GPS switched S for N!
Old June 21st 05, 11:55 AM
Cub Driver
Default GPS switched S for N!
The other day I flew up to Alton Bay. While over the bay, but still
flying north, I went go-to my waypoint for Hampton airport. (Not the
airport waypoint in the database, but one I programmed in, and that
puts me over the start of the 45 from the west.)
When I got up to the mouth of the bay, I turned around and followed
the bug back south. After half an hour I realized that I was west of
my expected track. Indeed I was going almost precisely south instead
of SSE.
What's more, my destination was 5,900 miles distant, and the time to
get there was 84 hours. The day was milky, so I couldn't see anything
on the horizon, so I turned SE until I came over US 4, then followed
that back to the seacoast.
When I got home, I scanned out and out on the map, to find that my
waypoint was now located in the Andes on the Argentinian side of the
Chile-Argentina border. Still, the coordinates looked very familar. On
a hunch, I changed the S to an N, and behold! The waypoint moved back
to the seacoast of New Hampshire.
What happened?
And could it happen to the waypoints in the database?
(Garmin 296)
thanks!
-- all the best, Dan Ford
email (put Cubdriver in subject line)
Warbird's Forum:
www.warbirdforum.com
Piper Cub Forum: www.pipercubforum.com
the blog: www.danford.net
In Search of Lost Time: www.readingproust.com
Old June 21st 05, 01:56 PM
Stubby
of SSE.
What happened?
Garmin doesn't have the best interfaces. Both the -12 and -60CS that I
use seem very prone to coordinate input errors. I frequently seem to
get N/S switch problem when defining a waypoint.
Another problem could be that your GPS is not initialized properly.
There is an automatic init that takes awhile and a manual init that
requires you to tell it what state you are in. If you get impatient and
abort the init, I'll bet you can wind up with a bad location, maybe on
the wrong side of the equator.
Old June 21st 05, 03:01 PM
Jose
the bug back south. [...] my destination was 5,900 miles distant, and the time to
What happened?
What happened was precisely why I am so vocal about paper charts and
against reliance on this newfangled gizmo thang. (and horrified at the
thought of central computer control of airplane systems)
As a cub driver you are probably with me on this. I've had my home
airport move to the other side of the country several times. Dunno why.
I use 'em when I hafta, and they're cool when they work, but I've never
seen the blue screen of death on a sectional!
Jose
My other car is up my nose.
Old June 21st 05, 09:16 PM
Paul Hirose
I have never had a corrupted GPS waypoint, even when the
battery was so exhausted the receiver wouldn't turn on. But I have
experienced some bad lock-ons. The receiver seemed to be working
normally, but its velocity and distance to go were obviously wrong.
(Turning the unit off for a moment cleared the problem.)
A lot of GPS troubles are detectable that way. Don't just follow the
receiver's steering bug. Crosscheck its readouts, same as you
crosscheck your instruments.
"Cub Driver" wrote in message
of SSE.
anything
On
back
What happened?
(Garmin 296)
Paul Hirose
To reply by email remove INVALID
Old June 21st 05, 09:56 PM
Jonathan Goodish
I've never seen the blue screen on a GPS either. I've used Garmin
handhelds for years without a single problem, and now use a
Windows-based PDA system for navigation without a problem--both are far
superior to charts for both navigation and situational awareness.
However, I always have charts on board so that if there is ever a
problem, I can revert to paper. Attempting to resist technology in the
cockpit is a losing battle.
JKG
Old June 21st 05, 10:26 PM
Michael 182
"Jose" wrote in message
lol - If you are in the majority of the posters on this newsgroup you fly a
single engine plane with 1970's mechanical technology. The GPS is probably
the single best technology on your plane. In any case, if it concerns you,
you can get a backup GPS for about the cost of a tank of gas. This "railing
against technology" stuff is getting pretty old...
Michael
Old June 21st 05, 10:42 PM
Jose
With proven technology.
Jose
Old June 21st 05, 11:04 PM
Michael 182
Yeah, proven to have dozens of moving parts that wear out and need to be
inspected annually, carbs that freeze, a pitot static system that clogs and
has to be checked every two years, probably some Narco comms that work every
third Sunday...
I have nothing against flying these planes - I fly one all the time. But I
don't kid myself that, after the pilot, the mechanical systems are the weak
link.
Michael
Old June 21st 05, 11:40 PM
Jose
third Sunday...
.... none of which have ever painted a purple line to Austrailia for me
to follow.
Jose
Old June 21st 05, 11:56 PM
Guillermo
the time to
What happened?
I use a KLN 94, but when I input coordinates and waypoints, I always
crosscheck the distances and bearing with a chart to see if everything makes
sense. Computerized systems do what we tell them to do, which is not
necessarily what we want them to do .
Fun weekend buying an Arrow (long) Jack Allison Owning 44 April 20th 05 12:29 PM
Fun weekend buying an Arrow (long) Jack Allison Piloting 45 April 20th 05 12:29 PM
