#51
Thanks for that link.....
Fred wrote in message oups.com... Just to add a little gasoline to the legal vs. practical argument, there are a good number of STCs out there that allow for gross weight increases. Power Flow has one for the C-172N that with relatively small modifications (limit flap travel, a cowl cooling lip that some N's already have) makes it legal to carry an extra 100lbs. http://www.powerflowsystems.com/prod...htincrease.htm |
#52
![]() "Michael" wrote in message oups.com... I know that when I was receiving training, my instructor once had me bring 2 male adults with me to a lesson. He then had you project performance and handling characteristics by extrapolating from the POH and maybe other sources. In flight, he discussed these issues with you so you would know how to handle the situation in the future, pointing out quirks of the operation. No? He just told you to get in and go? I wish that were the exception, but it's the rule. He was teaching you how to fly overgross, and he was doing about the worst possible job of it. Yeah - you did it in that particular instance. You learned a little - mainly, you learned that operating outside the published envelope has consequences, and a bit about what they can be. But without an underlying framework for understanding, all you learned is what happens in that one specific case. Since that specific case is unlikely to be repeated exactly, you haven't really learned anything very useful. So the answer to your question of how much is too much? When the safety margin associated with the limiting factor in play under the circumstances becomes uncomfortably slim, that's too much. Michael Very nice post, and I enjoyed reading it. I especially like your view on what my instructor did, and you make a very good point. I have admitted to myself, that he did some things in my training that, although we got away with, were wrong, and I remember those each time I fly. You make a very good point with regard to teaching without the proper framework. I will also remember that. Thank you for you comments. Fred |
#53
![]() If your limit is 45 over gross, how far over your limit is ok? How about as far as airlines go over-weight on a daily basis as a result of the FAA standard person not being equal to the actual load they're dealing with? Not everyone weights 170lbs or whatever the latest number is.......... |
#54
Can an
average GA plane take off with a load great enough to cause damage in the event of hitting some chop? I don't know, but I suspect that should be the least of one's worries. That depends on the airplane. If you're dealing with a normal category airplane with old and possibly deteriorated wing structure, I sure would worry about it. Some of the heavier Cessna twins that served a lifetime in hauling cargo (where, contrary to regulations, gross weight is often exceeded, as is zero fuel weight on short runs). Consider these accidents: http://www.ntsb.gov/ntsb/brief2.asp?...FA123& akey=1 This is a narrative of the NTSB accident investigation that prompted the original Airworthiness Directive against the 400-series Cessnas. Note that the blame is placed on a manufacturing defect, but that does not diminish the role that repetitive misloading may have played in the failure. http://www.ntsb.gov/ntsb/brief2.asp?...FA208& akey=1 This is narrative of an NTSB accident investigation of a Cessna 402 engaged in Part 135 cargo operations that crashed into the Caribbean Sea. Only parts of the aircraft and some cargo were recovered, and no probable cause is listed. However, known circumstances outlined in this report point to wing spar failure, the report suggests that misloading played a factor. Is this is a factor overloading a C-172? Not just no, but hell no. But here's the problem - you get away with it on a C-172, and unless you understand what you did and why you did it, you have no frame of reference to know you can't do the same thing on a C-402. CG seems a more pernicious issue to me, as the plane's behavior can fool you. Chances are you won't realize you're thoroughly screwed until after you're up in the air without any good options. Well, that's overstating the case by quite a lot. The cg needs to be quite a bit aft of limits before normal flight and a normal landing are a problem. Oh, you'll feel the reduced longitudinal stability, but it likely won't be bad enough to keep you from landing the plane. Just don't stall. Also realize that as weight increases, generally the cg limits narrow. The real issue occurs in a tailwheel airplane. A tailwheel airplane loaded aft of cg can be a real bear on the ground - lots of weight aft of the mains give it very poor lateral stability. In addition to takeoff CG, I'd also compute CG with half fuel and very little fuel, just in case. It's not a just in case. In the Beech Bonanza, it's a real issue. As you burn fuel, cg moves aft - and unless you have some real big boys up front and little or nothing in back, you're never far from the aft limit anyway. On the other hand, you have to try real hard to get a Brand C or Brand P aft of limits. Michael |
#55
![]() Excellent post! I have two comments... If you fly overgross, you're breaking the rules. Where will the rulebreaking stop? The answer is really nowhere. I agree. But as you pointed out earlier, keeping within max gross won't keep you safe, either. In other words, every flight includes making decisions about performance that are arbitary, or more precisely, that are based on experience. If experience didn't matter, why would we keep log books? If the rules were enough, why would we need anything else? You can study the design, and the available modifications and authorizations, to determine if it is performance, rather than structural integrity of some component, that limits gross weight. If it is structural issues -- which I would suggest it very rarely is -- you'll still have a huge safety margin when 5% or 10% over-weight. You are not going to be getting that close to the 'g' envelope, and your landings are hopefully not going to be hard enough to be given 10% of collapsing the gear! Further, if you look at accident reports where over-weight operation was a factor, I doubt you'll find many where structural issues came into play. In fact, I can't recall reading a single one, and like most pilots, I eat 'em up to try and learn from others' mistakes. As I said, the failure mode that matters most is failing to fly, or failing to get out of ground effect. |
#56
It depends on the aircraft. Well then, what does the word "limit" mean to you? As a test pilot, I agree there is no simple pat answer, and a previous post went into many of the factors that go into aircraft handling at high weights. But I'm not a test pilot, and have no intention of being one. And I've found in life that most of the time I've gotten into trouble with the laws of physics has been when I've been "over the limit" in one form or another. I'll stick with the book. That said, it would be nice if the book addressed limits a bit more completely (such as a graph showing the maximum takeoff weight vs density altitude). It doesn't, so I won't go there. Jose -- Nothing takes longer than a shortcut. for Email, make the obvious change in the address. |
#57
Exactly what we were discussing at work.....
