#81
Hilton
Have you ever drained 5 gallons of fuel out of an airplane to get it under the maximum gross weight? Have you ever cancelled the Lesson due to the missing compass correction card while instructing/flying was your only source of income and you haven't flown (or been paid) for 3 weeks due to bad weather? What do you do on your Dual Cross countries when any of the following occur 100 miles from your home airport and 30 miles from the nearest Mechanic? And you have 3 more students waiting for you when you get back since they haven't been able to fly for past 3 weeks due to bad weather. 1. The Starter Fails 2. The Alternator Fails 3. The Trim Tab Indicator Breaks off 4. The Flap Position indicator Fails 5. The Compass Correction Card Blows out the Window. 6,. You discover the Fluid has all drained out of the Compass 7. Screw falls out of the Cowling 8. Transponder Fails 9. Brake Fails 10. Vacuum Pump fails 11. Stall Warning become inoperative 12, Flap motor Fails True flying with some of these failures is not even illegal. on the the other hand I have almost all of them occur to me at some time or another if not mulitple times. The Vacuum pump failed about 1 hour into my 1st solo Cross country. Not a big deal. Anyway the point is I doubt the statement "I will not delibrately break an FAR" would hold up many in these situations. Perhaps I am wrong in your case if so I suspect you are in a unique situation and more power to you. Also remember that many aircraft are crashed or damages without ever breaking a FAR. Brian |
#82
"Mike Granby" wrote in message
oups.com... "once you go over the max weight, you are essentially a test pilot". That's putting it a bit strongly. No, it's putting it quite accurately. As long as the CG issues are OK, the effects of being reasonably over-weight are quite predictable in terms of stall speed, take-off requirements etc. The effects of flight at any weight are quite predictable in terms of stall speed, take-off requirements etc. And yet, during certification, the airplane is required to be *tested* at in a variety of configurations by a *test pilot* to demonstrate the actual performance. Just because one can predict the performance, that doesn't change the fact that a person flying an airplane in an untested (as far as they know) configuration is a "test pilot". The structural issues won't come into it as many aircraft have their max gross determined by other things (eg. stall speed low enough for Part 23, or the need to go-around at max gross with full flaps) Very few single-engined airplanes have a stall speed at the maximum allowed value (noting, of course, that the "maximum allowed value" isn't really so much a hard limit, but rather one that a manufacturer is required to meet in order to avoid other things). It's true that max gross weight may be affected by things other than structural issues, but there is no way to know whether this is true without consulting the manufacturer (which I doubt the theoretical over-gross pilot is going to do), and I can think of at least one common airplane for which structural issues DO limit the maximum landing weight (which is lower than the maximum takeoff weight for that airplane). and in any case, there's a large safety margin in there. The reason for that safety margin is for normal, legal weight operations. It's not so you can operate over the legal limits. Operate over the legal weight, and you've just abandoned your "large safety margin". The fact is that assuming you're not on the edge re DA or runway length, 5% overweight is going to be safe. It isn't legal, but it will be safe. It *might* be safe. You are still a test pilot when flying over the legal weight, which is the comment to which you replied. As to the arguement that breaking one rule leads to breaking another, with respect, that is nonsense. That's like saying speeding leads to murder... That's a matter of opinion, I guess. I personally believe that if we had better enforcement of the little laws, we wouldn't have so many people disregarding the more important ones. Looking the other way when it comes to speeding (and similar) simply teaches people disregard for rules. Each person winds up setting their own limits, rather than respecting the limits society claims to have made. And yes, in some cases, those limits go way beyond just speeding. Obviously each individual who speeds doesn't wind up a murderer, but general disregard for the rules does certainly lead to other negative behavior. Pete |
#83
"Bob Moore" wrote in message
. 121... [...] At some airlines, I have seen references to "Maximum Gross Weight" and "Actual Gross Weight", but never just Gross Weight meaning a certificate limit. And yet, somehow, we all knew what he meant. We must all be psychic. |
#84
![]() As a CFI, I have canceled lessons because the compass card was missing or not legible - perhaps the cancelation proves to be a better lesson for the student in the long run than the instructional flight. Yeah, right. And I'm sure the guy who took time off work, drove to the airport, and then had you cancel on him 'cos the bloody compass card was ilegible was really pleased with the lesson you taught him. It's up to you how you teach, but I'm glad my CFI had a more realistic attitude......... |
