#21
Orval Fairbairn wrote:
In article , Smitty wrote: When I get to my panel, which isn't going to be soon, I'll probably do it on the mill. But for those who don't have access to a machine shop, I wonder why you're talking about hole saws and fly cutters. Don't the Greenlee type punches work pretty well? You only need a small pilot hole and a couple of wrenches. I much prefer the fly cutter, as the Greenlee punches take a lot of torque and may leave the panel warped in places. It depends on how sharp the punch is, how thin the metal is and how close it is to another opening or edge. You can also use them with the panel insalled in the aircraft. If you turn the fly cutter slow enough and use a good aluminum cutting fluid, it works well and safely. I would also add the fly cutter MUST be sharp and not fed too fast. If I were going to start a new instrument panel from scratch I would take a sheet of 1/2" plywood and bolt the panel blank (cut oversize) to it. I would use a few of the instrument mounting screw holes as well as holes along the perimeter of the blank. I would use a fly cutter to cut the holes. When finished I would cut the panel to size. This would reduce chatter and make clamping of the entire set up easier. Dan, U.S. Air Force, retired |
clamped, the drill press, or mill is running very slow, and you use a
good cutting lubricant. One of the best lubes for cutting aluminum is WD-40. I've heard ATF works well too, but I've never tried it. |
On Thu, 14 Jul 2005 20:49:54 -0500, "Dan, U.S. Air Force, retired"
wrote: Orval Fairbairn wrote: In article , Smitty wrote: When I get to my panel, which isn't going to be soon, I'll probably do it on the mill. But for those who don't have access to a machine shop, I wonder why you're talking about hole saws and fly cutters. Don't the Greenlee type punches work pretty well? You only need a small pilot hole and a couple of wrenches. I much prefer the fly cutter, as the Greenlee punches take a lot of torque and may leave the panel warped in places. It depends on how sharp the punch is, how thin the metal is and how close it is to another opening or edge. You can also use them with the panel insalled in the aircraft. If you turn the fly cutter slow enough and use a good aluminum cutting fluid, it works well and safely. I would also add the fly cutter MUST be sharp and not fed too fast. If I were going to start a new instrument panel from scratch I would take a sheet of 1/2" plywood and bolt the panel blank (cut oversize) to A very good suggestion. I keep partial sheets of 1/2" and 3/4" around for for backing and never even thought to mention using it. That's what I get for typing at near 3:30 AM. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com it. I would use a few of the instrument mounting screw holes as well as holes along the perimeter of the blank. I would use a fly cutter to cut the holes. When finished I would cut the panel to size. This would reduce chatter and make clamping of the entire set up easier. Dan, U.S. Air Force, retired |
Are All Batteries Created Equal? (Does Size Matter?) | [email protected] | Soaring | 4 | July 17th 05 02:04 PM |
DIGGING A DEEPER HOLE | Cribsheet | Piloting | 3 | December 10th 04 12:00 AM |
Oil Temperature sending unit | Corky Scott | Home Built | 2 | October 19th 04 12:58 AM |
Finding vent hole in wing skin | Martin Eiler | Soaring | 7 | November 21st 03 01:44 PM |
Fairing question... | Tina Marie | Home Built | 5 | July 16th 03 12:18 AM |
