#91
xyzzy wrote:
Dave Butler wrote: Ron Rosenfeld wrote: So, you're filed to RDU, and the weather requires an alternate. You obtain "appropriate weather reports or weather forecasts, or a combination ..." that indicate the weather at TTA will be severe clear at your time of arrival. According to a strict reading of those regulations, you still could not use it as an alternate; although it would be perfectly OK to use some grass strip as an alternate. Makes no sense to me. You can't use it to satisfy the requirements for *filing* an alternate. You can *use* whatever you want. Right? Right, couldn't you file, say FAY, as an alternate then on your way there when you break out cancel IFR and land at TTA? Sure, except there's no requirement to cancel IFR. Just tell ATC you've decided to go to TTA. There's no requirement to actually go to the alternate that you filed. You just have to file it. When you divert, you decide where you're going. ATC will say something like "say intentions". You say (for example) "I'd like to try for a visual approach at TTA". ATC does not know what alternate you filed. The approaches marked NA might also be viable choices. You just can't *file* TTA as an alternate expecting to use one of the NA approaches. Dave |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 03:13 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 07:17 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
