#31
TripFarmer wrote:
Is 200 members and 4 airplanes really a club? I read the description to indicate 4 warriors, as opposed to 4 planes. For 4 planes, that would be an incredible ratio (~5 times the member/plane ratio my club maintains). That does beg a question that's been at the back of my mind for a while. For a "share based" club (like mine) where members all own a chunk of the action, what's the difference between "club" and "partnership"? - Andrew |
#32
![]() On 8-Aug-2005, xyzzy wrote: In the club I pay dues of $45/mo, and $80/hr wet to fly 160 hp Piper Warrior II's with Apollo GPS and coupled autopilot. The club has a fleet of four of them. That is the sum total of my airplane expenses and includes a very good insurance policy (all club members are named insureds), access to a hangar with offices that the club owns, and social events. Since joining the club I've been flying on average 6 hours a month, which is 72 hours a year. I know exactly how much it has cost me and I also know exactly how much it will cost me in the future to fly. So that works out to $87.50 per hour total cost ($80 + $45/6). Not bad, but... I co-own (with 2 others) an Arrow IV. We each fly roughly 70 hours/year, for a total of (typically) a bit over 200 hours. We almost never have scheduling conflicts. A couple of years ago we calculated what our hourly costs were running, including all direct and indirect operating costs -- essentially everything we spent to fly, maintain, store, insure, and upgrade the plane. Since the value of the plane is probably increasing at about the same rate as most low-risk investments, we did not factor in the cost of missed investment opportunity associated with our equity. The number came out to about $90/hr, quite a bit below what rental rates would be for a comparable plane. With today's higher fuel costs, the number is now probably running closer to $100/hr. We keep the plane meticulously maintained, stored in an enclosed hangar, and we have a $1 million "smooth" liability policy as well as low deductible hull coverage. The only maintenance we do ourselves is oil changes. What this shows is that once annual utilization gets to about 200 hrs/year, the per hour costs tend to flatten out. That's why I prefer my co-ownership arrangement. Diff'rent strokes, as they say. -Elliott Drucker |
#33
Joe - Great that you're looking into buying/co-owning a plane. FWIW, it
took me about six months to find both a set of partners and a plane. I joined the Cardinal Flyers Online when I first started looking and that was a source for a couple partnership contacts. Then again, I was looking into a Cardinal at that time so it made sense to go with CFO. However, groups like the Cherokee Pilot's association would be good as well since you can get some local contacts. It turns out that one of my current partners was a guy I'd met in a ground school and he knew another guy who was interested. End result: a 3-way partnership in a '71 Arrow and things are working out great. Ask around your FBO, folks at the airport, and just about anyone you run into. Be patient as the process can take some time. Good luck! Jack Allison Arrow N2104T |
#34
![]() "Peter R." wrote in message ... Gig 601XL Builder wr.giacona@coxDOTnet wrote: Nobody but you mentioned 172SPs. The OP certainly didn't Don't get hung up on my mention of the SP model. The OP mentioned "newer (but not brand new)" C172s. Thus, I assumed post-1998 models, which are all fuel injected and most contain more advanced avionics than a typical, older Warrior. In order to accurately reflect my experience, I used SP since that was what it was, but I certainly could have included the R model in my assumption about how long a checkout would take when going from a Warrier to either of these models. and again I wans't talking about SPs You weren't? Then why didn't you say so when you first stated, "If you are current in a Warrior and anybody REQUIRES 3-5 hours checkout in a Skyhawk they are just making money off you." Instead, you made a blanket statement that seems to imply all 172 models. Given the "newer (but not brand new)" quote from the original post, you were no more at liberty (and therefore no more right or wrong) to assume a pre-1998 model than I was to assume a post-1998 model. Well Peter the OP did mention that they were switching to Cessna because the vintage aircraft they were looking for was during the Piper bankruptcy isn't that pre-1996? You'll have to forgive me. When I think Skyhawk I think Fixed Gear, Non-constant speed prop, carbureted engine. I think you really know what I meant and are just being argumentative. |
#35
![]() Peter R. wrote: I have about 450 hours in a C172SP and I would probably need a couple of hours of instruction/flying just to become familiar with carb heat usage if I hypothetically needed to rent an older C172 model. Pull out the carb heat below the green arc. Push it in aboove the green arc. There. You're checked out. |
#36
Montblack wrote:
("xyzzy" wrote) 5. With a fleet of four basically identical planes, not completely grounded by squawks, annuals, overhauls, etc. We also have 152's, which are such low-end trainers that hardly any non-student pilots fly them, and Mooneys, and there are some members that fly both Warriors and Mooneys. Most members just fly one type though, because each type caters to a different market. 200+ members - 4 wariors. Hmm, something's not right. Not all members are as active as other members. Now I see 152's and Monneys. Ahhh, better :-) Got a club link? http://www.wingsofcarolina.org (rates haven't been updated, they went up in June, Warrior is now $80, Mooney is now $120, not sure what the 152's are now). |
#37
You'll have to forgive me. When I think Skyhawk I think Fixed Gear, Non-constant speed prop, carbureted engine. Fair enough. With that clarification, I agree with you that three-to- five hours does seem excessive for a Warrior pilot, if indeed the features you listed are the features of the C172 to which the pilot is transitioning. However, I honestly didn't know if your initial statement included the newer model 172s, which have enough differences (IMO) to warrant a longer checkout. Therefore I sought further clarification. FWIW, when I think Skyhawk, I think of the abilities and features of the newer models. Therein is the nature of our disagreement. I think you really know what I meant and are just being argumentative. Eh? I disagreed with your comment about the three hour checkout and provided the reasons for my disagreement. You now dismiss all of this as argumentative and hide behind the excuse that I knew what you meant all along, as if I am some type of mind reader? That's just silly. If you look again at my first post in this thread, it only asked what model to which you were referring. You are welcome to quote the words from my post that you interpreted as argumentative. Need I remind you that in your follow-up, it was you who lobbed a personal barb by questioning how many hours it took me to solo, as if you expected this to demonstrate some level of incompetence. -- Peter ----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
#39
Newps wrote:
Peter R. wrote: I have about 450 hours in a C172SP and I would probably need a couple of hours of instruction/flying just to become familiar with carb heat usage if I hypothetically needed to rent an older C172 model. Pull out the carb heat below the green arc. Push it in aboove the green arc. There. You're checked out. Thanks. If it is really that easy, then why are there so many NTSB accident reports that list carb icing as a contributory cause? -- Peter ----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
#40
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | December 2nd 04 07:00 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
