Hansen, PP-ASEL, Instrument Student
Sacramento, CA
  #34
Old June 8th 05, 06:06 PM
Ron Natalie
Matt Barrow wrote:
One I do fairly often is SDA GPS 12, which is a VOR/DME overlay.
Another is Laramie (WY) Rwy 30.
It doesn't require DME if you're going to fly it GPS.
The name of that appoach is
VOR/DME or GPS 12
  #35
Old June 8th 05, 06:08 PM
Ron Natalie
Matt,
My guess is that you'll
find more GPS approaches that require DME than require ADF.
There are no GPS appraoches that require DME period. It's not a
matter of "replacing" it.
The only issue is using GPS to substitute for DME on NON-GPS
approaches. You can do that if you have the fix AND this isn't
the non-GPS required alternate.
  #36
Old June 8th 05, 06:09 PM
Ron Natalie
the DME? Those are only the very few where the DME is not in the
database.
from a VOR. All VORs should be in the database.
There are ILS based DME's. The issue isn't GPS appraoches, it's
using a GPS to substitute for DME on another non-GPS approach.
  #37
Old June 8th 05, 06:11 PM
Ron Natalie
Roy Smith wrote:
Looking closer at this approach, I'm a little confused why the OVR
13 DME (CFDKH) fix exists. There's no course change. The MDA is the
same before and after. There's no timer to start. Why is the segment
after Omaha VOR not simply "2800 NoPT to PICAM"?
It's to let you know you're inside the circle :-)
  #38
Old June 8th 05, 06:14 PM
Ron Natalie
with an MBR than without.
It used to be that there was a penalty for no middle marker. This was
done away with almost a decade ago. The FAA doesn't take markers
seriously anymore. Unless it's a compass locator with some other
navigational function, they're pretty much ignored.
  #39
Old June 8th 05, 06:15 PM
Ron Natalie
Frank Stutzman wrote:
Yup, a big advantage of the 480 over the 430/530.
Has anyone ever attempted to get a FMS approved for a 430/530 that has
verbage like the 480 so that you could still do an approach with an
expired DB?
Not with any FSDO around here for sure. I've even got the stupid
GPS/VOR annunciators because my 480 is three inches too far to the
right to qualify for the exemption.
  #40
Old June 8th 05, 06:27 PM
No Spam
On 6/8/05 09:17, "Matt Barrow" wrote:
"No Spam" wrote in message
On 6/7/05 22:35, "Matt Barrow" wrote:
The ADF is no big deal, but definitely keep the DME. My guess is that
you'll
Thanks, Matt,
I had no idea that any GPS approaches existed that required DME - guess
that
would make them "GPS-DME" approaches. Can you name some?
Matt,
Those approaches can be flown with only the GPS - a DME isn't required. If
you flew them without a GPS, then you'd need the VOR/DME combination.
- Don
Life is just what happens to you,
While you're busy making other plans
"Beautiful boy" - John Lennon
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 40 October 3rd 08 03:13 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 June 2nd 04 07:17 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 2nd 04 11:41 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 05:12 AM
