#21
How do you "overspool" a rocket engine?
Mike MU-2 "tony roberts" wrote in message news:nospam-33EADD.23165714072005@shawnews... The tanks contain hydrogen and oxygen. A combination of the two power it. If it runs out of either, it can blow, or overspool the engine - either would be fatal. So it needs accurate fuel sensors - unless you want to fly it. Crew safety is paramount - and right now it's compromised. Tony C-GICE In article , "Granite" wrote: Discovery can't take off because of a bad fuel sensor ? Are they kidding us ? The crew is already strapped in, number one for departure, cocked and loaded. We just put gas in the thing. I saw the line guys top the tanks earlier in the day. Stick the tank, placard the gas gauge inop and let's go haul the mail ! Now it takes three or four days to replace it ? They need to find a new A&P, preferably non-union. We are never going to get commercial space travel at this rate. I'm sure the FAA is to blame too ... somehow. -- Tony Roberts PP-ASEL VFR OTT Night Cessna 172H C-GICE |
The SSME (like all modern, high performance rocket engines) is a big
turbopump. Big turbines, run from the same fuel source as is being ignited for use as a rocket. If the turbine is cranking away at full power and the source of fuel suddenly goes dry, then all that power being put into maintaining revs suddenly gets put into turbine speed. Depending on if you're lucky or not, the engine will detect this and shut off the turbine before it goes dry or before it overspeeds destructively. I wonder if these low-fuel sensors are part of the system that shuts down the SSMEs if there's a fuel starvation issue. I remember a mission a few years back where MECO (main engine cut-off) was unexpectedly a few seconds early because of higher then projected fuel burn or something. Not enough to really impact the mission, but it showed the safety systems that prevent dry-running SSMEs was working. Ben Hallert PP-ASEL and space nut |
My recollection was that the turbopump used the engery in the expanding fuel
to pump the fuel. If the fuel runs out doesn't the turbopump stop pumping? Mike MU-2 "Ben Hallert" wrote in message oups.com... The SSME (like all modern, high performance rocket engines) is a big turbopump. Big turbines, run from the same fuel source as is being ignited for use as a rocket. If the turbine is cranking away at full power and the source of fuel suddenly goes dry, then all that power being put into maintaining revs suddenly gets put into turbine speed. Depending on if you're lucky or not, the engine will detect this and shut off the turbine before it goes dry or before it overspeeds destructively. I wonder if these low-fuel sensors are part of the system that shuts down the SSMEs if there's a fuel starvation issue. I remember a mission a few years back where MECO (main engine cut-off) was unexpectedly a few seconds early because of higher then projected fuel burn or something. Not enough to really impact the mission, but it showed the safety systems that prevent dry-running SSMEs was working. Ben Hallert PP-ASEL and space nut |
ALL RIGHT!!!
John I was wondering when someone would give the right reason! You have won the prize my friend! ![]() proper time. If these little buggers go bad, well it would be possible to run out of fuel before getting into outer space...that would not be good. I think you did a good job of explaining it. Patrick student SPL aircraft structural mech I stayed in a Holiday Inn last night, ok ok and old friend is a electrical engineer on the space shuttle ![]() "John" wrote in message ups.com... The simple answer is that the sensors are used to shut the engines down before fuel exhaustion. The Space Shuttle Main Engine uses turbopumps (that also burn liquid hydrogen and liquid oxygen) to pump sufficient quantities of propellents to make it all go. The issue is that turbopumps behave very badly, even destroying themselves if they are run try, especially if at full power. It is apparently the nature of the beasts. The sensors cue systems that begin to throttle the engines back to about 65% power at which point the SSME can be shut down safely and without damage. Consider visiting the Science Space Shuttle News Group. Several people asked the same question and the issue gets explained pretty clearly. Someone noted that their car's fuel pump had a similar feature so to protect it from burning itself out from running dry. Just like us, the astronauts do not have the option of pulling the silly thing over to the side of the road if something important decides to break. blue skies to you all John |
tony roberts wrote in
news:nospam-33EADD.23165714072005@shawnews: The tanks contain hydrogen and oxygen. A combination of the two power it. If it runs out of either, it can blow, or overspool the engine - either would be fatal. So it needs accurate fuel sensors - unless you want to fly it. Crew safety is paramount - and right now it's compromised. Tony C-GICE In article , "Granite" wrote: Discovery can't take off because of a bad fuel sensor ? Are they kidding us ? The crew is already strapped in, number one for departure, cocked and loaded. We just put gas in the thing. I saw the line guys top the tanks earlier in the day. Stick the tank, placard the gas gauge inop and let's go haul the mail ! Now it takes three or four days to replace it ? They need to find a new A&P, preferably non-union. We are never going to get commercial space travel at this rate. I'm sure the FAA is to blame too ... somehow. But the regs say it only has to be accurate when empty! |
Backwards, the exhaust of the turbopump is fed into the engine bell,
where the expansion takes place. You may be thinking of a turbo in a piston engine, which runs parasitically off the exhaust. The pump has to start before the fuel to get the fuel into the pump, right? Chicken/Egg thing, there won't be any combustion in the chamber without fuel being pumped into it. Ben Hallert PP-ASEL |
![]() My recollection was that the turbopump used the engery in the expanding fuel to pump the fuel. If the fuel runs out doesn't the turbopump stop pumping? Mike MU-2 There are a number of differnet ways that turbopumps on rockets can be powered, what you are describing is an expander cycle, the SSME is a staged combustion pump. The pump is preburinign some small amount of fule to spin the turbine, if I recall it's about 150,000 HP per pump per engine. This is a lot of power. |
#28
I enjoyed the initial post in the original thread, taking it in the
