#11
Others have offered good advice and I'll throw in my 2 cents worth.
How many planes have you looked at? I was in a similar situation to yours when I was looking to buy an Ercoupe. I found a plane within 100 hours of TBO and the owner made only a modest accomodation for the high-time engine, starting from an optimistic estimate of the market value of the plane with a fresh engine. Bottom line, he wanted too much and wouldn't budge. Since it was one of the first planes I looked at, I walked away. Eventually I found a better plane with a much better engine at a lower price! There are indeed many airplanes out there. One trick I used to find my airplane was, first I decided on the model I wanted, then downloaded the FAA database and filtered it for owners of those models with zip codes within about 200 mile range of me. Then I wrote all the owners letters asking if they were interested in selling, emphasizing I was not a broker. This generated a number of quality replies, much better than looking in T.A.P. Good luck! |
On Fri, 29 Jul 2005 22:35:58 -0700, "DHead" wrote:
Hi group. I am interested in buying a Sundowner with 2035 TT E&A. The owner (actually the broker) offered to allow $5K off the asking price to have the engine O/H'd. I am a student pilot and very much want this particular airplane, but I don't think that $5K off a $14K O/H is reasonable. The avionics are ok, but could be improved on. My biggest concern at this point is the engine time. Any opinions on what is fair to me and the seller concerning allowances for the engine O/H? It depends on how the airplane is priced. If, in initially pricing the aircraft, the broker already took into account the fact that the engine was 2,000 SMOH, then an additional $5,000 discount is gravy to you. You need to appraise the value of the entire aircraft. Only then can you tell if the additional $5K discount is a good deal for you. AOPA has a service (for members) that allows this sort of appraisal. There is also the Blue Book as well as independent services. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
I would consider it an opportunity. If you like the plane,
and a thorough pre-buy inspection finds nothing wrong then use the TBO as a negotiating point. Personally, I would rather choose the person who rebuilds my engine rather trust someone who just wants to sell it. In any case, as long as the compressions are still okay you can still fly it beyond TBO. I would just make sure that my offer included an appropriate discount for a quality engine rebuild. |
I'd buy the airplane cheap and then do the overhaul myself.. then you know
what you have... not a cheap overhaul by the seller. Get an engine shop to tell you the overhaul cost, then add 50% for "unknowns". You don't know until it's opened up that the crank and case are good. O-540 Overhaul just completed, quoted $19000 with a good crank and case. Price dropped to $17500 because the cylinders were good. Price included mag overhaul, carb overhaul etc. Then we ended up spending $500 on a new starter and $500 on new hoses and clamps etc Price does not include the labor cost to remove and install the engine. BT "Bob Noel" wrote in message ... In article , "DHead" wrote: Hi group. I am interested in buying a Sundowner with 2035 TT E&A. The owner (actually the broker) offered to allow $5K off the asking price to have the engine O/H'd. I am a student pilot and very much want this particular airplane, but I don't think that $5K off a $14K O/H is reasonable. The avionics are ok, but could be improved on. My biggest concern at this point is the engine time. Any opinions on what is fair to me and the seller concerning allowances for the engine O/H? what is the asking price? what would be the asking price of the aircraft with a good overhaul? In general, it is always cheaper for the buyer to have the previous owner pay for things because a seller never seems to be able to recover 100% cost of repairs/improvements. However, be cautious of a cheapo overhaul. I'd recommend caution about buying an aircraft with a runout engine. Overhauling an engine can be a great learning experience, and can also be a lot of work, with lots of traps for the unwary. good luck -- Bob Noel no one likes an educated mule |
I agree with everything except that a Sundowner is difficult to land. I
