The reason is that the bureaucracy and incompetents feel threatened by the
trend. It is my opinion that people go the N-registered route so as not to have to deal with the bozos who have gone so far as to tell UK pilots what airplanes they are skilled enough to fly, and that they are doing it to protect them. I would hope that the CAA nor the DFT gets their way on this. There should be plenty of comments from N-reg owners filed in response this, pointing out that the problem is with the useless bureaucracy, not with the owners. "Peter" wrote in message ... The UK Department for Transport has published a consultation document; their aim is as stated above. This would be extremely bad news for practically all U.S. registered pilots based in the UK. It would also be bad news for the American GA aircraft market, which would get flooded with aeroplanes forcibly sold from the UK. Many aeroplanes have FAA approved features which are not European approved. These would have to be removed, or the aircraft sold. Cirrus SR22 (arguably the best U.S. GA success story) would also be evicted from the UK, as would the TBM700C2 and other types. Peter. -- Return address is invalid to help stop junk mail. E-mail replies to but remove the X and the Y. Please do NOT copy usenet posts to email - it is NOT necessary. |
On Sat, 6 Aug 2005 8:22:48 +0100, Peter wrote
(in message ): The structure of European airspace, and its weather in many places, are such that without an IFR capability one can't usefully go anywhere. In the UK there is the IMC Rating; effectively an IR limited to below Class A. This means an IR is not strictly needed for flying purely around the UK. We do have Class A down to 2500ft, and even surface, in a lot of places, but in general one can fly under/around it. In Europe it's different. Any IMC requires a full IR, and that (flying usefully into Europe, doing instrument approaches and departures) is why people do the IR. And the FAA IR is the only one that's realistically attainable for most pilots that have work to do. Not to mention that in the UK a basic PPL with no ratings can fly IFR, and only needs a Night Qualification to fly at night. I understand that elsewhere, any night flying (as here) is IFR, and IFR is not allowed without a full IR. Hence even night flying requires an IR outside the UK. |
![]() "Simon Hobson" wrote in message et... On Sat, 6 Aug 2005 8:22:48 +0100, Peter wrote (in message ): The structure of European airspace, and its weather in many places, are such that without an IFR capability one can't usefully go anywhere. In the UK there is the IMC Rating; effectively an IR limited to below Class A. This means an IR is not strictly needed for flying purely around the UK. We do have Class A down to 2500ft, and even surface, in a lot of places, but in general one can fly under/around it. In Europe it's different. Any IMC requires a full IR, and that (flying usefully into Europe, doing instrument approaches and departures) is why people do the IR. And the FAA IR is the only one that's realistically attainable for most pilots that have work to do. Not to mention that in the UK a basic PPL with no ratings can fly IFR, and only needs a Night Qualification to fly at night. I understand that elsewhere, any night flying (as here) is IFR, and IFR is not allowed without a full IR. Hence even night flying requires an IR outside the UK. The French allow night VFR, pretty restrictive though, see http://www.sia.aviation-civile.gouv....0ENR%201.2.pdf Rgds Andy R |
![]() "Andy R" wrote in message ... "Simon Hobson" wrote in message et... On Sat, 6 Aug 2005 8:22:48 +0100, Peter wrote (in message ): The structure of European airspace, and its weather in many places, are such that without an IFR capability one can't usefully go anywhere. In the UK there is the IMC Rating; effectively an IR limited to below Class A. This means an IR is not strictly needed for flying purely around the UK. We do have Class A down to 2500ft, and even surface, in a lot of places, but in general one can fly under/around it. In Europe it's different. Any IMC requires a full IR, and that (flying usefully into Europe, doing instrument approaches and departures) is why people do the IR. And the FAA IR is the only one that's realistically attainable for most pilots that have work to do. Not to mention that in the UK a basic PPL with no ratings can fly IFR, and only needs a Night Qualification to fly at night. I understand that elsewhere, any night flying (as here) is IFR, and IFR is not allowed without a full IR. Hence even night flying requires an IR outside the UK. The French allow night VFR, pretty restrictive though, see http://www.sia.aviation-civile.gouv....0ENR%201.2.pdf There are also other things things that make it not impossible to get about without an IR. ie you can fly VFR in most French airways provided you're not in cloud, and you don't need to be in sight of the surface. So if you can find a hole to go up through and it's scattered or better at your destination on occasions you're actually better off than in the UK with an IMC because you can use the airways. Rgds Andy R |
