#21
They're known as ALARS - Alternate Launch and Recovery Strips, and were a
specific design in several countries which had a concern about being able to operate from areas other than their main bases after a major invasion/air attack. They were considered a strategic imperative to be able to defend the country after the Soviets had taken out all the main base runways. Germany and Switzerland have already been mentioned; Korea is another one. They were often located near main bases to reduce the travel from the main base support facilities to the ALARS. You could tell you were driving on an ALARS because there were very wide shoulders at either end for servicing and arming the aircraft as well as parking after missions. If you knew what to look for you could also identify the barrier installation locations across the road. Ones I specifically have seen were outside the main gate at Ramstein and on Highway 1 in Korea, all of which were decommissioned in the mid-90s. In ReFORGER (Return of Forces to Germany, a major NATO exercise held every couple of years during the Cold War) the USAF and Luftwaffe used to exercise from them routinely during the 70s and 80s (I believe, though I have nothing other than memories of old photos to back that up). Shawn "Markus Voget" wrote in message ... "Chris" wrote: "John Galban" wrote in message ups.com... In some european countries, major highways were designed to accomodate military aircraft for use in war time. Switzerland is one country in particular. The same is true for Germany. European highways tend to have the lanes for both directions very close to each other, unlike the US ones with a wide grass area in the middle. In Germany, you often have small bushes (to block oncoming lights) between two guard rails. But on some straight stretches of Autobahn, the middle ground between both directions has been filled in with concrete, and the guard rails there can be disassembled. If you know what you are looking for, it is quite easy to pick out these "ad-hoc runways" as you drive along. Another giveaway: there is never a brigde or cables running across the highway, for obvious reasons. Greetings, Markus |
![]() "Gig 601XL Builder" If you are trying to counter what George wrote I have to ask. What do planes in Kosovo have to do with the US interstate highway system? Mountains. Bunkers. Planes. Highways. It's been done :-) Montblack |
![]() "john smith" wrote I have yet to see a segment of an interstate highway that is wide enough for the outriggers of a B-52. You must have been asleep in class, on that day. The outriggers ride on the highway, themselves. They have to put turf tires on the mains, for use in the medians. g -- Jim in NC |
![]() "John Gaquin" wrote in message ... "Ash Wyllie" wrote in message Ike sold the Interstate Highways as a national defence thing. As was right. One thing learned VERY quickly during the mobilization for WWII was the inefficiency of the logistical/distribution system in the US on a national scale. Railroads alone, while they did a marvelous job, just couldn't keep up. The country up to then was a huge group of local/regional units. The Interstate system was conceived and built for commercial/military trucking and transport. Any other benefit, like personal travel, was ancillary. And the legends live on.... |
Interstate 81 Information | Ryan | Piloting | 0 | July 20th 04 08:08 PM |
Interstate Aviation and Moyer Aviation | G.R. Patterson III | Owning | 2 | June 19th 04 05:47 AM |