spirit of a moderately clever kind of aviation-related standup comedy routine. And certainly no one has any desire to see the current Shuttle program be terminated at the cost of, or as the result above, one more set of crew fatalities. But the bottom line here is surely that the whole manned space flight effort and focus at NASA not only should be terminated as fast as possible, but should have been terminated several decades ago, for at least two major reasons. First of all, manned space flight at this point in time is just too difficult, dangerous, and expensive to be worth pursuing. It's a matter of the laws of physics versus the currently available or currently foreseeable level of technology, not the competence or the culture of NASA. Maybe some future breakthrough in technology will make manned space flight a much more reasonable goal; maybe not. But by far the more compelling reason is that there are really zero useful things, much less compelling needs, that we can or might want to accomplish in space that are not better done with unmanned rather than manned missions. Something like two-thirds of NASA's budget for the past several decades has gone into manned space flight efforts. Yet, essentially ALL of the useful scientific and technological accomplishments in space to date -- space probes, planetary missions, space observatories, communications satellites, gps systems, earth and environmental observatories, surveillance satellites -- have come totally from UNmanned satellites; and essentially ZERO significant results have come from manned space flights. Think about it: If you go into any moderately well equipped research or manufacturing facility of any kind in any field these days, you don't find scientists and technicians standing there turning knobs, watching meters, and writing results in lab notebooks. You find instead either highly automated, computer-controlled instruments and sample manipulation equipment, along with similar observation, measurement, or manufacturing apparatus, sitting there taking data, manipulating samples, or modifying things, in many cases 24/7, while feeding data and results back to hard disks and computers outside the lab, with maybe occasional reprogramming from a scientist or tech at a keyboard in their office or elsewhere outside the lab. If you want to measure or observe or do anything in space, you put the measurement and observation hardware in space, and keep the scientists and engineers in shirt-sleeve comfort and safety on the ground -- and you do this not just as as a matter of cost and safety, although these are compelling reasons, but also because the observational and recording capabilities of hardware these days far exceed the observational capabilities of humans in any case. Finally, just for the record, none of the above is to say we should not have done the Apollo Project as we did it when we did it. That was a much different era; Apollo was a proud and admirable accomplishment; it was worth doing. But now that we've come to understand a lot better what we really can do and want to do in space using unmanned missions, and how unbelievably much more it costs and how little we can really accomplish with manned missions, we've just got to get over this astronaut hero worship phase and start using our space efforts and resources much more intelligently. |
#29
have done the Apollo Project as we did it when we did it. That was a much different era; Apollo was a proud and admirable accomplishment; it was worth doing. Why? Earlier on you said First of all, manned space flight at this point in time is just too difficult, dangerous, and expensive to be worth pursuing. Well, it was even more difficult, dangerous, and expensive in the Apollo days. Most of your post seems to be that we should wait until space travel is easy, safe, and cheap before we pursue it. You complain that manned space research isn't impersonal enough (comparing it with manufacturing facilities on earth), but then you single out the Apollo program as being "a proud and admirable accomplishment" that was "worth doing". What's the difference? I would posit the opposite. Manned space travel isn't bold, daring, and audacious enough to capture our imagination and inspire mankind to do better than blow up people who hold the wrong opinions. The space shuttle has been, as NASA wanted it to be, "just a truck". Using the shuttle to replace rockets was an error given the lack of anything better than chemical rocket engines to power it. Instead we should have (and should now) use expendable rockets to put stuff into orbit, and a space station based fleet of mini-shuttles to do stuff with them once the heavy lifting is done. Another fleet of mini-shuttles would be used to carry people up and down - they would be the size of a lear jet and have enough payload capability for six people and little else. But the focus of our space program should be going to Mars and onward. Because it's there. Jose -- Nothing takes longer than a shortcut. for Email, make the obvious change in the address. |
#30
![]() "Jose" wrote in message m... better than chemical rocket engines to power it. Instead we should have (and should now) use expendable rockets to put stuff into orbit, and a space station based fleet of mini-shuttles to do stuff with them once the heavy lifting is done. Another fleet of mini-shuttles would be used to carry people up and down - they would be the size of a lear jet and have enough payload capability for six people and little else. But the focus of our space program should be going to Mars and onward. Because it's there. Jose Funny you should say that. There is a company in Oklahoma that plans on taking a stripped Lear 25 fuselage, bolting it to a basic wing, adding turbofan engines and a re-useable rocket engine. Take-off and climb to 30,000 feet of the turbofans, light the rocket and climb to 158,000 feet, then coast to about 330,000 feet before gliding back to earth. All in a half hour flight. www.rocketplane.com Allen |
Time, running out of fuel and fuel gauges | Dylan Smith | Piloting | 29 | February 3rd 08 07:04 PM |
fuel leak or auxiliary fuel pump malfunction? | [email protected] | Owning | 7 | December 17th 06 12:57 PM |
Replacing fuel cut-off valve with non-a/c part??? | Michael Horowitz | Owning | 46 | January 15th 05 10:20 PM |
Is Your Airplane Susceptible To Mis Fu eling? A Simple Test For Fuel Contamination. | Nathan Young | Piloting | 4 | June 14th 04 06:13 PM |
Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 02:57 AM |
