#31
![]() Matt Barrow wrote: wrote in message oups.com... Wayne LaPierre of the NRA, Ollie North, and Kenneth Starr all support the ACLU. Does that mean they are socialists? First, do you have a cite for LaPierre and North? Starr, being a lawyer, probably would support them. I found it about a month ago at abcnews.com. I don't know if it's still there. And yes, to an extend, North and Starr have a lot of socialist in them (can't speak for LaPierre). In any case, your point is a non-sequitur. Well, I guess it would be if it were MY point. I fly, own an airplane, and I support the ACLU, although I think it picks and chooses its cases with a touch of hypocrisy. A _LOT_ of hypocrisy. Their original premise was not a matter of "principle of free speech". It was to avoid stifling the Communist Party USA's propaganda. Their main, original funding came from the Soviet NKVD (as demonstrated by the Soviet Archives). When they take on the universities and their speech code they'll have demonstrated they are no longer puppets. Gosh, you sound like a John Bircher, or a conspiracy theorist. ACLU took on the Communications Decency Act and got it declared null and void. It constantly monitors Bill of Rights violations by big brother. All due respect, I don't give a damn who founded it or about some unsubstantiated gossip claiming to have come from soviet archives. |
#32
Answering Matt's statement that vapor lock has nothing to do with the
type of fuel: One reason why the FAA is reluctant to grant STC's for mogas is because of its vapor-lock propensities. There have been studies and plenty of discussion about the differences in vapor pressure at the same temperature and pressure between avgas and mogas. There was some discussion not long ago, iirc, in RAH. Google and you will find. |
#33
![]() wrote in message oups.com... Matt Barrow wrote: wrote in message oups.com... Wayne LaPierre of the NRA, Ollie North, and Kenneth Starr all support the ACLU. Does that mean they are socialists? First, do you have a cite for LaPierre and North? Starr, being a lawyer, probably would support them. I found it about a month ago at abcnews.com. I don't know if it's still there. And yes, to an extend, North and Starr have a lot of socialist in them (can't speak for LaPierre). In any case, your point is a non-sequitur. Well, I guess it would be if it were MY point. And what the hell IS your point? I fly, own an airplane, and I support the ACLU, although I think it picks and chooses its cases with a touch of hypocrisy. A _LOT_ of hypocrisy. Their original premise was not a matter of "principle of free speech". It was to avoid stifling the Communist Party USA's propaganda. Their main, original funding came from the Soviet NKVD (as demonstrated by the Soviet Archives). When they take on the universities and their speech code they'll have demonstrated they are no longer puppets. Gosh, you sound like a John Bircher, or a conspiracy theorist. And you sound like you haven't a clue what you're talking about and pull crap out of your ass as your suits your whimsey. As you demonstrate below, you're not only full of it, but have a tenuous grasp of reality. ACLU took on the Communications Decency Act and got it declared null and void. After a whole bunch of others beat them to it buy nearly a year. It constantly monitors Bill of Rights violations by big brother. Yeah, like the college speech codes? How totally full of ****! Like I said, as long it their boys are theBIG BROTHERS... All due respect, I don't give a damn who founded it or about some unsubstantiated gossip claiming to have come from soviet archives. (Such a man of principles!! :~( ) Man, you are totally in LaLa land! Thanks for making substantiating my points. |
#34
![]() wrote in message ups.com... Answering Matt's statement that vapor lock has nothing to do with the type of fuel: One reason why the FAA is reluctant to grant STC's for mogas is because of its vapor-lock propensities. There have been studies and plenty of discussion about the differences in vapor pressure at the same temperature and pressure between avgas and mogas. There was some discussion not long ago, iirc, in RAH. Google and you will find. http://www.avweb.com/news/maint/187232-1.html ------------------------- A large proportion of low-compression aircraft engines from both Lycoming and Continental were originally certificated for operation on 80/87 octane aviation gas. Most Lycoming O-235, O-290 and O-320 engines fall in this category, and so do some of the larger O-360 and O-540 engines. Most Continental O-200, O-300 and O-470 engines, and some of the fuel-injected IO-470 and IO-520 engines can run it as well. So, if you have a low-compression engine, can you just fill it up with autogas and take off? Nope, you've got to get an appropriate STC -- and despite what you may have heard elsewhere, it is very important to get that STC, even though it usually will consist of one or two pieces of paper, plus new decals for your fuel ports. Why is the STC important? While unleaded autogas provides sufficient octane to substitute for 80/87 avgas in low-compression engines, there are other differences that can cause problems when using autogas in some engine installations. The two most significant are lower vapor pressure -- which can lead to vapor lock -- and incompatibility between some of the additives in autogas and some components (particularly seals) in some aircraft fuel systems. In order to qualify for an STC, a particular airframe/engine combination has to be rigorously tested, to include either a 150 hour engine endurance test or 500 hour flight test, under controlled conditions. The tests also include checking operation at high ambient temperatures, which can create vapor lock. Some aircraft don't pass -- the Piper Apache and Comanche-250, and Cessna Skyhawk with Avcon's 180HP conversion all failed testing, and cannot legally run autogas. In a nutshell, by buying the STC you are paying for a bunch of research and testing to verify that it really is safe to use autogas in the airframe/engine combination you have. In a few cases, you may be required to have modifications made or the STC may authorize only premium (91 octane or higher) autogas. For example, Petersen Aviation's STC for Piper PA-28-160, -161, -180, and -181 models requires replacing the electric boost pump and running premium gas. ----------------------------- |
