Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
Cutting aircraft cable?
Old June 17th 05, 07:53 PM
Stubby
Default Cutting aircraft cable?
How do I cut 3/16" stainless steel aircraft cable? I've tried
wirecutters, tin snips, airplane sheers, and a branch lopper. Tough stuff!
Old June 17th 05, 08:40 PM
John Kunkel
"Stubby" wrote in message
stuff!
You need a dedicated cable/wire rope cutter.
http://www2.northerntool.com/product-1/200308983.htm
Old June 17th 05, 09:36 PM
Orval Fairbairn
stuff!
A big hammer and a sharp chisel against an anvil will work, too.
Remove _'s from email address to talk to me.
Old June 17th 05, 10:04 PM
Stubby
stuff!
Ah. The big hammer solution. I like that. Thanks.
Old June 17th 05, 10:10 PM
Gord Beaman
stuff!
Yes! that one appeals to me too...must be a man thing eh?...
-Gord.
"I'm trying to get as old as I can,
and it must be working 'cause I'm
the oldest now that I've ever been"
Old June 17th 05, 10:31 PM
RST Engineering
Orval --
A quick question from somebody who farms that part of the job out when it
has to be done...since the end doesn't take any of the tension of the cable,
what would be wrong with torching it and then nicropressing it outside of
the torched area?
Old June 18th 05, 12:23 AM
Brian Whatcott
On Fri, 17 Jun 2005 13:53:30 -0400, Stubby
A cable cutter is suited to this chore - a big one, for preference!
Brian Whatcott
Old June 18th 05, 12:25 AM
Brian Whatcott
On Fri, 17 Jun 2005 13:31:38 -0700, "RST Engineering"
Orval --
the torched area?
Doing things the boring, conventional way has a benefit:
reducing the unknowns.
Brian W.
Old June 18th 05, 05:32 AM
Orval Fairbairn
"RST Engineering" wrote:
Orval --
the torched area?
The problem is -- you just don't know how much of the cable has been
heat-damaged that way.
I have used the hammer/chisel and it works. Make sure that you have a
good, sharp chisel (and a big hammer).
Old June 18th 05, 05:41 AM
Gord Beaman
Orval --
the torched area?
At the risk of agreeing with Jim here I'll venture to say "Sure
you do...only the 'ends' are heated and those are inside the
clamped areas at the 'ends' of the cable..."
-Gord.
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 December 2nd 04 08:00 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 04:04 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 10:02 PM
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 01:14 PM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
