Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Restoration
restoring a DC9 restroom... at home
Old July 6th 05, 11:47 AM
Default restoring a DC9 restroom... at home
I want use my home workshop to rebuild an old, junked restroom from a
USAF DC9.
The milspec drawings show a slot for "used razor blades".
How often am I supposed to clean out the used razor blades to maintain
airworthiness specs?
Old July 6th 05, 12:28 PM
Robert Bonomi
In article .com,
USAF DC9.
single-edged, or double-edged?
Old July 6th 05, 06:25 PM
John Kunkel
USAF DC9.
Not to worry, Homeland Security won't allow razor blades in an aircraft
****ter, ground bound or not. BG
Old July 6th 05, 10:20 PM
Vaughn
"Robert Bonomi" wrote in message
In article .com,
USAF DC9.
The medicine cabinet in my childhood home had such a slot. Back then, a
razor blade was only good for one or two shaves. My father must have dropped
thousands of blades down that slot over the decades. Always wondered where they
went.
Vaughn
Old July 6th 05, 11:00 PM
RST Engineering
A 15" medicine cabinet was designed to fit between standard 2x4 studs on 16"
centers. The blades dropped into the inter-wall space created by those
2x4s. A quick calculation for a medicine cabinet at 5' high, 15" wide, 3.5"
deep shows a space of some 3150 cubic inches. Assuming the blades were
about 1" x 2" x 0.005, this gives a blade volume of.01 cubic inches. You
could drop 315,000 blades into the slot before the space filled up. If you
changed blades every other day, you had a little over 1700 years of
capacity.
"Vaughn" wrote in message
a razor blade was only good for one or two shaves. My father must have
dropped thousands of blades down that slot over the decades. Always
wondered where they went.
Vaughn
Old July 6th 05, 11:49 PM
Ebby
I can cross that one off my list of things I wonder about.
Old July 7th 05, 12:10 AM
Vaughn
"RST Engineering" wrote in message
centers. The blades dropped into the inter-wall space created by those 2x4s.
A quick calculation for a medicine cabinet at 5' high, 15" wide, 3.5" deep
shows a space of some 3150 cubic inches. Assuming the blades were about 1" x
2" x 0.005, this gives a blade volume of.01 cubic inches. You could drop
315,000 blades into the slot before the space filled up. If you changed blades
every other day, you had a little over 1700 years of capacity.
Ah yes Jim, but you forgot to take the firestops into consideration. They
were usually staggered at about bellybutton height, so that might cut the
capacity to something well under 1000 years. Those firestops are every old-work
electrician's nemesis. But running a wire is nothing, my old man (when he
wasn't shaving) used to fish heating ducts up through existing walls without
opening the plaster.
Actually, that was a heluva good answer Jim.
Vaughn
Old July 7th 05, 12:15 AM
Edgar
16"
3.5"
you
capacity.
IF they fell correctly (flat).
Old July 7th 05, 12:40 AM
RST Engineering
In California we never worried about it. The next earthquake would always
level them out.
"Edgar" wrote in message
If
you
capacity.
Old July 7th 05, 12:56 AM
Dan
In one of the buildings I used to work in, all the medicine cabinets had
that slot, and they all opened up in the back into a pipe chase thru which I
had to run wire. Long sleeves and leather gloves all day every day in those
places. I never got cut badly but one fellow got caught just right and
almost bled to death, in a nurses residence, on a hospital campus.
then, a razor blade was only good for one or two shaves. My father must
have dropped thousands of blades down that slot over the decades. Always
Vaughn
faa home study graduation certificate Falky foo Piloting 19 February 10th 05 11:38 PM
[Media] A Marine's journey home Michael Wise Military Aviation 0 May 3rd 04 04:57 AM
[Media] A Marine's journey home Michael Wise Naval Aviation 0 May 3rd 04 04:57 AM
Home Inspection Listings Patrick Glenn Home Built 4 April 26th 04 11:52 AM
N94 Airport may expand into mobile home community, locals supportive William Summers Piloting 0 March 18th 04 03:03 AM
