slowest top speed?
Old August 8th 05, 03:15 PM
Dan Bond
Default slowest top speed?
I'm doing research on the speed distribution of homebuilts. It's easy
to find published data on the fast airplanes, but I'm having a hard
time finding anything on the slowest. Anyone have a suggestion?
Old August 8th 05, 05:25 PM
Montblack
("Dan Bond" wrote)
For a slow 'high-end' speed example, a PPC (Powered Parachute) will max out
in the 26 mph range.
http://www.powerchutes.com/intro.asp
Montblack
Old August 8th 05, 11:10 PM
pittss1c
Depends on your definition of homebuilts.
Some of the MacCready human powered craft were 10 to 11 MPH.
Mike
Old August 9th 05, 04:14 AM
Harry K
Mike
Of couse if you define it as ground speed there is no trick at all in
getting negative ground speed, just fly into a head wind strong enough.
I vaguely recall seeing a report somewhere, somewhen where someone
actually landed backwards.
Harry K
Old August 9th 05, 11:55 AM
Scott
Corben Junior Ace with an A-65...75 MPH cruise, Vne of 126...couldn't
hit that going straight down with both wings ripped off
Scott
Old August 9th 05, 12:55 PM
Robert Bonomi
In article .com,
Mike
My father -- many years ago -- saw somebody in a Piper Cub (*NOT* a Super
Cub, the one with the little engine) flying into headwinds that were
approximately the _cruise_ speed of said craft.
The guy was on final coming in, when the winds kicked up and _stayed_ up.
There he is, a few hundred feet off the end of the runway, and pretty much
'parked' in mid air. Some 20+ minutes later, he's managed to get to the
runway, and gets down to 0 AGL, but the problem is "then what?" Start to
throttle down, and she starts rolling backwards.
As the story is told, the pilot, went back 'airborne', fought his way
over to the hanger area, and made a 'vertical' landing in the lee of
one of the hangers.
Old August 10th 05, 05:26 PM
CB
I've heard tell of a similar situation with WWII-era cadets flying
Stearmans in high winds. So the story goes, the wind kicked up while
the flight was out. When they came back, the aircraft couldn't get
down and stay down. Crews were sent out to grab the handles on the
wingtips and aft fuselage, haul them down, and walk them back to the
flightline.
Old August 10th 05, 05:45 PM
flightline.
It wasn't just one situation, the handhold were there in the bottom
wings of the Stearman's specifically for the ground crews to hang onto
to bring in the pilots in their airplanes in order to prevent them
from tipping over in the wind when they turned crosswind while
taxiing.
Many of the fields, or at least the one my father had his primary
flight training, was just a big field. You flew overhead, noted the
windsock direction and landed into the wind. If the wind was light,
you taxied in paying proper attention to use of ailerons and elevator
to keep the wings level and not nose over.
When the wind was higher, ground crew were stationed out at the field
and they'd run up once the airplane was stopped and hang on to the
wings using the handholds cut into the wingtips.
Other airplanes had them too. I took apart a Waco UPF-7 wings which
also had handholds built into it's wingtips. The wingtip around the
handhold was filled in with solid Balsa.
Corky Scott
Old August 10th 05, 08:25 PM
PittsS1C
I am not referring to ground speed... 10-11 is airspeed. (which is why I
found it relevant)
Mike
"Harry K" wrote in message
Mike
Harry K
Old August 10th 05, 08:49 PM
Richard Lamb
The extremely low speeds (10 to 11 mph) were absolutely necessary, as
MacCready figured out.
Since drag increases as a square of airspeed, the lowest possible
speeds were
necessary in order to fly at all - on the 1/4 sustained horsepower
available from
human muscles.
I thought his flyers were brilliant in both design and exicution.
Richard
Landing and T/O distances (Was Cold War ALternate Basing) Guy Alcala Military Aviation 3 August 13th 04 12:18 PM
Va and turbulent air penetration speed. Doug Instrument Flight Rules 70 January 11th 04 08:35 PM
Va and turbulent air penetration speed. Doug Owning 69 January 11th 04 08:35 PM
Speed Astir Guy Acheson Soaring 0 December 11th 03 02:24 AM
New Film: The Need For Speed - Going to war on drugs Phil Carpenter Military Aviation 0 July 23rd 03 07:43 AM
