Fuel selector or two check valves?
Old June 28th 05, 08:12 AM
Rob Turk
Default Fuel selector or two check valves?
Instead of using a left/right fuel selector, could I use two check valves
and connect the two tanks into a single feed?
[LTANK]---|-----T-----|-----[RTANK]
Where | and | are the check valves and 'T' is a T-connector towards the
header tank.
The check valves prevent fuel moving from one tank to the other. Any pro's,
con's or thoughts?
Rob
Old June 28th 05, 08:22 AM
Edgar
"Rob Turk" wrote in message
news:SN6we.366$in3.124@amstwist00...
header tank.
pro's,
con's or thoughts?
I'd want more control over the actual fuel usage than a check valve will
give me. The selector valve will allow you to use fuel from the 'heavy side'
to properly level out- check valves will not allow this. Then you can leave
the selector valve on 'both' for normal conditions.
Old June 28th 05, 09:12 AM
Rob Turk
"Edgar" wrote in message
header tank.
pro's,
con's or thoughts?
side'
leave
Wouldn't gravity take care of leveling the two tanks? That way there
wouldn't be a heavy side. My assumption is that the fullest one will create
more pressure, causing it to level automatically. Wrong assumption?!? This
is on a high-wing plane by the way..
Rob
Old June 28th 05, 01:30 PM
Drew Dalgleish
Rob
I think that your tanks will not feed evenly because of little
differences in the way the lines run and venting. You will also lose
the ability to run one tank dry to extend your range. On my murphy
rebel one tank feeds a lot faster than the other one when I'm running
on both.
Old June 28th 05, 01:54 PM
Mark Smith
Rob
on both.
Very dependent on how far below the tank outlet the two lines/valve
connects the two feed lines,,,,,,,,,,
a connection that is level with the tank outlets will very likely have
trouble feeding both tanks evenly,
a much lower connection won't care,,,,,,,,,
Mark Smith
Tri-State Kite Sales
1121 N Locust St
Mt Vernon, IN 47620
1-812-838-6351
http://www.trikite.com
Old June 28th 05, 03:22 PM
Drew Dalgleish
Rob
on both.
that may usually be the case but on my plane the connection is at the
firewall just ahead of the gascolator. thats almost 3' difference in
height. When I did my fuel flow test the tanks flowed the same amount.
Mark Smith
1121 N Locust St
Mt Vernon, IN 47620
1-812-838-6351
Old June 28th 05, 04:02 PM
Dave S
Is the fuel above or below the engine (high wing or low wing?)
it IS possible in a low wing configuration for one tank to completely
drain and then suck air.
The answer to that is to use a sump or gravity fed header tank.
The Velocity plans call for two strake mounted tanks, draining into a
single sump, from there the fuel is fed to the engine. In practice the
two strake tanks and sump function as a single fuel tank. The check
valve isnt necessary.
Dave
header tank.
con's or thoughts?
Rob
Old June 28th 05, 04:39 PM
Al
How would you shut off the fuel? Let's say in the case of fire. Al
header tank.
pro's, con's or thoughts?
Rob
Old June 28th 05, 04:49 PM
Mark Smith
Rob
on both.
I'd bet mine would too, on the ground,
but in the air, they were several inches different, and with a tank that
is pretty thin, it is a bunch of fuel, or air, since the pump will suck
air from the empty tank rather than fuel from the partially full one,
I solved it by installing two small forward pointing tubes that mount on
the caps,,,,
Mark Smith
1121 N Locust St
Mt Vernon, IN 47620
1-812-838-6351
Old June 28th 05, 06:40 PM
Rob Turk
"Al" wrote in message
news:1119973229.7b47c562c0536a3cc6ea1419507bddbe@t eranews...
The full picture is a bit more complex (isn't it always...)
This is a high-wing plane (Rans S6S). Both main tanks have breather pipes to
pressurise the tanks during flight. The fuel lines from the tanks flow into
separate entries of a fuel buffer tank (approx 1.5 Gallon) placed low, below
the luggage compartment. From the buffer tank a single feed goes through a
Facet pump (just in case), then through the fuel filter to a shut-off valve
near the firewall, within easy reach of the pilot. Then through the firewall
into a gascolator. Output of the gascolator goes to the mechanical pump on
the Jabiru engine, then to the carburettor.
The overflow of the gascolator goes through a check valve, then through a
return line into the buffer tank.
What I'm trying to determine is if I should use separate cut-off valves in
the lines from the main tanks to the buffer, or that I can use check valves
instead.
Rob
Time, running out of fuel and fuel gauges Dylan Smith Piloting 29 February 3rd 08 07:04 PM
Weatherhead fuel valves? Yosimite Sam Home Built 2 February 14th 04 12:21 AM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Home Built 0 January 26th 04 07:48 AM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 07:09 PM
Hot weather and autogas? Rich S. Home Built 33 July 30th 03 11:25 PM
