Aircraft type designators new vs. old and ATC
Old June 14th 05, 03:54 AM
John
Default Aircraft type designators new vs. old and ATC
About 9 years ago, the (USA) FAA had us switch to new aircraft type
designator codes, which were different then what we previously used for
some aircraft. This, like airspace types, four digit identifiers, and
METAR/TAF weather formats was part of the greatness of International
standardization. So fixed gear PA-28s became P28A (i.e. slower
Cherokees 140-181) and P28B for the faster fixed gear Cherokees (235,
236) etc. See http://www.faa.gov/atpubs/ATC/Appendices/atcapda.html
Recently a speaker from our local Class B Tracon mentioned that they
didn't care what type of Cherokee somebody was flying, they were all
entered as PA-28 anyway.
So does the FAA use those identifiers that they made sure we knew about
and use? Usually when I file a flight plan with a four letter airport
ID, it gets converted to the old 3 letter anyway. Do the FAA computers
and radar systems still accept/want the old identifiers?
Old June 14th 05, 05:38 AM
My experience with filing via the AOPA flight planner (which I believe
uses DUATS as its backend) is that it does indeed reject PA-28, PA28,
etc, and only accepts P28A, as you said and the FAA pub say. My CFII at
the time when I discovered this told me I was crazy.
Interesting that the designators for lots of other PA-nn were not
changed around.
-- dave j
Old June 14th 05, 06:40 AM
Well...I guess I've filed as PA28 (archer II) a half dozen times and
havent been yelled at for it yet. I shall get it right next time.
maybe they were input as P28A
Just like at the flight school where we were filing C172 for the
cutlass RG, which should really C72R
methinks a difference of 10-20 knots doesnt make much diff to ATC,
tho. Now the diff between a PA28-140 and a Turbo arrow...that they
might want to know...
--Don
Don Byrer
Electronics Technician/Friendly but Sarcastic Pilot
FAA Airways Facilites/Tech Ops, RADAR/Data/Comm @ CLE
Amateur Radio KJ5KB
Instrument Pilot Commercial Student
PP-ASEL 30 Jan 2005 "-IA" 25 Mar 2005
Old June 14th 05, 04:37 PM
Larry Dighera
On Mon, 13 Jun 2005 22:54:32 -0400, John wrote in
and use?
Flying a PA28-235, I have been asked by ATC if I'm not a Lance at
times. This was probably due to unusually good performance when
lightly loaded. The little Piper would handily out climb Bonanzas
departing behind me that ATC had routed over me.
Old June 14th 05, 05:57 PM
Ron Natalie
I believe some tracons put VFR popups in with only a single letter
type. This explains why my Navion keeps getting called a Navaho
when handed off between sectors.
Old June 14th 05, 06:08 PM
Odd. Do you use the AOPA flight planner? Do you use DUAT?
Here is a snippet of the transaction log from trying it just now on a
VFR flight plan:
DUAT DOMESTIC;VFR;TAIL N15782;ACTYPE PA28/A;SPEED 110;DEPART
KPAO;ARRIVE KLVK;ETD 2003;FL 31
ERR228: ACTYPE:Invalid Aircraft Type.
And here is it working:
DUAT DOMESTIC;VFR;TAIL N15782;ACTYPE P28A/A;SPEED 110;DEPART
OK.
Your Flight Plan will be transmitted to OAK FSS 1 hour and 56 minutes
from now for a proposed departure at 2003 on 06/
14/2005.
-- dave j
Old June 14th 05, 11:26 PM
I didn't know Newps was a controller. I thought he was being cheeky. It
all makes sense now.
-- dave j