think it is no more difficult to land than any other light single, but it does require a little more attention to speed. Keep your speed at 70 kts on final, and it's a piece of cake. Les "A Lieberman" wrote in message ... On Fri, 29 Jul 2005 22:35:58 -0700, DHead wrote: I am interested in buying a Sundowner with 2035 TT E&A. Hi Gary, I bought my 1976 Sundowner with 1940 TT on air and engine 4 years ago. What I learned..... Don't depend solely on compressions for evaluating a engine. I bought mine that had 76 to 78 on each cylinder. Thought that was great until an exhaust valve disintegrated in flight. So, keep in mind, there is a bottom half of the engine to consider. What you describe is a very underused plane. I learned this is just as bad, if not worse then buying an overused plane. You may ask why? Things corrode, grease settles and all sorts of nasty things happen to metal AND WIRES when it sits unattended for long periods of times. I bought mine for 38K. The owner originally asked for 44K, but I said no, too high based on high time engine. He came back about 1 month later and dropped it to 38K which I thought was fair enough. Bought the plane. Flew it for 50 hours and then the exhaust valve on the number 4 cylinder bit the dust. Got the cylinder replaced, and then another cylinder started acting up (luckily on the ground). I could not get it to pass the mag check, taxied back to the ramp, asked my A&P to yank the engine and overhaul it. 13.5K and a month later, I was a proud owner of a newly overhauled plane. Avionics. Mine was IFR capable, but was not current on the .411 and .413 transponder pitot static system check. You indicated you are a student, so this may not be important now, but it is nice to have it current. I had just got my VFR ticket and was going to transition to my IFR rating, so I figured, I would be saving a lot of money flying in my plane. (I probably saved about 5K in training expenses, so that paid for the remainder of the overhaul is the way I look at it. My radios are old and tired. I learned from my last pitot static check, the filters are going bad, and will need to be replaced. Because of the age of the radio, I was told, it probably will be time to look at new avionics. Sitting on the ramp is the worst thing one can do for the gauges. Lubrication settles, gauges get sticky and so on. So, evaluate how much was the plane used recently? I am now at a point, where I have every switch, button and knob working. (knock on wood!). It took me 3 years to get to this point, and it is expensive. A stupid power supply to strobe light cost $240 dollars. Not sure what you currently fly, but a Sundowner for creature comfort is by far better then a piper or a Cessna 172 or lower. Tons of room. Plan for 110 knots in your flight planning at 2300 rpm. I burn about 9.5 to 10 gph. In the three years I have owned my plane, I have flown at least once a week, so whoever gets my plane will have gotten a plane with some serious TLC. Note, a Sundowner is very difficult to learn to land. It is very nose heavy and you must fly it all the way down to the ground. You must stick to the POH numbers or you will float kingdomkong or drop like a brick. If you hold the speed to the numbers you will grease every landing. The elbow gear does amazing things for landings. The plane is built like a tank and flies like one, so don't expect to be a speed demon after wheels are up. The known porposing problems are true, as I have been there and done it. If you bounce on landing, don't salvage it, go around. Hope this helps! Allen |
I'll take an engine with 2500 since FREMAN before a 200 hrs since a "Dip &
Ship" overhaul anytime. "John Doe" wrote in message ink.net... I would walk away. There are thousands of planes for sale with plenty good lower time engines. "DHead" wrote in message ... Hi group. I am interested in buying a Sundowner with 2035 TT E&A. The owner (actually the broker) offered to allow $5K off the asking price to have the engine O/H'd. I am a student pilot and very much want this particular airplane, but I don't think that $5K off a $14K O/H is reasonable. The avionics are ok, but could be improved on. My biggest concern at this point is the engine time. Any opinions on what is fair to me and the seller concerning allowances for the engine O/H? Thanks in advance. Gary Future pilot without a plane |
