#101
None of the a/c flown by most of us can be 'flown' while stalled no matter how much engine power is applied.
Then what am I doing when I practice stalls at altitude, holding the aircraft at the stall buffet? I suppose that's not fully stalled yet, and when it does fully stall I would lose altitude, but ok, fly it juat above this speed (unstalled) six inches above the runway, and reduce power. I don't reccomend this, but put it out since it would not be impossible to do, and would result in a full stall greaser if all conditions were right. Jose -- "Never trust anything that can think for itself, if you can't see where it keeps its brain." (chapter 10 of book 3 - Harry Potter). for Email, make the obvious change in the address. |
#102
Recently, Jose posted:
None of the a/c flown by most of us can be 'flown' while stalled no matter how much engine power is applied. Then what am I doing when I practice stalls at altitude, holding the aircraft at the stall buffet? You're holding the aircraft at just above the stall speed. When you're stalled, you're falling, not flying. What I thought you were describing in your earlier post was there is adequate power to remain in flight strictly on the engine alone. Think F-18, not C-172. ;-) I don't reccomend this, but put it out since it would not be impossible to do, and would result in a full stall greaser if all conditions were right. What you seem to describing now is one where you reach stall speed at exactly the point where your wheels touch down. What's the point in that, when you can grease it on at 2-3 kts above stall without the risk of being wrong and dropping, or hitting a gust and being lifted a few feet and *then* dropping because you don't have the airspeed to fly? Neil |
#103
exactly the point where your wheels touch down. What's the point in that, when you can grease it on at 2-3 kts above stall without the risk of being wrong and dropping, or hitting a gust and being lifted a few feet and *then* dropping because you don't have the airspeed to fly? I was taking issue with the idea that a greaser full stall landing is self-contradictory. Jose -- "Never trust anything that can think for itself, if you can't see where it keeps its brain." (chapter 10 of book 3 - Harry Potter). for Email, make the obvious change in the address. |
#104
Jose wrote:
I was taking issue with the idea that a greaser full stall landing is self-contradictory. Well, lot's of semantic problems in this whole discussion. I would say that what people commonly *call* a full stall is not a good way to grease it on. I would also say that what is called a full stall landing is actually a landing where power is off, and the plane is at an attitude and speed where you run out of elevator authority just as you touch the ground - perhaps the wing is stalled but what I think is that the nose is simply dropping to continue flying as you run out of elevator. The only way out of this is to add power or let the nose drop until more airspeed is gained. I can do this in the Maule when I make a minimum speed approach, flare at the right moment, and touch the ground just as the wheel is pulled all the way back. Not a good way to grease it on but it is wonderful thing when it happens. Normally, I come in at a normal approach speed, flare to the 3 point attitude and touch down. If I pull back too far or too fast, I can and will touch the tailwheel first. So I agree that what we think of as a full stall landing, can be greased on. It's just not the best way. I also suggest that the idea of holding it off with power at a high angle of attack (dragging it in) is neither a 'full stall landing' nor a good way to grease it. Perhaps just a different perspective. |
#105
Recently, T o d d P a t t i s t posted:
There are a couple of points I'd like to make in this thread. "Neil Gould" wrote: None of the a/c flown by most of us can be 'flown' while stalled no matter how much engine power is applied. Then what am I doing when I practice stalls at altitude, holding the aircraft at the stall buffet? You're holding the aircraft at just above the stall speed. That is indeed what he's doing. When you're stalled, you're falling, not flying. This is a matter of semantics. I consider myself to be flying even when practicing spins with both wings stalled. I thought one could only maintain a spin where *one* wing is stalled, and the other not? If both wings stall, the spin should stop and the plane should fall. First point: I also consider aerobatics pilots to be flying when using a powerful engine to supplement reduced lift and fly with both wings stalled. Well, they're "flying" by power lift, in the same sense that a Harrier is "flying" when hovering. The wings are irrelevant in those situations. So, in the context of "greasing on" a full-stall landing in a typical SEL, those scenarios are irrelevant