spoilers vs. ailerons
Old July 26th 05, 09:12 PM
Right, but the B52 also has gear that can be aligned with the runway so
it lands in a crab. I'm asking if there's a different method for xwind
landings for conventionally gearly acft with spoilers. Maybe I didn't
phrase the question clearly enough... Mike R whaddya think?
Old July 26th 05, 09:59 PM
Peter Duniho
"Ron Natalie" wrote in message
m...
OK, but if spoilers "spoil" lift over the wing isn't that an
undesirable condition when low & slow such as a crosswind landing where
the upwind wing is dropped?
What do you think an aileron does in the same situation?
The difference is one of degree, as well as of mechanism.
To address the previous question...
For a given roll rate, a certain amount of force needs to be applied.
Ailerons provide this force in a balanced way, by increasing the angle of
attack on one wing and reducing it on the other. A spoiler, rather than
reducing the angle of attack, simply disrupts the airflow and reducing lift.
So, compared to ailerons, the spoiler is more like using only a single
aileron on the opposite wing to induce the roll (which would put that wing
closer to the stalling angle of attack).
Of course, that all ignores a bunch of other aspects of the situation.
Ailerons, even as they increase the angle of attack, also change the shape
of the wing, which can change the stalling angle of attack. Also, many
ailerons are configured for asymmetric deployment, to help reduce adverse
yaw; the aileron on the down-going wing is deflected more than the aileron
on the up-going wing.
Another element that is actually in favor of spoilers (the previously
mentioned ones are, IMHO, pro-aileron) is that if for some reason deployment
of the spoiler should cause a stall, all that will happen is that the wing
going down will go down faster. The pilot's instinctive response will be
just fine, as reducing or reversing aileron input will simply restow the
spoiler, allowing that wing to generate the required lift again. Contrast
that to slow flight with an aileron, in which not only does the wing stall
induced by aileron input cause a reversal of the rolling moment, but the
pilot's natural reaction would be exactly opposite that required.
Of course, being able to put full-span flaps on a wing also helps compensate
for any potential risk of a stall due to roll control input. It seems
likely to me that, given the situations in which spoilers are often found
for roll control, it's a net gain for the spoilers.
One should not forget that in reality, at typical approach speeds (even
those required for a short-field approach), one ought not to be close enough
to risking a wing stall due to roll control input, whether it's spoilers or
ailerons that are being used. Obviously, spoilers work "well enough" and in
fact in many cases may be a superior solution to ailerons.
Pete
Old July 27th 05, 12:19 AM
Matt Whiting
Mike Rapoport wrote:
Spoilers function the same as ailerons at low angles of attack and better
than ailerons at high angle of attack. The primary advantage of spoilers
instead of ailerons is that it enables full span flaps. Spoilers also
reduce or eliminate adverse yaw.
I assume there must be some disadvantages of spoilers for roll control
as you see them so rarely. What are the drawbacks? Cost??
Matt
Old July 27th 05, 05:52 AM
Mike Rapoport
"Darrell S" wrote in message
news:BavFe.49931$4o.24620@fed1read06...
.. With a spoiler controlled aircraft, when
you stall the wings it makes the spoiler ineffective. It can no longer
spoil lift that is no longer there. --
Darrell R. Schmidt
B-58 Hustler History:
http://members.cox.net/dschmidt1/
This isn't true. Spoilers provide effective roll control even on a stalled
wing while ailerons do not. lift does not disappear when the wing stalls.
Mike
MU-2
Old July 27th 05, 05:54 AM
Mike Rapoport
You guys are overthinking this. Aircraft with spoilers have *better* low
speed roll control than those with ailerons.
Mike
MU-2
Old July 27th 05, 06:01 AM
Mike Rapoport
I think that the main disadvantage is probably cost and perhaps complexity
or weight, I really don't know. Many jets use spoilers as their primary
roll control. Guys are overthinking this one. If spoilers were really
different then a type rating would be required on a MU-2 and if they were a
problem at low speed they wouldn't be used on a Helio.
Mike
MU-2
"Matt Whiting" wrote in message
spoilers instead of ailerons is that it enables full span flaps.
Spoilers also reduce or eliminate adverse yaw.
I assume there must be some disadvantages of spoilers for roll control as
Matt
Old July 27th 05, 04:58 PM
Why not just land across the runway.
Why indeed? Just fly off a carrier... those Navy guys never have to
deal with crosswinds when flying off the boat Hmmphh... What's so
darn hard about grabbing a three-wire anyway? : )
Old July 27th 05, 05:26 PM
Mike Rapoport
Actually with it large vertical stabilizer and relatively small rudder, the
Helio has fairly poor crosswind performance. Most experienced Helio pilots
compensate for this by landing diagonally across the runway
Mike
MU-2
Old July 28th 05, 01:14 AM
Darrell S
longer spoil lift that is no longer there. --
Darrell R. Schmidt
stalled wing while ailerons do not. lift does not disappear when the
wing stalls.
Mike
MU-2
Not so, Mike. Spoilers spoil lift. You can't spoil lift that ain't there
as in a stalled wing.
Darrell R. Schmidt
B-58 Hustler History: http://members.cox.net/dschmidt1/
Old July 28th 05, 03:13 AM
Skywise
"Darrell S" wrote in news:NrVFe.51930$4o.23949@fed1read06:
Darrell R. Schmidt
wing stalls.
Mike
MU-2
But is not the definition of a stalled wing one that is
producing less lift than necessary to maintain flight?
That seemed to be quite a topic not too long ago re spins.
Brian
http://www.skywise711.com - Lasers, Seismology, Astronomy, Skepticism
Seismic FAQ: http://www.skywise711.com/SeismicFAQ/SeismicFAQ.html
Blog: http://www.skywise711.com/Blog
Sed quis custodiet ipsos Custodes?
Ailerons needed for Schweizer 1-23 noel56z Soaring 2 May 5th 05 06:48 PM
Frise ailerons on sailplanes Mark James Boyd Soaring 24 February 25th 05 09:43 PM
Flaperons Lou Parker Home Built 26 November 15th 04 04:40 AM
American Eaglet George Vranek Soaring 4 March 11th 04 01:17 AM
L-13 Spoilers Scott Soaring 2 August 27th 03 06:08 AM
