WAAS for GNS 430/530?
Old June 8th 05, 10:27 PM
Andrew Gideon
Victor J. Osborne, Jr. wrote:
But does this feature work as enhancements to existing SDF/LOC approaches?
My reading of the advertising-speak is that it can build a descent profile
for any approach. I've some question about that (ie. what if the straight
line from FAF to VDP passes under a stepdown), but I don't know that I've
interpreted the advertising-speak accurately.
- Andrew
  #32
Old June 9th 05, 02:28 AM
Matt Barrow
"Roy Smith" wrote in message
Matt Barrow wrote:
"Andrew Gideon" wrote in message
gonline.com...
Matt Barrow wrote:
Think about breaking out at the MAP...you've got 0.2 seconds to make
your
decision.
Perhaps I'm misinterpreting what you've written, but how is this
different
than a 'real' precision approach?
When you reach the MAP after D&D, you're stable in three axes. How would
you
rather be when looking for the runway?
When you reach the MAP after following a glide slope, you should also
be stable in three axes (heading, pitch, and bank should all be
constant). Even better, if you see the runway, you can continue to
hold that attitude down to the surface.
If anything, the slight nose-down pitch attitude should make it easier
to see the runway, compared to having to search for it over the nose
in level flight after a dive-and-drive.
And at the MAP, your rate of descent must be reduced to zero, so the
stability in three axes doesn't hold.
  #33
Old June 9th 05, 02:29 AM
Matt Barrow
"Scott Moore" wrote in message
Andrew Gideon wrote:
your
decision.
different
- Andrew
I believe he is saying that dive and drive gets you broken out sooner,
since
you are down at the minimum altitude considerably befor the map.
You've got it.
Did you read Deakins article? He's a much better writer/spokesman than I.
  #34
Old June 9th 05, 03:06 AM
Matt Barrow
gonline.com...
your
decision.
different than a 'real' precision approach?
since you are down at the minimum altitude considerably befor the map.
Perhaps, but that's still the same as a precision approach.
No, it's not. A PA breaks you out AT the MAP, D&D breaks your out eealier,
perhaps _much_ earlier.
If reaching the
MDA at the same moment that one much decide whether or not to continue the
approach (ie the VDP) is a Bad Thing, why isn't it bad on a precision
approach?
It's the dreaded "approach to minimums". In the turbine equipment, it's
piloted by (usually) more experienced pilots. In such equipment it HAS to be
done as a stabilized approach. Why would a prop/piston driver put that onus
on themselves?
  #35
Old June 9th 05, 03:15 AM
Matt Barrow
A factor I didn't see mentioned:
A coupled autopilot can fly a WAAS approach. It cannot do dive and drive.
A coupled approach does let you keep your eyes outside, especially during
the transition phase, but how many are equipped with AP's that can do
coupled approaches?
Remember: CONTEXT.
  #36
Old June 9th 05, 03:33 AM
Ron Natalie
coupled approaches?
Remember: CONTEXT.
I've got an WAAS-enabled GPS, GPSS, and an autopilot that will fly
coupled approaches.
  #37
Old June 9th 05, 03:41 AM
Matt Barrow
m...
during
coupled approaches?
Remember: CONTEXT.
coupled approaches.
So do I. We're a distinct minority. So what?
Remember: CONTEXT.
  #38
Old June 9th 05, 04:35 AM
John R. Copeland
"Andrew Gideon" wrote in message =
online.com...
=20
But does this feature work as enhancements to existing SDF/LOC =
approaches?
=20
My reading of the advertising-speak is that it can build a descent =
profile
for any approach. I've some question about that (ie. what if the =
straight
line from FAF to VDP passes under a stepdown), but I don't know that =
I've
=20
- Andrew
I agree the "advertising-speak" seems to say what you interpreted.
But I've yet to encounter a computed glide slope for any SDF/LOC
or VOR approaches in my CNX80.
(If some are there, though, someone will surely tell us so.)
However, it seems like all RNAV (GPS) approaches, as well as a majority
of the plain-vanilla GPS approaches do give me vertical guidance,
to which I can couple my 3-axis autopilot if I so choose.
During practice, I make sure I'm comfortable either coupled or =
uncoupled.
Regarding the "straight line from FAF to VDP passing under a stepdown",
that's handled by a charting a delay before descending until reaching a =
point
from which the stabilized descent *will* meet obstruction-clearance =
criteria.
The CNX80/GNS480 follows that charting.
It does not start the descent from the FAF when it's incorrect to do so.
  #39
Old June 9th 05, 11:04 AM
Ron Natalie
m...
during
coupled approaches?
Remember: CONTEXT.
coupled approaches.
Remember: CONTEXT.
Anybody with a IFR capable GPS is a minority. Anybody with
a really capable IFR panel that's legal to use IFR is a minority.
What freaking CONTEXT are you talking about.
  #40
Old June 9th 05, 02:48 PM
Andrew Gideon
point from which the stabilized descent will meet obstruction-clearance
criteria. The CNX80/GNS480 follows that charting.
That's a nice solution; I wish I could see it for myself grin.
- Andrew
Any inside story re 430/530 WAAS cert.? [email protected] Instrument Flight Rules 0 May 20th 05 06:13 PM
WAAS and Garmin 430/530 DoodyButch Owning 23 October 13th 03 04:06 AM
Terminology of New WAAS, VNAV, LPV approach types Tarver Engineering Instrument Flight Rules 2 August 5th 03 03:50 AM
WAAS Big John Piloting 8 July 22nd 03 01:06 PM
Garmin Behind the Curve on WAAS GPS VNAV Approaches Richard Kaplan Instrument Flight Rules 24 July 18th 03 01:43 PM