to the OP. [...] The point I'm making here is that a stalled wing still produces lots of lift. In fact, near stall, it's producing nearly the maximum lift that the wing is capable of producing. Is that like saying, "Even those that don't have an income can purchase the most expensive plane they can afford"? ;-) Second Point: It is exceptionally difficult to actually get to a full stall attitude for landing. What is often called a "full stall landing" or "3 point landing" does not actually have the wing at stall AOA. Many aircraft would hit their tail if they were low enough to safely land and the wing was at stall AOA. I completely disagree with this notion. The AOA is a vector of the relative direction of travel through air. There is no requirement that there be a nose-high attitude in a stall, only that the wind traveling over the wing is lower than what is required to produce lift. It isn't difficult to hold a typical SEL aircraft in a nose-down stall, and in fact, a descending turning stall is a required manouvre in the private PTS. Neil |
#106
"Neil Gould" wrote in message
. .. Recently, T o d d P a t t i s t posted: This is a matter of semantics. I consider myself to be flying even when practicing spins with both wings stalled. I thought one could only maintain a spin where *one* wing is stalled, and the other not? If both wings stall, the spin should stop and the plane should fall. Anyone trying to describe spin aerodynamics in one or two sentences is doomed to failure. ![]() one wing flying" scenario is insufficient, IMHO. Each wing is creating different amounts of lift, true...and a stall has occurred, also true. But both wings can still be generating lift, while still both remaining stalled. It's the asymmetric lift that causes the spin, regardless of whether both wings are stalled or not. First point: I also consider aerobatics pilots to be flying when using a powerful engine to supplement reduced lift and fly with both wings stalled. Well, they're "flying" by power lift, in the same sense that a Harrier is "flying" when hovering. The wings are irrelevant in those situations. So, in the context of "greasing on" a full-stall landing in a typical SEL, those scenarios are irrelevant to the OP. If the wing has non-zero motion relative to the air, it has a defined angle-of-attack, and thus can be determined to be stalled or not stalled. Whether the wing is providing any significant lift contribution to helping the airplane maintain altitude is irrelevant to the question of whether the airplane is flying with both wings stalled or not. In particular, Todd's comment simply corrects the statement that "when you're stalled, you're falling, not flying". Using power to keep oneself aloft is still "flying", even if the wings are stalled. Thus, it is not always true that "when you're stalled, you're...not flying", even if it IS true in most situations. The point I'm making here is that a stalled wing still produces lots of lift. In fact, near stall, it's producing nearly the maximum lift that the wing is capable of producing. Is that like saying, "Even those that don't have an income can purchase the most expensive plane they can afford"? ;-) That depends on what you mean by "don't have an income". It's more like saying that "even those whose income has peaked and is now going back down can purchase an airplane almost as expensive as one they could have afforded at their peak income". In other words, what Todd is saying is that lift doesn't just quit in a discontinuous way at the stall. If you look at the graph of lift versus angle of attack, the peak of that graph occurs right at the stalling angle of attack, and then starts to drop off from there. It does drop quite a bit more rapidly than the other side of the graph where lift is increasing, but it doesn't just jump to zero. Assuming you could maintain control of the airplane in a fashion to ensure that you exceeded the stalling angle of attack only by a tiny fraction of a degree, you would wind up getting almost as much lift as you were getting right at the instant you stalled. There are, of course, other issues. The graph I'm talking about is actually the lift coefficient graph; actual lift depends on the lift coefficient (angle of attack) and airspeed. Drag increases dramatically at stall, and it would require a lot of extra power to maintain an airspeed sufficient to produce lift equal to the airplane's weight, flying just past the stalling angle of attack. But it certainly is theoretically possibly. Second Point: It is exceptionally difficult to actually get to a full stall attitude for landing. What is often called a "full stall landing" or "3 point landing" does not actually have the wing at stall AOA. Many aircraft would hit their tail if they were low enough to safely land and the wing was at stall AOA. I completely