New Battery -- thanks for the recommendation
Old July 6th 05, 07:06 PM
RST Engineering
Nothing on the airplane isn't on a "worry about" list. It just took it from
the #1 priority list to the #3 or #4 list.
Crap. And here I thought I had removed the battery from my "worry about"
list...
Old July 6th 05, 07:21 PM
Jay Honeck
And what is vinegar but acetic acid. So you neutralized acid with acid?
Not in my chem class you don't. You could have used window-cleaning
ammonia to do the neutralization, but the stuff of choice is plain old
Arm&Hammer baking soda at about a 10% concentration in water.
Okay, "neutralize" it doesn't. "Dissolve" it does, and then I "neutralized"
with the ACF-50 goop.
It still smells good!
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old July 6th 05, 07:59 PM
Maule Driver
8 years. That's sounds pretty good. Perhaps too long.
i've had to change batts every 3-4 years. Both sealed Concordes and an
unsealed something. That last year, the battery just gets a little
weaker and weaker until one cool day, it just won't go.
I think I'm taking adequate care and am unaware of any discharge problem.
What are other people's experience with battery life?
Jay Honeck wrote:
Just installed the new Concorde RG 35AXC -- the most powerful battery
approved for my plane -- and, wow, what a difference! No more "bumping"
the starter to get the prop past the highest compression stroke of that big
ol' six cylinder on a hot day... It just whirls it right around!
When I pulled the 8-year old battery out, there was an area of spilled
acid/crusty stuff that had to be cleaned thoroughly. I'm looking forward to
this new "sealed" battery eliminating that problem, and the yearly expense
of paying my A&P to clean the battery box (and surrounding area) at every
annual inspection.
I can't remember who recommended this battery to me -- but it's great --
thanks!
Old July 6th 05, 08:12 PM
Jay Honeck
Yeah, I'm pretty satisfied with that kind of life from a battery. My A&P
says it lasted so long because we fly often, and kept the thing charged up.
He also thinks our new (in March) wing-tip landing lights probably were the
kiss of death for the old battery. It was probably weak, getting weaker,
and then I put that big ol' load on it. (The amp-meter shows over 40 amps
with everything on, which means the alternator probably can't keep up when
taxiing....)
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old July 6th 05, 08:15 PM
nrp
C172M - I've always gotten at least 8 years from the last three
batteries. Just never let the plates get exposed to air, never let it
get discharged & keep the top clean. I do not put any trickle charger
on it unless everything is down for many weeks. I also have never had
to use the ground service plug - except when the FAA Certified Repair
Station left the master on after an annual.......
Old July 6th 05, 08:26 PM
Jay Masino
RST Engineering wrote:
Arm&Hammer baking soda at about a 10% concentration in water. When it stops
bubbling with each fresh application, you is done.
I also re-coat the inside of the box with some of that acid resitant black
paint that you can get at most of the aircraft parts places.
__!__
Jay and Teresa Masino ___(_)___
http://www2.ari.net/jmasino ! ! !
http://www.OceanCityAirport.com
http://www.oc-Adolfos.com
Old July 6th 05, 08:27 PM
Jay Masino
annual inspection.
Yike! 8 years? I suspect that replacing that battery with ANY battery
would have made it spin faster.
__!__
Old July 6th 05, 09:10 PM
RST Engineering
Are you talking about the Pep Boys Aircraft Supply Depot?
Old July 7th 05, 03:21 AM
Jim N.
You should check, but my understanding is that the RG batteries may only
last 2-3 years, and that the decreased life is a trade-off compared to
normal lead acid batteries.
For what it's worth, I was told to change the battery on the Extra (by
necessity an RG) every two years, while the normal batteries in the Baron
are a lot older and still crank well.
Old July 7th 05, 05:38 AM
Jay Honeck
Man, I hope not. At $162, this battery ain't cheap.
Anyone got any real-life numbers on this?
Why would they tell you to replace a battery based on the calendar? If it's
still cranking fine, what other parameter is there to worry about?
Jay Honeck
Iowa City, IA
Pathfinder N56993
Batteries, charger for Yaesu handheld - NiCad or NiMH? David Herman Owning 10 November 7th 04 04:30 PM
14 Volt Gel Cell? Joe Allbritten Soaring 32 May 11th 04 01:37 AM
Icom A5 Battery Tester ?? Harry Gordon Piloting 5 January 10th 04 01:29 PM
Becker AR 4201 or Microair 760 Transceiver Steve B Soaring 23 September 15th 03 06:32 PM
Battery life...how to test? Jim Kelly Soaring 2 July 11th 03 09:12 PM
