No SID in clearance, fly it anyway?
Old November 4th 03, 12:30 AM
Robert Henry
"Ron Rosenfeld" wrote in message
If the problem has been taken care of, then fine. However, if the problem
has not been taken care of, then it should be for all of our sakes.
That assumes there is a problem. The way it has been explained to me is
that the rules that apply for departing IFR at a non-towered field apply in
this case, and that operating under the understanding that terrain
separation services are available when departing a towered field (especially
a VFR-only one as in my case) is just a bad one.
So from that perspective, that looks to be the way the system works, not a
system problem. Now, if the controllers here would like to jump in and
correct me, great, but that doesn't seem to be happening.
Also, I made some inquiries with some people that know, and I wrote it up
for NASA.
I will also recommend to anyone to plan the departure according to the ODP
and make sure it is requested. Flying the ODP without telling ATC about it
can create separation issues. In this case, the ODP goes right into the
arrival corridor for the field.
  #105
Old November 4th 03, 02:54 AM
Ron Natalie
"Chip Jones" wrote in message k.net...
Or "VHF" towers, or "VHS" towers...all of which came up in aviation media
reports about the hearings and debates.
Or the slightly less popular beta towers.
  #106
Old November 4th 03, 03:21 AM
Ron Rosenfeld
On Mon, 3 Nov 2003 19:30:38 -0500, "Robert Henry"
I have read and reread this paragraph, and I must confess I don't
understand what you are saying, at least in the context of ATC and ODP's.
If you fly an ODP, you will have terrain separation. It doesn't matter
what field you are departing from.
Again, I'm not understanding what you are saying here. At least, I don't
understand how you are saying "the system works".
for NASA.
If flying the ODP without telling ATC can create separation issues, then
that is NOT how the system should work. If ATC is neither giving you an
alternate TERPs checked procedure to fly, nor keeping the ODP route clear,
then they are flat out doing it wrong, and there most certainly IS a
problem.
  #107
Old November 4th 03, 04:39 AM
Robert Henry
problem.
Conditions were clear, night vmc in the mountains with no moonlight. The
ODP was not issued.
  #108
Old November 4th 03, 11:21 AM
Ron Rosenfeld
On Mon, 3 Nov 2003 23:39:57 -0500, "Robert Henry"
problem.
ODP was not issued.
Weather conditions don't make any difference. Whether they protect the ODP
or not depends on the flight rules under which you are flying. VFR or IFR.
If you were IFR they should have been protecting the ODP, regardless of the
weather conditions. Or they should have given you alternate departure
instructions. If they are not doing this, they need training.
  #110
Old November 4th 03, 02:12 PM
Chip Jones
"Robert Henry" wrote in message
news:u4Gpb.565$0d2.102@lakeread06...
clear,
problem.
ODP was not issued.
When would an ODP ever be specifically issued unless more than one procedure
was available and traffic separation depended on which one you flew? Is the
assignment of an ODP something that if they don't specifically issue it as
part of your IFR clearance, then you can't fly it?
The way it works in my airspace is that I issue you an IFR departure
clearance *after* I deconflict you from other IFR traffic. You fly any
pertinent ODP at your discretion unless I assign something else. You do an
ODP and get with traffic, and I am the guy who screwed up.
Chip, ZTL
GPS approaches with Center Dan Luke Instrument Flight Rules 104 October 22nd 03 09:42 PM
IFR Routing Toronto to Windsor (CYTZ - CYQG) Rob Pesan Instrument Flight Rules 5 October 7th 03 01:50 PM
required readback on clearance [email protected] Instrument Flight Rules 15 September 17th 03 04:33 PM
Picking up a Clearance Airborne Brad Z Instrument Flight Rules 30 August 29th 03 01:31 AM
Big John Bites Dicks (Security Clearance) Badwater Bill Home Built 27 August 21st 03 12:40 AM
