#11
"Michael" wrote in message oups.com... The extra vibration occurs only if you don't have proper fuel distribution LOP I have never seen an engine, GAMI equipped or otherwise, that was as smooth LOP as it was ROP - and I've seen a lot of them. I'll give you a ride in mine. Not only as smooth, but temps, pressures, carbon deposits, etc. are all MUCH better. -- Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO |
You have to consider the smaller operating range when running LOP. Small
changes in altitude, temperature, or pressure will wider fluctuations in temperature when running LOP as opposed to ROP. We would all like to think we keep the engine perfectly leaned, but over the 2000 hours on a typical engine, how many times does the average pilot let the temperature drift a little before catching it. How long at 25 or 15 LOP before you shorten the engine life. I change altitudes a lot, and tend to fly high when weather permits. I also have a turbo arrow with a very sensitive throttle that needs to be adjusted continuously during climbs and decent. I don't need the aggravation of having to adjust the mixture 3 times as much because I was LOP. I know during the 2000 hours I would eventually get distracted in busy airspace, and end up running too close to peek during a cruise climb. "Michael" wrote in message oups.com... So much depends on quality information about proper engine operations, yet there appears to be little science behind the assertions. You are quite correct - there is very little science here. There is certainly a lack of solid statistical evidence. In this situation, you pretty much have to work from engineering first principles. Let's start from what is scientifically defensible: Operating 50 degrees LOP vs 50 degrees ROP (which is what many manufacturers recommend) means that: The engine runs slightly rougher. Extra vibration. The peak pressures in the cylinder (and thus transmitted to the crankshaft) are lower. Less stress on crankshaft, bearings, etc. That's about it. Everything else is rumor, conjecture, and guesswork. The slightly rougher running may in the end reduce the life of the engine more - or less - than the higher peak pressures in the cylinders. Oops, I guess we're done until an actual controlled study shows us which factor is more important. Michael |
"O. Sami Saydjari" wrote in message ... Yes, exactly. -Sami Doug wrote: I have often thought that what is needed is a scientific study of what works best in aircraft engines. Get a statistically signifigant number of engines. Rebuild them. Put monitoring equipment in the aircraft. Instruct each owner of the aircraft to run the engine in specific ways. Numerous groups of engines being run different ways. Oil selection, oil change frequency, leaness, shock cooling etc could all be studied. After 2000 hours of running one would have a pretty good idea of cause and effect. Between the known physics of combustion, the test stand that GAMI has been operating for several years, the engineering data the P&W and the airlines generated for a couple decades of operating the radials...I don't think these folks really want scientific data. |
"bill hunter" wrote in message ... You have to consider the smaller operating range when running LOP. Small changes in altitude, temperature, or pressure will wider fluctuations in temperature when running LOP as opposed to ROP. We would all like to think we keep the engine perfectly leaned, but over the 2000 hours on a typical engine, how many times does the average pilot let the temperature drift a little before catching it. How long at 25 or 15 LOP before you shorten the engine life. Well, I hope you've kept adequate re$erve$ for a top overhaul in addition to your early MOH. |
"O. Sami Saydjari" wrote in message ... This is actually a split off from the "Rotating Injectors Among Cylinders" thread. I prefer not to distract that thread any. I must say that I find the evidence presented in support on LOP to be uncompelling. The exiting data is not only compelling, it's pretty much overwhelming. Although it is certainly appealing at the gut level, it is a far cry from scientific evidence that LOP operations is better for the engine and will lead to longer TBOs. You need to learn to integrate information. But why would anyone want to kick in a load of $$$ when Old Wives Tales are so "compelling". Not only is there no known data to support these OWT's, by the time people finally quit sitting on their brains and assimilate the new learning, we'll probably be using mico-nuclear engines. From geocentric, flat earth, and a host of other "knowledge bases", I guess ROP/LOP is just another notch in human nature. I suspect what's wanted here is not scientifc data, but excuses. -- Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO |
"Paul kgyy" wrote in message oups.com... The extra vibration occurs only if you don't have proper fuel distribution LOP. Admittedly, this is normal for carburetion and common for fuel injection, but that's the point of using GAMI injectors. http://www.avweb.com/news/reviews/182558-1.html ----------------------- These subjective reports were confirmed recently when Chadwick-Helmuth spent several days running tests on a 1993 Beech F33A instrumented with one of C-H's latest state-of-the-art vibration analyzers hooked to multiple accelerometers and vibration transducers. Tests were flown at a wide range of power settings and mixtures using a set of standard TCM nozzles, then repeated after GAMIjectors were installed. The results indicated that the GAMIjectors reduced vibration levels at the 2nd order frequency and at the low 1/3rd order frequency by 60% to 80%. ================================================== ================ |
I'm glad you feel that way. Those of us who are actually qualified practicing engineers do not concur. Michael |
"Michael" wrote in message ups.com... The exiting data is not only compelling, it's pretty much overwhelming. I'm glad you feel that way. Those of us who are actually qualified practicing engineers do not concur. In what field of engineering? |
"Michael" wrote in message ups.com... The exiting data is not only compelling, it's pretty much overwhelming. I'm glad you feel that way. Those of us who are actually qualified practicing engineers do not concur. Why? Be specific and technical. -- Matt |
Where is your long-term field study comparing LOP and ROP operations? How many engines have been monitored in service from start to overhaul, under what conditions, and for how long? Have you shown a statistically significant difference in MTBF, service life, or cost of maintenance? That's really the only way to cover all bases. Sometimes this is not practical, but lacking a long term field study, you at least need a reasonable model. A compelling model would address the following issues, as a minimum: What are your parameters to asess engine roughness in normal LOP and ROP operations? How do you model the imperfections caused by pilot technique? Do you have amplitude and frequency data on engine vibration at various mixture settings? What kind of sensors did you use? Do you have long term operational data or at least a model showing the long term behaviour of the engine mounts, bearings, cases, crankshaft, etc. under the vibration conditions? Without long-term operational data, I would expect at least an FEA. Do you have any information at all on the differences in combustion end-products in excess-air vs. excess-fuel combustion reactions? I can assure you they are differrent. Are any of the combustion products harmful to the engine components long-term? Do any pose corrosion issues when the aircraft is not flown for several days or weeks, as commonly happens with private planes? How about that big mixture pull - it takes the mixture through peak. What is the effect of this transition on the crankshaft? Some analysis of this issue was done in the 1940's, using the limited available tools - but only for radial engines, which have significantly different crankshaft designs. For that matter, about the only large base of operational data in the LOP regime comes from radial engines - which are different - using 1940's and 1950's fuels which were significantly different than what you're burning now. I'm sure given time I could think of other issues. The main arguments for LOP operation are short-term economic ones - less plug fouling, lower fuel burn. These are pretty compelling. As for effect on TBO and general engine longevity, there has been much hype and no compelling evidence. BTW - to answer your other question - I run the R&D group for a major manufacturer of industrial instrumentation. So yes, this is pretty much right up my alley. Michael |
| Thread Tools | |
| Display Modes | |
| Looking for JPI's older software to download engine monitor data to a PC | Peter R. | Piloting | 11 | February 14th 05 09:58 PM |
| ROP masking of engine problems | Roger Long | Owning | 4 | September 27th 04 08:36 PM |
| more radial fans like fw190? | jt | Military Aviation | 51 | August 28th 04 05:22 AM |
| French block airlift of British troops to Basra | Michael Petukhov | Military Aviation | 202 | October 24th 03 07:48 PM |
| Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 05:29 AM |
