Continental accessory case
Old July 8th 05, 05:40 AM
pwm
Default Continental accessory case
Does anyone know if a Continental O-200 or a C-75 rear accessory case will
fit an A-65? Reason for asking is that I'm wanting to add a starter and a
generator.
Thanks,
Monty
Old July 8th 05, 03:23 PM
pwm
Can you elaborate as to the modifications necessary to make a -12 acc case
work on a A-65 crankcase?
Thanks,
Monty
"Cy Galley" wrote in message
news:8muze.144887$xm3.82381@attbi_s21...
Not as they come from the factory. But anything is possible with a
talented machinist but the FAA will NOT approve without a 337.
"pwm" wrote in message
will fit an A-65? Reason for asking is that I'm wanting to add a starter
and a generator.
Thanks,
Monty
Old July 8th 05, 10:04 PM
Morgans
talented
Cy, you gotta think outside the box! Here in the world of homebuilts, there
are no 337s!
Jim in NC
Old July 9th 05, 02:27 AM
Cy Galley
Have to change a bunch of gears. but the crank is has the same bearings.
I've been told one can put an O-200 crank in an A-65 AND the cylinders as
well.
There is a company that has an STC to put a -12 accessory case on a -8 C-85
so I'll be it can be done on the A-65. All it takes is money and a good
machinist.
The real problem is it adds weight and after being done ;the 2 place plane
becomes a single.
Cy Galley - Aeronca Aviators Club
Newsletter Editor & EAA TC
www.aeronca.org
Actively supporting Aeroncas every day
Thanks,
Monty
and a generator.
Thanks,
Monty
Need PAN and Rear ACCESSORY CASE Gaskets For 0-435 Lycoming Engine Spar Home Built 5 March 30th 04 10:09 PM
Need PAN and Rear ACCESSORY CASE Gaskets For 0-435 Lycoming Engine Spar Aviation Marketplace 5 March 30th 04 10:09 PM
Need PAN and Rear ACCESSORY CASE Gaskets For 0-435 Lycoming Engine Spar Owning 5 March 30th 04 10:09 PM
Need PAN and Rear ACCESSORY CASE Gaskets For 0-435 Lycoming Engine Spar Restoration 6 March 30th 04 10:09 PM
Continental Airlines Complaint - A Newspaper article John B. Piloting 40 October 21st 03 04:07 PM
