More KAP 140 questions
Old October 23rd 03, 08:09 PM
Peter R.
Peter R. ) wrote:
However, knowing the old reliable equipment cannot be ignored either. I
learned this last year when I and a copilot were flying to Boston in IMC.
This should have read last summer, not last year. I only received my
instrument rating in March of this year.
Last summer does seem like a long time ago already.
Peter
----== Posted via Newsfeed.Com - Unlimited-Uncensored-Secure Usenet News==----
http://www.newsfeed.com The #1 Newsgroup Service in the World! 100,000 Newsgroups
---= 19 East/West-Coast Specialized Servers - Total Privacy via Encryption =---
  #32
Old October 23rd 03, 08:33 PM
Ron Natalie
"Peter R." wrote in message ...
Mostly I do, but I also like to keep current from a FAR standpoint.
Sometimes I purposely will navigate with VORs to remain current as per the
instrument currency requirements,
There's no instrument currency requirements that say you have to use the VOR.
It says intercepting and tracking courses using navigation systems.
  #33
Old October 23rd 03, 08:55 PM
Craig Prouse
instrument currency requirements, as wells as to maintain proficiency with
VOR navigation.
Ah yes, but 61.57(c)(1)(iii) only requires that you "intercept and track
courses through the use of navigation systems." It doesn't specify that you
have to be current on VOR navigation systems.
Since GPS is not approved for "sole means," I of course do my 30-day VOR
receiver checks. That's perhaps the main use of my NAV/GPS button, since I
don't get to fly an ILS every 30 days.
Although I don't agree with leaving out the departing airport (in the event
one needs to get back to it quickly in IMC), I now see the value of putting
in those extra waypoints that show the entire first airway, rather than
having the first waypoint my first (usually VOR) waypoint en route.
I would never leave out my departing airport. Best of both worlds. I
commonly depart SE from here after joining V107. The local segment of V107
is defined by OAK and PXN VORs. There is an intersection on V107 called
VINCO. Even though OAK is several miles north of here and my departure
takes me immediately south and east, I program my route as:
KPAO OAK VINCO PXN ...
The clearance is always:
Turn right heading 060° radar vectors ...
I simply ignore the fact that the GPS is telling me to fly to OAK, and fly
my assigned vectors. As I get oriented near V107, which is already
depicted, the GPS automatically sequences and makes VINCO my next active
waypoint. The reason I have to put VINCO in there is not because of a bend
in the airway, but because sometimes the clearance will morph into "direct
VINCO when able, resume own navigation." If I fly across V107, I fly into
the side of a mountain, so it's important that I not be screwing around
trying to dial in all the letters in VINCO right then. You can bet that
when it's IMC, I have that airway dialed in, identified, and displayed on
NAV2, so I won't miss the turn.
Yes. But don't forget those free opportunities to track a few VOR radials
for currency during those routine flights.
Once a year, I fly the Hayward Air Race, where GPS units and (even DME) are
disabled and impounded, and we fly a rigorous navigational exercise down the
Central Valley of California and across the Mojave Desert to Bullhead City
AZ, by pilotage and VOR navigation only.
It's great practice because you're trying to find sometimes obscure little
landmarks at the turn points, and you need to be low to see them, so service
volume becomes a consideration in flight planning.
  #34
Old October 24th 03, 02:48 PM
Peter R.
Yep, my mistake. Without an ADF, I have no choice but to practice VOR
navigation.
What other forms of navigation meet these regulations?
Peter
  #35
Old October 24th 03, 02:53 PM
Peter R.
Now that sounds like a blast! I definitely need to expand my aviation
horizons.
Peter
  #36
Old October 24th 03, 07:39 PM
Everett M. Greene
Peter R. writes:
horizons.
Navigation: head south keeping mountains to your left and
right until mountains also ahead. Identify Bakersfield and
turn left to follow Cal58 to Barstow. Proceed east until
Colorado River identified. Find Bullhead City. Stay low
east of Techachapi to avoid high-speed kerosene burners
(who may be lower than you -- ever seen an F-16 at 100
feet, inverted?).
  #37
Old October 25th 03, 05:20 AM
EDR
This is not an approved use of the GPS equipment. VOR approaches are
supposed to be flown using actual VOR course guidance, or as a GPS overlay
approach. The latter must be loaded from the database because there are
operational consequences when you do it that way. Substitution of GPS for
ground-based navaids in the approach phase is limited to DME and ADF.
On the KLN 94, if you do not keep the database updated, the box will
not allow you to select any approaches from the database.
  #38
Old October 25th 03, 01:34 PM
Teacherjh
So what do you do in an emergency if you need an approach from the box?
Jose
  #39
Old October 25th 03, 03:17 PM
Greg Esres
That maybe software configurable. Our schools DBs are now kept
up-to-date, but they didn't used to be, and I don't remember ever not
being able to select an approach.
  #40
Old October 26th 03, 01:42 AM
EDR
In article , Teacherjh
That's what paper is for. You do carry current approach plates and
enroute charts, don't you?
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 2nd 04 11:41 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 09:02 PM