disagree with this notion. The AOA is a vector of the relative direction of travel through air. The AOA is the "angle-of-attack". It's not a vector at all, never mind the one you describe. It is true that the AOA is relative to direction of travel through air (ie the "relative wind"). There is no requirement that there be a nose-high attitude in a stall, only that the wind traveling over the wing is lower than what is required to produce lift. It isn't difficult to hold a typical SEL aircraft in a nose-down stall, and in fact, a descending turning stall is a required manouvre in the private PTS. Read Todd's statement again. He is clearly talking only about the situation during a landing. The motion of the aircraft through the air just prior to touchdown is necessarily nearly or precisely parallel to the ground. And it is true that with most airplanes, the stalling angle-of-attack produces a pitch angle so nose-high that the tail will hit the ground before the main gear does. Which was the entire point of the phrase Todd uses: "if they were low enough to safely land and the wing was at stall AOA". If they are low enough to land and are at a nose-down stalling AOA, they are milliseconds from crashing. Which is clearly not the scenario we're talking about here. You are certainly correct that an airplane can be stalled in any attitude. But that in no way provides a basis for disagreement with Todd's statements. Pete |
#107
T o d d P a t t i s t wrote:
If you want to get closer to a true stall at landing, you'd probably want to come in about a foot or two higher and really get the nose up before touching the tail. Of course your Maule probably wouldn't be so happy with that technique Maules are not happy with that technique. When a Maule is in three-point attitude, it is not stalled. Power-off stall in no-wind conditions occurs when the mains are about 6" higher than the tailwheel. George Patterson Why do men's hearts beat faster, knees get weak, throats become dry, and they think irrationally when a woman wears leather clothing? Because she smells like a new truck. |
#108
Recently, Peter Duniho posted:
In particular, Todd's comment simply corrects the statement that "when you're stalled, you're falling, not flying". Using power to keep oneself aloft is still "flying", even if the wings are stalled. Thus, it is not always true that "when you're stalled, you're...not flying", even if it IS true in most situations. Then, the issue is one trying to make an absolute statement out of one intended only in the context of the discussion, specifically, "full stall greasers" in the typical SEL aircraft. Any discussion about other forms of flying, whether it be in hovering Harriers or personal batwings are irrelevant to that context. In other words, what Todd is saying is that lift doesn't just quit in a discontinuous way at the stall. If you look at the graph of lift versus angle of attack, the peak of that graph occurs right at the stalling angle of attack, and then starts to drop off from there. It does drop quite a bit more rapidly than the other side of the graph where lift is increasing, but it doesn't just jump to zero. I wasn't claiming that it does. It's just that the amount of lift after stall isn't sufficient to be relevant. There are, of course, other issues. The graph I'm talking about is actually the lift coefficient graph; actual lift depends on the lift coefficient (angle of attack) and airspeed. Drag increases dramatically at stall, and it would require a lot of extra power to maintain an airspeed sufficient to produce lift equal to the airplane's weight, flying just past the stalling angle of attack. But it certainly is theoretically possibly. Of course, if you have enough power. That's why my original reply stated, "Think F-18..." This theoretical possibility isn't very relevant to the context of the post to which I originally replied, e.g., "full-stall greased landings" in a typical SEL. Second Point: It is exceptionally difficult to actually get to a full stall attitude for landing. What is often called a "full stall landing" or "3 point landing" does not actually have the wing at stall AOA. Many aircraft would hit their tail if they were low enough to safely land and the wing was at stall AOA. I completely disagree with this notion. The AOA is a vector of the relative direction of travel through air. The AOA is the "angle-of-attack". It's not a vector at all, never mind the one you describe. It is true that the AOA is relative to direction of travel through air (ie the "relative wind"). One doesn't have directional motion *without* a vector. ;-) "Vector...Etymology: New Latin, from Latin, carrier, from vehere to carry -- more at WAY 1 a : a quantity that has magnitude and direction and that is commonly represented by a directed line segment whose length represents the