How come GPS reads different
Old June 13th 05, 03:52 PM
Thomas Borchert
I would be more worried about avoiding the big yellow things that are
the cause of all this, if it happens.
and about the poetry...
Thomas Borchert (EDDH)
  #42
Old June 13th 05, 05:59 PM
Ross Richardson
Aluckyguess wrote:
I am getting over 500ft. difference and more.
"Matt Whiting" wrote in message
Aluckyguess wrote:
How come the GPS reads a different altitude than the Altimeter?
For many reasons. The main reason is that they derive altitude by two
completely different methods and this inevitably introduces errors. Then
each method has its own inherent errors.
Even two altimeters side by side won't read the same altitude other than
by accident.
Matt
GPS altitude is not accurate. That is why you need to have a baro sensor
included as input to a IFR approved GPS.
Regards, Ross
C-172F 180HP
KSWI
  #43
Old June 13th 05, 06:08 PM
Gene Seibel
GPS is most accurate when your position is surrounded by satellites. In
the horizontal plane, that is usually true. In the vertical direction,
you always have satellites above you, but none below you. This also
makes altitude slightly more difficult to resolve.
http://gpsinformation.net/main/altitude.htm
Gene Seibel
Gene & Sue's Aeroplanes - http://pad39a.com/gene/planes.html
Because we fly, we envy no one.
  #44
Old June 13th 05, 06:45 PM
Frank Ch. Eigler
.... except when it is, which is most of the time.
That is why you need to have a baro sensor included as input to a
IFR approved GPS.
That baro input is used as a cross-check for gross errors, to assist
RAIM. It does not "correct" inaccuracy, and thus is irrelevant to the
normal GPS altitude readout.
- FChE
  #45
Old June 13th 05, 06:47 PM
Peter
It's true that GPS vertical accuracy is worse by about a factor of 1.5
to 2 than horizontal accuracy. But despite this, GPS vertical accuracy
is still better than using barometric pressure when you're at a
significantly different altitude than the reference point giving the
barometric calibration.
The continued use of pressure-based altimeters is for consistency and
reliability - not accuracy.
  #46
Old June 13th 05, 08:26 PM
John Galban
Jim Fisher wrote:
"Tauno Voipio" wrote in message
Actually, if Earth would disappear with all its mass, GPS would
get unusable, as the satellites would continue out of their
tracks due to the lack of gravity pull.
Yeah, but they'd work longer than a pressure altimeter so I think we should
still adopt GPS altimeters in case this ever actually happens.
Good idea! It's always smart to be prepared. I always carry a
towel with me whenever I fly. Just in case.
  #47
Old June 14th 05, 09:27 AM
Thomas, I've a complete off-topic question.
I see you fly from Hamburg, is there any chance you ever been to
Borkum(EDWR)?
I'm send on a reconnaissance mission tomorrow to check out if the place
is oke for our vacaction.
Any info is helpfull,
Kees (EHSE)
  #48
Old June 14th 05, 01:39 PM
Thomas Borchert
Borkum(EDWR)?
Yes, I have been there. IMHO, while nice, it is not the nicest of the
East Frisian Islands. I would prefer Juist, one further down. Baltrum
is great, too, if your plane is REALLY short-field capable. Borkum
would be next on the list, with the others being much more touristy due
to a lot of one-day visitors.
But this all depends on what you want to do there. Borkum has car
traffic, the other two don't. On Juist, the field is far away from the
village, and you'll need to take the horse-drawn coach. Bicycle rental
in the village only.
  #49
Old June 14th 05, 02:02 PM
Thanks for the info.
The problem of visiting the other islands is not the short field
capability of my plane(it being a Rallye), but my lack of German.
According my Bottlang Borkum is the only one with English R/T.
The plan is to have a vacation for a week or so in August(when the sea
temp. is a bit up) and use Borkum as a base to fly from to other nearby
fields in Germany or maybe Denmark.
To be honest, Helgoland is high on my wish list.
Happy landings,
Kees.
  #50
Old June 14th 05, 04:00 PM
Thomas Borchert
I wouldn't care about that. Just fly in and talk to them in English.
Also, if you want, I can find out more by calling them. Just tell which
fields you are interested in. Use
thomas (the sign of signs) aeroversand.de
to send me an e-mail...
Our TB-10 won't do Helgoland - otherwise I'd have been there a long
time ago. I would have some recommendations for Denmark, too. Oh, and
if you're interested, we could meet at some point during your trip.
GREAT AVIATION READS Cribsheet Piloting 1 September 12th 04 02:51 AM
GREAT AVIATION READS Cribsheet Rotorcraft 0 September 10th 04 06:06 PM
GREAT AVIATION READS Cribsheet Military Aviation 0 September 7th 04 06:37 PM
When the ASI Reads Below Zero BTIZ Piloting 11 August 23rd 04 04:57 PM
Newsweek Reads RAM! Bob McKellar Military Aviation 0 February 17th 04 02:10 AM