![]() "Peter" wrote in message ... Simon Hobson wrote: Not to mention that in the UK a basic PPL with no ratings can fly IFR, Only in VMC and in Class G ![]() and only needs a Night Qualification to fly at night. I understand that elsewhere, any night flying (as here) is IFR, and IFR is not allowed without a full IR. Plenty of countries have VFR allowed at night - the USA is one great example. But yes this can be an issue. However a much bigger issue is that the UK is unique in allowing flight in IMC (i.e. IFR) anywhere, and allowing it without any clearance or even any radio contact in Class G. Outside the UK, to fly IFR, one needs to be on an IFR flight plan (following the proper ATS routes, filed and verified via the Brussels computer, and amended en-route by ATC as they wish) and an IR is mandatory to stay legal. Same in the USA, except their flight plan handling and lots of other details are very different. If the British Govt kicks out N-reg aircraft, in addition to the huge costs (typically, 4-5 figures to move back to G, for a little plane with no certification issues, and impossible for many e.g. the SR22) they will strip a large number of pilots of their IFR privileges for European flight. This is a very poor thing to do for safety. But a very good thing to do for civil servants/politicians who want control of the populace at any cost. AIUI this isn't being pushed as a safety measure and it's not even the CAA doing the pushing but the DFT. Rgds Andy R |
On Wed, 10 Aug 2005 9:02:20 +0100, Simon Hobson
wrote: /// in the UK a basic PPL with no ratings can fly IFR, and only needs a Night Qualification to fly at night. I understand that elsewhere, any night flying (as here) is IFR, and IFR is not allowed without a full IR. Hence even night flying requires an IR outside the UK. This note is wrong in several respects Brian Whatcott Altus, OK |
Not entirely true. You need an IMC rating to fly in IMC but it doesn't give
you the full priveleges of an IR (Class A use, for instance). It is merely to teach you to fly in marginal weather. Also you do need to have a Night Rating (and pay the CAA for the privelege) but it requires neither an IMC nor an IR rating. shawn "Simon Hobson" wrote in message et... On Sat, 6 Aug 2005 8:22:48 +0100, Peter wrote (in message ): The structure of European airspace, and its weather in many places, are such that without an IFR capability one can't usefully go anywhere. In the UK there is the IMC Rating; effectively an IR limited to below Class A. This means an IR is not strictly needed for flying purely around the UK. We do have Class A down to 2500ft, and even surface, in a lot of places, but in general one can fly under/around it. In Europe it's different. Any IMC requires a full IR, and that (flying usefully into Europe, doing instrument approaches and departures) is why people do the IR. And the FAA IR is the only one that's realistically attainable for most pilots that have work to do. Not to mention that in the UK a basic PPL with no ratings can fly IFR, and only needs a Night Qualification to fly at night. I understand that elsewhere, any night flying (as here) is IFR, and IFR is not allowed without a full IR. Hence even night flying requires an IR outside the UK. |
Simon Hobson wrote: (some stuff snipped) Not to mention that in the UK a basic PPL with no ratings can fly IFR, and only needs a Night Qualification to fly at night. I understand that elsewhere, any night flying (as here) is IFR, and IFR is not allowed without a full IR. Hence even night flying requires an IR outside the UK. In the US, all you need is three takeoffs and landings at night within the past 90 days to be qualified at night -- no IFR, "night rating," etc. |
ORVAL FAIRAIRN wrote:
In article , Simon Hobson wrote: (some stuff snipped) Not to mention that in the UK a basic PPL with no ratings can fly IFR, and only needs a Night Qualification to fly at night. I understand that elsewhere, any night flying (as here) is IFR, and IFR is not allowed without a full IR. Hence even night flying requires an IR outside the UK. In the US, all you need is three takeoffs and landings at night within the past 90 days to be qualified at night -- no IFR, "night rating," etc. In the USA, you only need to be "night-current" to carry passengers at night. You don't need to be night-current to fly solo at night. It's just normal VFR flying. |
In the US, all you need is three takeoffs and landings at night within the past 90 days to be qualified at night -- no IFR, "night rating," etc. I don't think so, Orval.... (b) Night takeoff and landing experience. (1) Except as provided in paragraph (e) of this section, no person may act as pilot in command of an aircraft CARRYING PASSENGERS during the period beginning 1 hour after sunset and ending 1 hour before sunrise, unless within the preceding 90 days that person has made at least three takeoffs and three landings to a full stop during the period beginning 1 hour after sunset and ending 1 hour before sunrise, and— (i) That person acted as sole manipulator of the flight controls; and (ii) The required takeoffs and landings were performed in an aircraft of the same category, class, and type (if a type rating is required). |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 07:17 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