magnitude and whose orientation in space represents the direction..." When one refers to the "angle of attack" (and, yes, I know that "AOA" is the acronym), one is definitely referring to motion having both direction and magnitude. "Relative wind" is just a non-technical way to state this. However, it would have been better stated if I had said "... relative direction of _the wing's_ travel...", even though the typical SEL's wing pitch isn't drastically different from the rest of the aircraft. ;-) There is no requirement that there be a nose-high attitude in a stall, only that the wind traveling over the wing is lower than what is required to produce lift. It isn't difficult to hold a typical SEL aircraft in a nose-down stall, and in fact, a descending turning stall is a required manouvre in the private PTS. Read Todd's statement again. He is clearly talking only about the situation during a landing. The motion of the aircraft through the air just prior to touchdown is necessarily nearly or precisely parallel to the ground. My reply specifically separates the AOA from any ground reference. And it is true that with most airplanes, the stalling angle-of-attack produces a pitch angle so nose-high that the tail will hit the ground before the main gear does. I responded to that. In the context of landing, if one flies slowly enough to stall, one can stall "flat" relative to the ground because the decrease in forward "relative wind" increases the AOA. That is what my remark addresses. You are certainly correct that an airplane can be stalled in any attitude. But that in no way provides a basis for disagreement with Todd's statements. I think it does with regard to necessarily hitting the tail before stalling. Neil |
#109
... [...] Any discussion about other forms of flying, whether it be in hovering Harriers or personal batwings are irrelevant to that context. Then perhaps you should take that up with the person who brought up such examples. Todd was not that person. Oh, wait...it was YOU that mentioned the F-18. (Minor nitpick: I don't recall for sure whether the F-18 actually has more thrust than weight; I believe that the F-16 does, and it's the only airplane I understood to have that characteristic. I will continue saying "F-18" in this post, with the assumption that you know for a fact it also has more thrust than weight...perhaps it's just one of the later models, like the Super Hornet, that does). I wasn't claiming that it does. It's just that the amount of lift after stall isn't sufficient to be relevant. That's a false claim. As the lift drops off in a continuous manner, there is a region "after stall" where the lift coefficient is just as high as usable regions "before stall". You may equivocate on whether a pilot can maintain the airplane at the angle-of-attack required to obtain that "after stall" coefficient of lift. But the fact remains that the lift is theoretically obtainable. As long as you don't want a lift coefficient very close to the maximum lift coefficient for the wing, it may not even be that hard to obtain the desired coefficient. There are, of course, other issues. The graph I'm talking about is actually the lift coefficient graph; actual lift depends on the lift coefficient (angle of attack) and airspeed. Drag increases dramatically at stall, and it would require a lot of extra power to maintain an airspeed sufficient to produce lift equal to the airplane's weight, flying just past the stalling angle of attack. But it certainly is theoretically possibly. Of course, if you have enough power. That's why my original reply stated, "Think F-18..." I fear we're back to square one. The F-18 has more power than is necessary. You only need enough power to overcome the drag. You don't need enough power to overcome weight, which is what you seem to be saying. This theoretical possibility isn't very relevant to the context of the post to which I originally replied, e.g., "full-stall greased landings" in a typical SEL. Sure it is. It discusses the actual aerodynamics, allowing someone to consider what would be required to make a "full-stall greaser". Physical characteristics of most airplanes preclude actually stalling the wing when in a safe landable position (mainly the issue of the tail winding up too low for a safe landing), but otherwise there's no obvious reason one could not only make a "full-stall greaser", but could actually *fly* the airplane onto the runway in the stalled condition. In fact, if anything (again, ignoring the geometry of the situation) the landing scenario is the most likely scenario in which a pilot could maintain the post-stall condition, since ground effect would dramatically reduce induced drag, induced drag being a primary reason that maintaining the airplane in a flying condition past the stall is so difficult. Of course, as Todd correctly