ICOM A24
Old July 6th 05, 12:32 PM
John Sp
Default ICOM A24
Can anyone tell me if this radio can be operated and re-charged (at the same
time) from a 12V source -(Aircraft/Auto battery)
Thnaks in advance from John in Cape Town
0
Old July 7th 05, 02:35 AM
Morgans
"John Sp" wrote in message
same
I believe that the answer is yes, but it is not to transmit while on charge.
The owners manual has that information. Check that to be sure. The manual
should be online.
You will need a voltage converter (cigarette lighter adapter) of the correct
voltage output, as selected by the voltage input label, on the case of the
radio.
Jim in NC
Old July 7th 05, 06:18 AM
same
should be online.
radio.
FWIW, I emailed ICOM about my IC-A5, and they definitely said not to transmit on
the charger. I bought a plug-in battery eliminator.
Old July 7th 05, 08:56 AM
Morgans
transmit on
the charger.
My ICOM, also. Do you (or Jim) know what the reason (electronically) is,
behind this restriction?
Jim in NC
Old July 7th 05, 11:59 AM
Scott
It's probably because the charger can only put out a smaller amount of
current than the transmitter needs during transmit. If the battery is
too low in charge and unable to supply the transmit current, it will try
to draw the required current from the charger, possibly until burnout.
Scott
transmit on
the charger.
ICOM Headset Adaptor Plug Ron Wanttaja Home Built 3 June 2nd 05 07:54 AM
Icom A6 Radio Registration Problem Clyde Torres Home Built 4 May 6th 05 12:21 PM
ICOM IC-A23 Sport Karl-Heinz Künzel Piloting 1 September 11th 04 06:43 PM
Icom IC-A5/23 and David Clark Thomas Schmidt Piloting 5 August 16th 04 09:45 PM
Icom CM-35 Desktop Battery Charger for Icom IC-A2 Radio A. Kay Aviation Marketplace 0 August 23rd 03 08:01 AM
