I need to replace the aluminum wiring in my Archer with new copper cables.
Spruce is selling Bogart replacement cables for $289 which seems a bit steep for the amount of cable and connectors involved. I understand Piper has a description of the parts and technique for doing the replacement, but my service manual doesn't seem to mention it and I haven't found the SB or a description of the procedure on-line. Any suggestions are appreciated. Best Regards, Mike. |
Mike,
Try American Aviation, 405-354-7136 or 404-232-2607. They have STC'd kits for PA-28s for $115/2 ga and $145/1 ga. I used the 2ga kit in my PA-28-140 and had no problems in either the install or performance. Mike Bednarek "Mike Noel" wrote in message ... I need to replace the aluminum wiring in my Archer with new copper cables. Spruce is selling Bogart replacement cables for $289 which seems a bit steep for the amount of cable and connectors involved. I understand Piper has a description of the parts and technique for doing the replacement, but my service manual doesn't seem to mention it and I haven't found the SB or a description of the procedure on-line. Any suggestions are appreciated. Best Regards, Mike. |
Why does wire replacement have to have an STC?
************************************************** ********* Changes the weight and balance of the airframe... denny |
Denny wrote:
: Why does wire replacement have to have an STC? : ************************************************** ********* : Changes the weight and balance of the airframe... I was thinking that, but I thought that there were situations where empty W&B change didn't require a 337. Now that I read through it, I can see the interpretation differently. One example that comes to mind is installing a lightweight starter. It's got a PMA, so it's a drop-in replacement for the original. It also takes 9 lbs off the nose (of my bird at least), so it requires a W&B. All I can say is that if you cannot get your local FSDO to approve a 337 for replacing Al wires with Cu wires according to AC43 and a W&B change, it's time to send them some hate mail and/or move. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
"Mike Noel" wrote in message ... I need to replace the aluminum wiring in my Archer with new copper cables. Spruce is selling Bogart replacement cables for $289 which seems a bit steep for the amount of cable and connectors involved. I understand Piper has a description of the parts and technique for doing the replacement, but my service manual doesn't seem to mention it and I haven't found the SB or a description of the procedure on-line. Any suggestions are appreciated. My service manual (page 4D1) states that the #1 aluminum wire can be replaced by #3 copper by following procedures in 43-13. No STC or kit needed, just get some wire and terminals and do it by the book. |
Cory,
Yes, you can replace the cables on your own (via FAA Mechanic) using all the appropriate materials (cable, connector's, etc.) without an STC. However, my understanding is that the STC was obtained to allow them to manufacture and sell the complete kit (with all the connector already assembled). Mike wrote in message ... wrote: : Mike, : Try American Aviation, 405-354-7136 or 404-232-2607. They have STC'd : kits for PA-28s for $115/2 ga and $145/1 ga. I used the 2ga kit in my : PA-28-140 and had no problems in either the install or performance. : Mike Bednarek Why does wire replacement have to have an STC? I would think that replacing Al wires for Cu wires would fall under the normal AC43 guidelines. So long as the current capacity is within spec, wires are of proper type (insulation, etc), and ends are fabricated according to proper practices, it's simply preventative maintenance. What am I missing? Although for $115, it sounds like a pretty good deal.... I'd imagine 10-20 feet of #2 AWG aircraft wire is a pretty sizeable chunk of that cost, let-alone the aircraft lugs and crimpers to put them on. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
OK, thanks to all who replied. I ordered a 2 gauge kit from American
Aviation for $115. He's nice enough to send the STC PMA kit postpaid and trust me to send him the money on receipt. wrote in message news ![]() Mike, Try American Aviation, 405-354-7136 or 404-232-2607. They have STC'd kits for PA-28s for $115/2 ga and $145/1 ga. I used the 2ga kit in my PA-28-140 and had no problems in either the install or performance. Mike Bednarek "Mike Noel" wrote in message ... I need to replace the aluminum wiring in my Archer with new copper cables. Spruce is selling Bogart replacement cables for $289 which seems a bit steep for the amount of cable and connectors involved. I understand Piper has a description of the parts and technique for doing the replacement, but my service manual doesn't seem to mention it and I haven't found the SB or a description of the procedure on-line. Any suggestions are appreciated. Best Regards, Mike. |
| Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) | Striker Cat | General Aviation | 0 | October 12th 04 06:11 PM |
| Wire for homebuilts. | clare @ snyder.on .ca | Home Built | 9 | March 25th 04 06:51 PM |
| New Piper Aircraft Designations | EDR | Piloting | 8 | October 27th 03 02:18 PM |
| replacement rotating beacon for 64 piper cherokee | Patrick Mathews | Owning | 2 | October 1st 03 02:55 PM |
| The Piper Cubs That Weren't | Veeduber | Home Built | 5 | August 28th 03 05:38 AM |