#35
On 4-Jul-2005, "Matt Barrow" wrote:
Well, vapor lock has nothing to do with the type of fuel you're running. On 4-Jul-2005, "Matt Barrow" wrote: While unleaded autogas provides sufficient octane to substitute for 80/87 avgas in low-compression engines, there are other differences that can cause problems when using autogas in some engine installations. The two most significant are lower vapor pressure -- which can lead to vapor lock -- and incompatibility between some of the additives in autogas and some components (particularly seals) in some aircraft fuel systems. Hmm.... either there are two Matt Barrows (using the same e-mail address) or else he is schizophrenic. Judging from some of his political views, I'd say the later is a distinct possibility. -- -Elliott Drucker |
#36
![]() wrote in message news:OWiye.14793$mr4.13119@trnddc05... On 4-Jul-2005, "Matt Barrow" wrote: Well, vapor lock has nothing to do with the type of fuel you're running. On 4-Jul-2005, "Matt Barrow" wrote: While unleaded autogas provides sufficient octane to substitute for 80/87 avgas in low-compression engines, there are other differences that can cause problems when using autogas in some engine installations. The two most significant are lower vapor pressure -- which can lead to vapor lock -- and incompatibility between some of the additives in autogas and some components (particularly seals) in some aircraft fuel systems. Hmm.... either there are two Matt Barrows (using the same e-mail address) or else he is schizophrenic. Judging from some of his political views, I'd say the later is a distinct possibility. -- -Elliott Drucker I'm keeping out of the politics on this one, except to say that two out of every one of us could be schizophrenic. After talking to a Shell Guru at a seminar my understanding is that the vapour pressure issue with mogas can be of real concern and that mogas is best used for low altitude work. His other push was the relative quality of avgas versus mogas - not just in manufacture but in distribution. With what I find in many of the auto fuel filters I change, I'd have to agree. I have had about 15 cases from one local servo in the past 8 to 10 weeks. Now that, in Oz, ethanol is included in much mogas, not to mention the odd toluene shonk, I would be wary about mogas use for long haul or high altitude. Also goes without saying that you don't get as far on a litre of fuel containing ethanol and/or toluene. Brian |
#37
George Patterson wrote:
Charles Oppermann wrote: The cost of insuring an aircraft has skyrocketed at a rate greater than fuel costs. Really? That wasn't the case when I owned my Maule. The premium was something like $1,700 the first year (1995-96), but it came down to around $1,300 the last few years. IIRC, the quote I got last February was less than that. Please don't get in the way of Barrow's ideologically-driven complaining about trial lawyers through the proxy of imagined increases in insurance costs. |
#38
![]() wrote in message news:OWiye.14793$mr4.13119@trnddc05... On 4-Jul-2005, "Matt Barrow" wrote: Well, vapor lock has nothing to do with the type of fuel you're running. On 4-Jul-2005, "Matt Barrow" wrote: While unleaded autogas provides sufficient octane to substitute for 80/87 avgas in low-compression engines, there are other differences that can cause problems when using autogas in some engine installations. The two most significant are lower vapor pressure -- which can lead to vapor lock -- and incompatibility between some of the additives in autogas and some components (particularly seals) in some aircraft fuel systems. Hmm.... either there are two Matt Barrows (using the same e-mail address) or else he is schizophrenic. Judging from some of his political views, I'd say the later is a distinct possibility. It's called correcting myself. You call it schizophrenia, I call it maturity. Get a ****ing clue, statist prick! |
#39
![]() "xyzzy" wrote in message ... George Patterson wrote: Charles Oppermann wrote: The cost of insuring an aircraft has skyrocketed at a rate greater than fuel costs. Really? That wasn't the case when I owned my Maule. The premium was something like $1,700 the first year (1995-96), but it came down to around $1,300 the last few years. IIRC, the quote I got last February was less than that. Seeing as the accident rate has declined dramatically over the past several years, that fits. Please don't get in the way of Barrow's ideologically-driven complaining about trial lawyers through the proxy of imagined increases in insurance costs. Do you recall the 1994 act that brought back the aviation industry from deaths door? Do you recall WHAT it did? Do you comprehend that engineering is not OMNISCIENT? Do you also recall that only a handful of suits had anything to do with real negligence? Your post demonstrates a real negligence of harebrained ideology...that of making excuses most people wouldn't accept from a ten year-old. GFY. |
#40
![]() On 5-Jul-2005, "Matt Barrow" wrote: Hmm.... either there are two Matt Barrows (using the same e-mail address) or else he is schizophrenic. Judging from some of his political views, I'd say the latter is a distinct possibility. It's called correcting myself. You call it schizophrenia, I call it maturity. Get a ****ing clue, statist prick! Yeah, right. For a while I was confused. How could someone as clearly challenged by the English language (and common logic) as Mr. Barrow have composed the lucid and intelligent comments in his second post regarding vapor lock (which completely contradicted his earlier post on THE SAME DAY)? However, I took his advice to heart and "got a clue." A simple Google search on the phrase "incompatibility between some of the additives in autogas" pointed me to the following website: http://www.aviation-indonesia.com/mo...rticle&knid=16 It seems that in addition to his wealth of other shortcomings Mr. Barrow is also a plagiarist. -- -Elliott Drucker |
