Metallic paint and composite antenna signal strength
Old June 28th 05, 12:38 AM
RST Engineering
Absolutely NOT. That is the LAST place you want a ferrite-foil dipole. You
want a "stock" "B-B on a BNC" with a pie plate ground plane. Dipoles waste
half your expensive transmitter power warming up the ionosphere.
"Joe Camp" wrote in message
On Sun, 26 Jun 2005 07:41:15 -0700, "RST Engineering"
sounds like a good place to use Wier's foil antenna setup :-)
Old July 3rd 05, 05:28 AM
firstflight
Sorry for the delay in my response. I was dragged away on vacation.
The antenna is designed to be "GLUED" in place. See the info at:
http://www.advancedaircraft.com/index.htm
The paint in question is made by Dupont and has actual medium and small
Aluminum flakes in it.
I am going without the metallic paint just to be sure, but glad I was able
to get some thoughts on the topic.
Thanks all.
"Rich S." wrote in message
"RST Engineering" wrote in message
No, that wasn't the point. You CAN'T bond (as in glued to) a ground
plane type of transponder antenna to the plastic fuselage. If you were
so ... ummm ... thoughtless as to try and bond a dipole type antenna for
transponder use half your transponder power gets radiated into outer
space. Where, as I understand it, no ATC facilities yet exist.
Actually, ATC probably does have facilities somewhere in "outer" space.
Local space has yet to comply with the EPA regs.
Rich "How far out is outer??" S
Old July 3rd 05, 04:17 PM
RST Engineering
Sorry, if I had known you were spending hundreds of dollars of your money on
fives and tens of dollars worth of antennas I'd have told you to go to the
manufacturer who is taking your money and ask the question. After all, you
should be getting SOMETHING for your money.
I will stand by my assertion that if you do not use a ground plane for your
transponder antenna you will be wasting half of your transponder power.
"firstflight" wrote in message
Old July 26th 05, 09:10 PM
Rich S.
No, that wasn't the point. You CAN'T bond (as in glued to) a ground plane
type of transponder antenna to the plastic fuselage. If you were so ...
