#11
![]() "Jim Burns" wrote in message ... Mike, Just a few questions and thoughts, mainly because I'm curious. I'd be interested to know the HP rating of the GO480 installed in the Helio. I've been watching a few people that are building Bearhawks and one article mentions that the GO480 isn't favored for that application for the relative high weight to HP ratio compared to the 540. 295HP I "believe" that the Beech Queen Air originally used a version of the 480 and I "know" a lot of them have been retrofitted with either 720's or turbines. Whether this was due to high rebuild or maintenance costs or lack of power, I have no idea. Would the desirability of the 480 in the Helio be due to a desire to keep them "original"? No, Helio owners only care about STOL performance. The Helio requires high power for takeoff only. Actually what it requires is high static thrust and it benefits from a large diameter prop so that thrust flows over more of the slats/wing/flaps. The geared engine can use a larger diameter prop without the tips going supersonic. Once airborn, the airplane is not going to go very fast (135-140kts) with its large wing and large exposed wheels no matter how much power is availible. The 350hp TIO 540 tends to overheat in the Helio probably due to the cowling/baffling design. There were only about seven Helios made with the TIO540 and at least three seem to be on the market at any given time, a dead giveaway that the airplane is a lemon.. The 400hp IO 720 adds a lot of weight both in terms of the engine itself and the additional fuel it requires. Both the H700 and H800 (350hp and 400hp) were also designed to accomodate both nosewheel and tailwheel configurations and they are heavier as a result. I was surprised that this was the case since generally later airplanes are improved over earlier ones with various bugs fixed. MU-2s underwent a gradual transformation over the ~20 yr production run where they got more power, more pressurization, more fuel capacity, better avionics ect. I went to OSH last year specifically to find out why all the experienced Helio pilots preferred the H295 (295hp) to the H700 (350hp) and H800 (400hp). The explanations varied somewhat but everyone thought strongly that the earlier ones were better. The ultimate Helio is a early model with an Allison turbine engine. I know of only one that exists. This give you a larger prop, much more power AND lighter weight, although fuel consumption eats up some of the weight savings. Mike MU-2 |
Thanks Mike!
Great explaination of desired airflow vs. HP. Several years ago our aerial applicators mounted gearboxes and longer props to their round engined Air Tractors. Not only did they reduce the prop speed and noise but they increased the airflow around the airplane produceing a better spray pattern. Jim No, Helio owners only care about STOL performance. The Helio requires high power for takeoff only. Actually what it requires is high static thrust and it benefits from a large diameter prop so that thrust flows over more of the slats/wing/flaps. The geared engine can use a larger diameter prop without the tips going supersonic. Once airborn, the airplane is not going to go very fast (135-140kts) with its large wing and large exposed wheels no matter how much power is availible. |
I really want that 450hp Allison(!!!) but it would be at least a $250K
upgrade and I have a 80hr engine now. Supposedly it well take off in about 80' with the Allison.. Mike MU-2 "Jim Burns" wrote in message ... Thanks Mike! Great explaination of desired airflow vs. HP. Several years ago our aerial applicators mounted gearboxes and longer props to their round engined Air Tractors. Not only did they reduce the prop speed and noise but they increased the airflow around the airplane produceing a better spray pattern. Jim No, Helio owners only care about STOL performance. The Helio requires high power for takeoff only. Actually what it requires is high static thrust and it benefits from a large diameter prop so that thrust flows over more of the slats/wing/flaps. The geared engine can use a larger diameter prop without the tips going supersonic. Once airborn, the airplane is not going to go very fast (135-140kts) with its large wing and large exposed wheels no matter how much power is availible. |
Jim Burns wrote:
Mike, Just a few questions and thoughts, mainly because I'm curious. I'd be interested to know the HP rating of the GO480 installed in the Helio. I've been watching a few people that are building Bearhawks and one article mentions that the GO480 isn't favored for that application for the relative high weight to HP ratio compared to the 540. The QueenAir uses supercharged 480's. The unblown engines run about 295HP I believe. There's no free lunch. While the gohpers get more HP out of less cubic inches, the weight doesn't really go down because of the weight of the gear box. The CG does go forward a bit though. |
Mike Rapoport wrote:
I really want that 450hp Allison(!!!) but it would be at least a $250K upgrade and I have a 80hr engine now. Supposedly it well take off in about 80' with the Allison.. Are you going to put the All-Terrain tires and the air horns on it too? |
![]() "Ron Natalie" wrote in message ... Mike Rapoport wrote: I really want that 450hp Allison(!!!) but it would be at least a $250K upgrade and I have a 80hr engine now. Supposedly it well take off in about 80' with the Allison.. Are you going to put the All-Terrain tires and the air horns on it too? No, I thought that thing was pretty stupid. The performance was about the same as a stock Helio after they added 1000lb to the empty weight. Mike MU-2 |
No, I thought that thing was pretty stupid. The performance was about the same as a stock Helio after they added 1000lb to the empty weight. Yeah, but it was soooo cool! ;-) First train I've ever heard going over at 1000 AGL... -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
On Wed, 22 Jun 2005 21:04:19 GMT, "Mike Rapoport"
wrote: The ultimate Helio is a early model with an Allison turbine engine. I know of only one that exists. This give you a larger prop, much more power AND lighter weight, although fuel consumption eats up some of the weight savings. I seem to recall a Sport Aviation article about a Helio or similar STOL plane converted to turbine. The owners put a lot of crazy conversions onto the plane. For example, they had a train whistle driven by bleed air from the engine, a sprayer/fogger system for killing mosquitos in the area prior to landing, and tires that looked to be from a 4x4 truck. One hell of a back country airplane. -Nathan |
Nathan Young wrote:
I seem to recall a Sport Aviation article about a Helio or similar STOL plane converted to turbine. The owners put a lot of crazy conversions onto the plane. For example, they had a train whistle driven by bleed air from the engine, a sprayer/fogger system for killing mosquitos in the area prior to landing, and tires that looked to be from a 4x4 truck. One hell of a back country airplane. Last I read, they were removing most of that, except the turbine that is... To get better cruise performance... Guess it was fun for awhile and then became impractical for frequent usage... |