#85
"Corky Scott" wrote in message
... On Fri, 08 Jul 2005 08:18:12 -0400, Stubby wrote: I'm met a few USAF test pilots. None of them ever talked about flying over max weight. During WWII, my impression is that nearly all the escort fighters and for sure all the bombers were over gross for every mission. Were the test pilots flying those missions? If not, I fail to see the relevance to the post you quoted. In any case, if I were loading up an airplane in order to intentionally fly it somewhere that had a good chance of getting me killed anyway, I probably wouldn't worry so much about aircraft weight either. That doesn't mean it's a reasonable philosophy for the rest of us. Pete |
#86
Matt Whiting wrote:
As a former part 135 charter and cargo pilot, I can also tell you that you wouldn't hold on to your job for long if you hold on to your principles so tightly. Some leeway is expected, as nobody operates in the perfect world except the FAA... and apparently, you. Is that why you are a former charter and cargo pilot? :-) Not even close. Nursing pays much better and the jobs are waiting for me in any town I chose to visit. My last flying position ended in a pilot's meeting on a Thursday telling us that the bank had taken our aircraft and it's been nice knowing us. On Saturday I picked up a newspaper telling me that a new nursing school had just been approved by the State Board and that they were taking applications. I was on the phone to them on Monday. The rest is history. -- Mortimer Schnerd, RN VE |
#87
"Dave Stadt" wrote in message
m... I believe you would lose that argument. Many a gross weight is set by the marketing department so the plane performs to a competition beating specification rather than some engineering requirement. Cite |
#88
![]() The same issue comes up with regard to landings. Long smooth runway in daylight and light winds, in a plane I've flown before many times? No problem. Unfamiliar airplane and short strip with gusty crosswinds? I think I want all the protection I can have. Agreed 100%. As I said before, it's about JUDGEMENT. See the NTSB references in my reply to cwk. I looked at these, both of which were for Cessna 402Cs, which I think immediately says something about whether we're dealing with a general or model-specific issue. The first, for N819BW, happened when the spar broke where it had been subject to mechanical damage AND deep machining marks. Hardly sounds like being over-weight was the cause here. The second, N405MN, can't really be put down to anything, since very little of the airplane was recovered. Again, hardly a clear case of over-weight operation causing structural failure. |
#89
Morgans wrote:
"Corky Scott" wrote During WWII, my impression is that nearly all the escort fighters and for sure all the bombers were over gross for every mission. The Hiroshima bomber took off 8 tons overweight. Wow. OK but that was a very special mission, not the typical test pilot task. Test pilots are not supposed to see how much over gross they can fly. They do things like fly in a 60-deg bank at 420 kts with a power setting of X to see what altitude change results. |
#90
Brian wrote:
Have you ever drained 5 gallons of fuel out of an airplane to get it under the maximum gross weight? Good God... no. Nor will I. I'd never be welcome there again. Have you ever cancelled the Lesson due to the missing compass correction card while instructing/flying was your only source of income and you haven't flown (or been paid) for 3 weeks due to bad weather? I can tell you at least have operated with the constraints placed on someone who flies for a living. These simplistic rules of thumb I've been reading from the self righteous here are making me want to spew. Simple rules are for simple people. What do you do on your Dual Cross countries when any of the following occur 100 miles from your home airport and 30 miles from the nearest Mechanic? And you have 3 more students waiting for you when you get back since they haven't been able to fly for past 3 weeks due to bad weather. You tie down the airplane, set the brake, set the throttle (gently) and hand prop it. Then you fly it home IFR (I follow roads). I've had most of that crap happen to me one time or another too. My last 135 cargo company expected us to continue to the destination on one engine if the other failed; they didn't get paid otherwise. That's the reality of flying for pay. You don't get the privileges of flying for fun. -- Mortimer Schnerd, RN VE |
Max gross weight | Chris | Piloting | 21 | October 5th 04 08:22 PM |
Apache Alternate Gross Weight | Jim Burns | Owning | 1 | July 6th 04 05:15 PM |
Buying an L-2 | Robert M. Gary | Piloting | 13 | May 25th 04 04:03 AM |
F35 cost goes up. | Pat Carpenter | Military Aviation | 116 | April 11th 04 07:32 PM |
Empty/Gross weight Vs. Max. Pilot weight | Flyhighdave | Soaring | 13 | January 14th 04 04:20 AM |
