NAVMAN 3450 question
Old August 2nd 05, 01:59 AM
RW
Default NAVMAN 3450 question
Does anyone have experience with the Navman 3450 GPS Navigation
Sleeve for IPAQ? I'm specifically wondering if lat/long coordinates
can be directly entered into the unit. From the literature, I get the
impression that you must enter an address or intersection name. Are
there any other PDA/ GPS products out there that I should consider?
Trying to realize the impossible dream of an actual spousal unit
ground retrieval in a landout pinch Thanks in advance for
any help
Old August 2nd 05, 02:04 AM
Mal
Address only on the version of navman pin
http://www.navman.com/go/aus/ ask Navman
"RW" wrote in message
any help
Old August 2nd 05, 02:08 PM
basils27
You are confusing hardware and software. The 3450 is a gps sleeve and
supplies NMEA data to the Ipaq. The software that comes with it won't
accept lats and longs. I use a 3450 and IPAQ with Tom Tom navigator.
Version 3 will accept lats and long and version five can do if you use a
free utility to put the lat and long in as a "point of interest"
Basil
any help
Old August 2nd 05, 02:59 PM
Tim Mara
our attempts to use the Navman for flight navigation software were less than
sterling.......It does not appear that the Navman transmits GPS altitude
sentences....or?
If anyone wants an Navman I do have a brand new one here (works great for
Vehicle navigation and is tidy!) you can have cheap.. TomTom on the other
hand does work fine with Flight navigation (FlywithCE Navigator) and works
great for vehicle navigations as well making it quite an impressive option
for glider pilots who want to use their PDA for something other than just
glider use.
tim
Wings & Wheels
www.wingsandwheels.com
any help
Old August 2nd 05, 03:31 PM
The Navman will transmit altitude, as long as you didn't run the crappy
road nav program which was supplied with the unit. If you did, then you
need to reset the gps, using a simple utility. I occasionally use the
NAMVAN 3450 with an IPAQ 3835 when I flying club gliders, and it works
just fine.
I use PocketMap Navigator for road navigation. It will accept Lat/Long.
This is a real nice program with many features.
sentences....or?
glider use.
tim
Wings & Wheels
any help
Old August 2nd 05, 05:31 PM
Pete S
just fine.
Snip
Where do you get the utility from?
Peter.
Old August 3rd 05, 05:29 PM
basils27
Utility is on the Winpilot power flying software site. Once you have reset
the sleeve ditch the Smart ST road nav software and you will never have to
run it again.
http://www.winpilot.com/VFR/Default.htm
Basil
"Pete S" wrote in message
just fine.
Snip
Peter.
Old August 5th 05, 03:18 PM
Try this link: http://pocketmap.com/accessories/Win...itor_Setup.zip
Navman 3450 Doug Snyder Soaring 7 May 10th 05 02:20 PM
Navman PiN Pocket PC for glider usage [email protected] Soaring 1 February 8th 05 12:17 AM
