Procedure turn required?
Old June 10th 05, 04:51 PM
"Steven P. McNicoll" wrote:
wrote in message ...
That doesn't make sense in that airspace since the SLI VOR is the
fix/facility
closest to the airport from that direction.
Pilots file lots of routes that don't make sense.
And, in the context of this thread, your point is?
  #72
Old June 10th 05, 04:52 PM
Steven P. McNicoll
As a matter of definition a feeder route is not a segment of an IAP (but
if it looks like a duck, walks like a duck, and quacks like a duck...).
As a
matter of regulation, it is a component of an IAP, which is by procedure
design
an evaluated and designed segment, just like the four set forth in the
definition.
What regulation?
Further, you can find it on any Part 97-issued Form 8260 -3 or -5 that has
a feeder route and you can find it in TERPs Paragraph 220:
220. FEEDER ROUTES. When the IAF is part of the enroute structure there
may be no need to designate additional routes for aircraft to proceed to
the IAF.
In some cases, however, it is necessary to designate feeder routes from
enroute structure to the IAF. Only those feeder routes which provide an
operational advantage shall be established and published. These should
coincide with the local air traffic flow. The length of the feeder route
shall not
exceed the operational service volume of the facilities which provide
navigational guidance unless additional frequency protection is provided.
Enroute airway obstacle clearance criteria shall apply to feeder routes.
The minimum altitude established on feeder routes shall not be less than
altitude established at the IAF.
Based on that it appears to be more closely related to enroute airways than
IAPs.
  #73
Old June 10th 05, 04:55 PM
Steven P. McNicoll
That pilots file lots of routes that don't make sense. In the context of
this thread, what point were you trying to make?
  #74
Old June 10th 05, 07:49 PM
That the clearance would be to SLI VOR, so either of the feeder fixes would
have limited, if any, application in a lost comm situation.
  #75
Old June 10th 05, 07:53 PM
As a
design
definition.
What regulation?
FAR 97.2X, the "X" varying with the type of IAP that is issued under Part 97.
the IAF.
shall not
IAPs.
A feeder route is, indeed, constructed to airway criteria, except the descent
gradient limitations have to be calculated in accordance with initial approach
segment criteria. Further, in non-DMAs there is absolutely no difference in any
aspect of a feeder route or initial approach segment for ground-based IAPs.
Also, airways are issued under Part 95 and feeder routes are issued under Part
97.
  #76
Old June 10th 05, 09:46 PM
Steven P. McNicoll
would have limited, if any, application in a lost comm situation.
No, the clearance would be to the filed destination.
  #77
Old June 10th 05, 11:51 PM
No, that would be the clearance limit. The last clearance fix coming to KFUL
from the west or northwest would be SLI. In the context of this thread: the
last airway fix would be SLI, not WILMA.
It's all academic anyway because routing over WILMA conflicts the SoCAL TEC
routes.
  #78
Old June 10th 05, 11:58 PM
Steven P. McNicoll
The clearance limit will be the filed destination.
  #79
Old June 11th 05, 12:12 AM
That is what I said.
  #80
Old June 11th 05, 02:34 PM
Steven P. McNicoll
No, you said the clearance would be to SLI VOR.
Sports class tasking [email protected] Soaring 12 April 25th 05 01:32 PM
Agent86's List of Misconceptions of FAA Procedures Zero for 15 Putz!!! copertopkiller Military Aviation 11 April 20th 04 02:17 AM
Instrument Approaches and procedure turns.... Cecil E. Chapman Instrument Flight Rules 58 September 18th 03 10:40 PM