pointed out, the physical geometry of most airplanes preclude stalling the airplane when in a position for a safe landing (ie just above the runway). But you incorrectly attempt to dispute that as well. The AOA is the "angle-of-attack". It's not a vector at all, never mind the one you describe. It is true that the AOA is relative to direction of travel through air (ie the "relative wind"). One doesn't have directional motion *without* a vector. ;-) I never said there were no vectors. I said the angle-of-attack is not a vector. "Vector...Etymology: New Latin, from Latin, carrier, from vehere to carry -- more at WAY 1 a : a quantity that has magnitude and direction and that is commonly represented by a directed line segment whose length represents the magnitude and whose orientation in space represents the direction..." When in doubt, post a definition? Seriously...what purpose was that supposed to serve? When one refers to the "angle of attack" (and, yes, I know that "AOA" is the acronym), one is definitely referring to motion having both direction and magnitude. No, they are not. The angle-of-attack is a specific angle, measured between the wing's chord and the relative wind. In fact, a motionless airplane can still have an angle-of-attack, just as long as there is some wind. "Relative wind" is just a non-technical way to state this. Actually, "relative wind" is a *technical* way to state the apparent wind relative to the chord of the wing. But angle-of-attack is something else entirely. Relative wind is indeed a vector. Angle-of-attack is not. However, it would have been better stated if I had said "... relative direction of _the wing's_ travel...", even though the typical SEL's wing pitch isn't drastically different from the rest of the aircraft. ;-) The angle of incidence (which is what you appear to be talking about now...that is, the angle between the wing chord and the longitudinal axis of the airplane) is yet again something else entirely different from angle-of-attack. The phrase you suggest as a replacement for angle-of-attack (that is, "relative direction of _the wing's_ travel") would not be a suitable replacement at all for "angle-of-attack", though it might serve as an synonymous phrase for "relative wind". The confusion here is not between the airplane's pitch angle and the wing's angle-of-attack. It's your insistence on calling the angle-of-attack a vector, when it's a scalar (and, it appears, your confusion between "relative wind" and "angle-of-attack"). My reply specifically separates the AOA from any ground reference. Actually, your reply implies that Todd doesn't understand that the angle-of-attack isn't measure relative to the ground. He does understand that, but the fact that angle-of-attack isn't measured relative to the ground doesn't change the fact that you can't stall most planes while in a position for a safe landing. And it is true that with most airplanes, the stalling angle-of-attack produces a pitch angle so nose-high that the tail will hit the ground before the main gear does. I responded to that. In the context of landing, if one flies slowly enough to stall, one can stall "flat" relative to the ground because the decrease in forward "relative wind" increases the AOA. That is what my remark addresses. Your claim is incorrect. As long as the airplane is flying just above the ground, the relative wind is parallel to the ground. No change in the angle-of-attack will occur from any decrease in speed, not directly. It is simply impossible to do what you suggest one might do. If one "flies slowly enough to stall", the angle-of-attack is at the stalling angle-of-attack, period. Furthermore, if one flies at a constant altitude (as one must do when landing an airplane, once over the runway), the relative wind is parallel to the ground, and thus the airplane's pitch angle is the same as the wing's angle-of-attack (ignoring the angle of incidence, of course). What WILL happen is that as the aircraft slows, the pitch angle of the aircraft will need to be increased, so as to continually increase the angle-of-attack of the wing. The increase in AOA increases the lift coefficient, compensating for the reduction in airspeed to maintain a lift force equal to the airplane's weight. If you do not increase the pitch angle, the airplane will simply descend onto the runway. You will not stall "flat" relative to the ground. Only one of two things can happen in the scenario you describe. You will either prevent the airplane from touching the runway by continually increase the angle-of-attack (which means no stall "flat" relative to the ground) , or the airplane will descend and touch the runway (again, no stall "flat" relative to the ground). In *either* case, the airplane will touch the runway before the wing stalls, assuming a safe landing. You are certainly correct that an airplane can be stalled in any attitude. But that in no way provides a basis for disagreement with Todd's statements. I think it does with regard to necessarily hitting the tail before stalling. You think wrong. Pete |