I guess maybe it might relate to how many drinks can I have in a specified period before driving home..... Actually, I've found alcohol to be quite useful in aviation. In situations where I'd be over gross, I have a few six-packs of beer. If the pilot is already flying, then his weight can be subtracted from the manifest, allowing more cargo, or more fuel. By getting the passengers suitably high also, I can reclaim almost all the payload that way. So then, after the passengers have boarded the airplane, I calculate how much extra fuel each one represents, and have the FBO fill up one of those big fifty gallon drums full and we load it into the cargo compartment... you know, the one in the back that says "200 pounds max". Well, ok 50 gallons is 300 pounds, but if we average that over the whole airframe we're only 25 pounds over per passenger (and the bigger the passenger, the less that 25 pounds is, percent wise). And more fuel makes you safer anyway. So then I get on the runway, open the throttle, and climb as fast as I can. Really pull back on that yoke - the plane should climb like a bat out of hell, since it's virtually empty. Remember - eight bottles, then throttle. ![]() Jose (*) kids - don't try this at home! -- Get high on gasoline. Fly an airplane. for Email, make the obvious change in the address. |
#58
LOL!
Fred "Jose" wrote in message ... Exactly what we were discussing at work..... I guess maybe it might relate to how many drinks can I have in a specified period before driving home..... Actually, I've found alcohol to be quite useful in aviation. In situations where I'd be over gross, I have a few six-packs of beer. If the pilot is already flying, then his weight can be subtracted from the manifest, allowing more cargo, or more fuel. By getting the passengers suitably high also, I can reclaim almost all the payload that way. So then, after the passengers have boarded the airplane, I calculate how much extra fuel each one represents, and have the FBO fill up one of those big fifty gallon drums full and we load it into the cargo compartment... you know, the one in the back that says "200 pounds max". Well, ok 50 gallons is 300 pounds, but if we average that over the whole airframe we're only 25 pounds over per passenger (and the bigger the passenger, the less that 25 pounds is, percent wise). And more fuel makes you safer anyway. So then I get on the runway, open the throttle, and climb as fast as I can. Really pull back on that yoke - the plane should climb like a bat out of hell, since it's virtually empty. Remember - eight bottles, then throttle. ![]() Jose (*) kids - don't try this at home! -- Get high on gasoline. Fly an airplane. for Email, make the obvious change in the address. |
#59
![]() But I'm not a test pilot, and have no intention of being one. If being 1lb over-weight makes you a test pilot, then so does having an engine which is operating at 1hp less that its rated outputs. Or a wing that is contaminated with bugs and is producing less than the CoL that was present during POH testing. Or brakes that are operating at 1% less than new condition. Or, well, you get the idea........... |
#60
Fred Choate wrote:
How much is too much over gross weight? I will not fly 1 pound over gross, I will not delibrately break an FAR, I will always do a thorough pre-flight on the aircraft, I will only cancel IFR once I'm more than 500' below or 1000' above the clouds, etc. As a CFI, I have canceled lessons because the compass card was missing or not legible - perhaps the cancelation proves to be a better lesson for the student in the long run than the instructional flight. Either way, I'm not prepared to be tempted by the slippery slope. NAFI Code Of Ethics: http://www.nafinet.org/who/code.html Hilton |
Max gross weight | Chris | Piloting | 21 | October 5th 04 08:22 PM |
Apache Alternate Gross Weight | Jim Burns | Owning | 1 | July 6th 04 05:15 PM |
Buying an L-2 | Robert M. Gary | Piloting | 13 | May 25th 04 04:03 AM |
F35 cost goes up. | Pat Carpenter | Military Aviation | 116 | April 11th 04 07:32 PM |
Empty/Gross weight Vs. Max. Pilot weight | Flyhighdave | Soaring | 13 | January 14th 04 04:20 AM |
