Sealing an ASW 28 canopy
Old August 9th 05, 04:43 PM
Udo Rumpf
Might it also be possible to include a check-valve sort of flap that would
allow exhaust but would prevent dirt from the tailwheel from entering the
tail boom?
bumper
I have given it some thought.
Installing a brush wiper at the front and rear to clean the rolling face.
of the wheel. Also a smaller wheel would allow a secondary fender.
The original wheel is about ~7". A 6" wheel would be large enough.
That would allow room for some sort of baffle.
Udo
Old August 9th 05, 06:36 PM
Eric Greenwell
bumper wrote:
Udo,
Interesting, I'll have a look at my ASH26E.
tail boom?
There appears to be plenty of exit area in the tail of my ASH 26 E
through the rudder horn fairings and openings in tail bulkheads. I
suspect restrictions, if any, are due to the engine box, or even just
stuffing the baggage compartment full with a down jacket, as I do.
Even so, my 26 has too much ventilation flow, so I've blocked off the
left side duct in the nose. I've heard of at least one pilot of an ASW
27 that made the nose intake hole smaller to achieve the same thing. My
guess is Udo's problem is specific to his glider, and not ASW 24 and
later models in general.
Craig Shaber had an exit (reverse NACA duct) installed in his ASH 26 on
the right side of the fuselage near the wheel doors, but I don't recall
if he thought it improved anything. Other pilots have done this to
various gliders, rather than trying to get the air all the way to the tail.
Eric Greenwell
Washington State
USA
Old August 9th 05, 07:00 PM
Greg Arnold
I would agree -- when I had a '24, I thought the ventilation was very good.
Old August 10th 05, 09:59 PM
CHo
why not ask AS sending an email?
and you sure will get an answer
I always get a reply
:-) Chris CH
ASW27
"Udo Rumpf" wrote in message
Wasn't air able to exit through the rudder horn and cable openings?
Eric Greenwell
Washington State
USA
It appears the opening is plugged by excess assembly epoxy.
Udo
Sealing The PIK-20B Canopy P. Corbett Soaring 5 August 21st 05 08:32 PM
Duo Discus canopy problems David Starer Soaring 4 June 20th 04 11:09 PM
Canopy crack repair Pete Brown Soaring 0 May 18th 04 03:09 AM
Redundant canopy latching John Soaring 5 March 16th 04 12:50 PM
DART Canopy needed Ernie Soaring 2 January 17th 04 03:26 PM