I am interested in buying a Sundowner with 2035 TT E&A. The owner (actually the broker) offered to allow $5K off the asking price to have the engine O/H'd. I am a student pilot and very much want this particular airplane, but I don't think that $5K off a $14K O/H is reasonable. $5k allowance not enough? You are darned right it is not. Many owners think they can pass off a huge major repair on the next guy by quoting some ridiculous price and waiting for the right sucker. The sad thing is, they usually can. There are a lot more fools out there with money who don't know or don't care about the math. If the engine overhaul number is $14k, I would add another $5k for: muffler O/H. alternator O/H, starter O/H, fuel and oil hoses, scat tubing, etc. Also, have a mechanic look at the landing gear. I thought that others had posted something that the sundowners have some rather expensive cushions that give out with age. Rather than trying to talk some sense into this owner, I would pass and find a plane ready to go (with about 400 since overhaul). Here is the Catch-22: The more you are prepared to walk away and wait, the better your chances at getting a good plane. Junk is for sale every day and readily available. Decent small airplanes are much harder to find and usually take some time to locate. When they come around, it is a feeding frenzy to get at it. Success means being willing to pass on the dogs and possibly lose out on a couple of nice ones until your time comes. Good Luck, Mike |
The owner (actually the broker) offered to allow $5K off the asking price to have the engine O/H'd. I am a student pilot and very much want this particular airplane, but I don't think that $5K off a $14K O/H is reasonable. You are correct; $14K off a $14K O/H is the reasonable adjustment. You seem pretty knowledgeable, but this article can help. including explaining what TBO really represents. http://www.avweb.com/news/columns/187037-1.html /excerpt The Savvy Aviator #4: Debunking TBO April 14, 2004 By Mike Busch, Columnist Engine TBO (time between overhauls) seems to be one of the most misunderstood concepts in aviation maintenance. There are lots of TBO-related old wives tales that are widely believed by owners and mechanic alike, and they can cost owners a great deal of money. Mike Busch endeavors to clear up these misconceptions, and explain what TBO really means. Ask any aircraft owner what the TBO is for the engine(s) on his aircraft and you'll almost always get the correct answer without hesitation: "My engine has a 1,700-hour TBO." But ask that owner to explain the significance of that TBO figure and you'll get all sorts of answers, most of them flat wrong. Here are a few of the most common misapprehensions about TBO: "It's illegal to fly an airplane if the engine is past the TBO established by the manufacturer." Nonsense. The TBO figures published by Lycoming and TCM are not airworthiness limitations. An engine may be long past TBO and still be legally airworthy. (An engine may also become unairworthy long before reaching TBO.) /end excerpt I bought my plane with less than 40 hours until TBO because I wanted to do a complete makeover (TSIO-520 over to a TNIO-550) and got a very handsome deal (the previous owner, I think, thought TBO was hard cast legal number as in the OWT just mentioned) because of it. If an airplane has a 2000 hr TBO and it costs $14K for the overhaul (everything else not withstanding), the pro rata allowance then is $7 an hour. If this fellow you're dealing with is allowing $5k he is attempting to use the airplane and have you pay for it. Good luck, and welcome to the Beech owners group...an elite group, IIDSSM :~) -- Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO |
Mike Spera wrote: Ah Bull****. If the engine overhaul number is $14k, I would add another $5k for: muffler O/H. $400 for a new one. alternator O/H, $300. starter O/H, $250. fuel and oil hoses, $50 maybe for hoses, plus time. scat tubing, Hardly anything. |
In article , Newps
wrote: If the engine overhaul number is $14k, I would add another $5k for: muffler O/H. $400 for a new one. alternator O/H, $300. starter O/H, $250. fuel and oil hoses, $50 maybe for hoses, plus time. depends on the airplane. -- Bob Noel no one likes an educated mule |
| Thread Tools | |
| Display Modes | |
| Mooney Engine Problem in Flight - Advise | Paul Smedshammer | Owning | 17 | December 21st 04 07:39 AM |
| Mooney Engine Problems in Flight | Paul Smedshammer | Piloting | 45 | December 18th 04 10:40 AM |
| ROP masking of engine problems | Roger Long | Owning | 4 | September 27th 04 08:36 PM |
| Diesel engine | Bryan | Home Built | 41 | May 1st 04 08:23 PM |
| Objective Engine Discussion | Rick Maddy | Home Built | 26 | October 14th 03 05:46 AM |