#110
"Neil Gould" wrote in message I wasn't claiming that it does. It's just that the amount of lift after stall isn't sufficient to be relevant. That's a false claim. As the lift drops off in a continuous manner, there is a region "after stall" where the lift coefficient is just as high as usable regions "before stall". You may equivocate on whether a pilot can maintain the airplane at the angle-of-attack required to obtain that "after stall" coefficient of lift. But the fact remains that the lift is theoretically obtainable. As long as you don't want a lift coefficient very close to the maximum lift coefficient for the wing, it may not even be that hard to obtain the desired coefficient. Again, the _context_ is a response to Matt & Jose's claim of controlling a typical SEL to "greaser full-stall landings". I was agreeing with George that this is probably not what they were experiencing, and Todd's explanation regarding the high pitch angle typical of stall speeds is in agreement with this, albeit for other reasons. So, in context, how is your theoretically available lift relevant? When one refers to the "angle of attack" (and, yes, I know that "AOA" is the acronym), one is definitely referring to motion having both direction and magnitude. No, they are not. The angle-of-attack is a specific angle, measured between the wing's chord and the relative wind. In fact, a motionless airplane can still have an angle-of-attack, just as long as there is some wind. If there is wind, there is motion, direction and magnitude relative to the wing, ergo, a vector. If there is no wind, there is no "attack", and that angle then describes something entirely different. [...] However, it would have been better stated if I had said "... relative direction of _the wing's_ travel...", even though the typical SEL's wing pitch isn't drastically different from the rest of the aircraft. ;-) The angle of incidence (which is what you appear to be talking about now...that is, the angle between the wing chord and the longitudinal axis of the airplane) is yet again something else entirely different from angle-of-attack. Two different things are being described. In context (the direction of travel), the difference between the AOA and the angle of incidence is not "drastically different". [...] The confusion here is not between the airplane's pitch angle and the wing's angle-of-attack. It's your insistence on calling the angle-of-attack a vector, when it's a scalar (and, it appears, your confusion between "relative wind" and "angle-of-attack"). To be a scalar, it would have to lack motion, ergo no "attack". [...] I responded to that. In the context of landing, if one flies slowly enough to stall, one can stall "flat" relative to the ground because the decrease in forward "relative wind" increases the AOA. That is what my remark addresses. Your claim is incorrect. As long as the airplane is flying just above the ground, the relative wind is parallel to the ground. No change in the angle-of-attack will occur from any decrease in speed, not directly. My claim is that if the aircraft is flying parallel to the ground just before touch-down, it isn't stalled. [...] It is simply impossible to do what you suggest one might do. If one "flies slowly enough to stall", the angle-of-attack is at the stalling angle-of-attack, period. And all I'm saying is that this is independent of the pitch angle relative to the ground. [...] What WILL happen is that as the aircraft slows, the pitch angle of the aircraft will need to be increased, so as to continually increase the angle-of-attack of the wing. We are describing the same phenomena from two perspectives. In the context of my usage, if one maintains the pitch angle as the aircraft slows, the AOA will continually increase (normally, the pitch angle changes as the aircraft slows). But, again, the context of what happens during landing; one is maintaining a safe pitch angle as the aircraft slows, not necessarily increasing the pitch angle to insure a stall. [...] In *either* case, the airplane will touch the runway before the wing stalls, assuming a safe landing. In fact, I stated that the risk is something quite different from a safe landing. Neil |
RAF Blind/Beam Approach Training flights | Geoffrey Sinclair | Military Aviation | 3 | September 4th 09 06:31 PM |
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP | vvcd | Piloting | 0 | September 22nd 04 07:13 PM |
WINGS: When do the clocks start ticking? | Andrew Gideon | Piloting | 6 | February 3rd 04 03:01 PM |
Flight instructors as Charter Pilots | C J Campbell | Piloting | 6 | January 24th 04 07:51 AM |
