Connecting Winpilot to LNAV
Old August 10th 05, 10:37 PM
Robin Birch
Default Connecting Winpilot to LNAV
What cabling should be used to connect an LNAV based setup to an iPAQ
running winpilot?
Regards
Robin Birch
Robin Birch
Old August 10th 05, 11:08 PM
Paul Remde
Hi,
WinPilot can't connect to an L-NAV but it can connect to a GPS-NAV which is
commonly used with an L-NAV. Is that the setup you have?
It is my understanding that WinPilot does not send the GPS initialization
string that is required to tell the GPS-NAV to start sending GPS data when
connected to the GPS-NAV's DB-9 port. That is not a problem because you can
use the RJ connector that sends data to the L-NAV to also send data to
WinPilot. I think that the wiring connections for the RJ connector are
described in the GPS-NAV manual.
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
http://www.cumulus-soaring.com
"Robin Birch" wrote in message
running winpilot?
Regards
Robin Birch
Robin Birch
Old August 10th 05, 11:10 PM
Nick Gilbert
You need to connect the Ipaq to an NMEA source (i.e. a Datalogger or
GPS of some sort). The L-Nav also needs receive NMEA data to display
final glide info.
If you have a Cambridge GPS-Nav, this is quite simple. Otherwise, I'm
sure someone else knows better than i do!
Nick.
running winpilot?
Regards
Robin Birch
Robin Birch
Old August 11th 05, 05:43 AM
Robin,
WinPilot ADV can be used with a GPS-NAV. Please see my website for a
GPS14-Kit. It includes a power converter and the cables. The kit
connects you to the serial port of the GPS-NAV. The phone connector
still connects to the L-NAV.
Some say that you can power you ipaq with the GPS-NAV . The problems
with this is that the power converter in the GPS-NAV is not rated to
power an Ipaq and may pop the internal thermal fuse in the GPS-Nav.
To Set WinPilot ADV for the GPS NAV start the WinPilot Sim and go menu
about under hardware select GPS_NAV1. Shut down WinPilot normally to
save the setting. Connect to the GPS-NAV make sure the green light on
the GPS-NAV is blinking (means you have a GPS lock) Start WinPilot if
the Setting page come up this is the correct setting, if not do the
above and select GPS-NAV2. One of these setting will initialize the
GPS NAV.
Please see my website or call if you have additional questions.
Richard
www.craggyaero.com
Old August 29th 05, 03:04 PM
Jim Kelly
On many iPaqs there is a setting to insist on a "slow USB charge
(rate)" (StartSettingsSystemPowerUSB Charging). There is a
chance that this puts less load on the supply circuit and could
avoid blowing fuses.
Cheers,
Jim Kelly
problems
to
GPS-Nav.
Old August 30th 05, 05:27 PM
Robin Birch
In message , Jim Kelly
writes
Cheers,
Jim Kelly
problems
to
GPS-Nav.
Thanks for all of this guys. My chum (whose glider it is) has worked
out what to do and is going to put in a separate power supply for the
PDA.
Cheers
Robin
Robin Birch
WinPilot offer... and UK news Paul Crabb Soaring 2 February 19th 04 09:22 AM
WinPilot ADV comm port setting Ted Wagner Soaring 1 December 29th 03 05:44 PM
What determines LNAV "circling mode"? Jack Soaring 11 November 20th 03 05:15 AM
WinPilot Offers Free WinPilot XP for your Desktop Computer Richard Pfiffner Soaring 0 November 8th 03 04:44 PM
Declaring a flight in WinPilot to the Volkslogger JohnD Soaring 0 October 1st 03 11:55 PM
