I use "wire math": Weather, instruments, radios, everything else (speed, flaps) for set-up, and missed,
altitude, time and heading for breifing the approach. "John R. Copeland" wrote: I gotta get me one of them "anacronyms". :-) Seriously, though, filing IFR whether needed or not is good training. Pretty soon you'll find you no longer need mnemonics and acronyms. Maybe you'll need only a place to record clearances and amendments. ---JRC--- "Doug" wrote in message om... For approaches I use WestCoastRailRoad Weather, Clearance, Radios, and Review. I'll admit its a bit short of being exhaustive. I also have an IFR checklist in the plane for takeoff, cruise, arrival and approach phases. It IS exhaustive. As for my clearance, everything goes into a radio or instrument. Frequecies go into the radios, altitudes go into the altitude bug and headings go into the heading bug and waypoints go into the GPS. Not a bad idea to write them down also, but so long as my radios work, I can always ask. The reality is I just keep a 4 1/4" x 5 1/2" (half) pad of paper and a few pens in the plane and write down what I need on that. One of the things I do have is a business card sized flight plan form, I use it all the time so I have all the info to give flight service. All I really need to jot down is my takeoff time and enroute time that I gave him when I filed (well, ok, my destination, but I usually do know that). Works great and I dont have to bring any paperwork into the FBO, just my wallet, which I always have. It all depends on how exhaustive and organized YOU want to be. Do you want to emulate the airlines, or just fly around with minimum hassle? Or somewhere in between? I only file IFR if I need to, to get where I am going. Some file IFR all the time. So my suggestion, memorize an anacronym, get several 1/2 size notepads, some pens or pencils, and business card flight plan form, and you have the minimum necessary. -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
I used to use "wire math": Weather, instruments, radios, everything else (speed, flaps) for set-up, and missed,
altitude, time and heading for breifing the approach. Now after flying lots of hours in the system, it is easier to just use the audio panel plus the instrument faces to brief the setup. For each switch on the audio panel, check the switch in the right position, and set the corresponding radio. Reach the last switch, and all your radios are set up for the approach. Then check each of the primary instruments and set any knobs as appropriate. In my case, that is the autopilot, the altimeter, match the DG to the compass and set the heading bug, then go across the switches to make sure things there are set properly: lights, pitot heat, fuel pump etc, then all the way to the floor to check fuel tank and flaps. "John R. Copeland" wrote: I gotta get me one of them "anacronyms". :-) Seriously, though, filing IFR whether needed or not is good training. Pretty soon you'll find you no longer need mnemonics and acronyms. Maybe you'll need only a place to record clearances and amendments. ---JRC--- "Doug" wrote in message om... For approaches I use WestCoastRailRoad Weather, Clearance, Radios, and Review. I'll admit its a bit short of being exhaustive. I also have an IFR checklist in the plane for takeoff, cruise, arrival and approach phases. It IS exhaustive. As for my clearance, everything goes into a radio or instrument. Frequecies go into the radios, altitudes go into the altitude bug and headings go into the heading bug and waypoints go into the GPS. Not a bad idea to write them down also, but so long as my radios work, I can always ask. The reality is I just keep a 4 1/4" x 5 1/2" (half) pad of paper and a few pens in the plane and write down what I need on that. One of the things I do have is a business card sized flight plan form, I use it all the time so I have all the info to give flight service. All I really need to jot down is my takeoff time and enroute time that I gave him when I filed (well, ok, my destination, but I usually do know that). Works great and I dont have to bring any paperwork into the FBO, just my wallet, which I always have. It all depends on how exhaustive and organized YOU want to be. Do you want to emulate the airlines, or just fly around with minimum hassle? Or somewhere in between? I only file IFR if I need to, to get where I am going. Some file IFR all the time. So my suggestion, memorize an anacronym, get several 1/2 size notepads, some pens or pencils, and business card flight plan form, and you have the minimum necessary. -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
The perfect approach | Capt.Doug | Home Built | 25 | December 3rd 04 03:37 AM |
DME req'd on ILS (not ILS-DME) approach? | Don Faulkner | Instrument Flight Rules | 13 | October 7th 03 03:54 AM |
Terminology of New WAAS, VNAV, LPV approach types | Tarver Engineering | Instrument Flight Rules | 2 | August 5th 03 03:50 AM |
IR checkride story! | Guy Elden Jr. | Instrument Flight Rules | 16 | August 1st 03 09:03 PM |
CAT II Minimums on a CAT I Approach | Giwi | Instrument Flight Rules | 11 | July 24th 03 07:46 AM |
