about this little simulator
Old August 12th 05, 11:20 AM
Grandss
Default about this little simulator
Hi All,
I need a pilot help
here is a little simultor in c++ and directx with an .exe
http://examples.oreilly.com/physicsgame/flightsim.zip
it is a "real" simulation
i don't arrive to pitch down when I flying (because plane stalling)
if someone can do it, please inform me
thanks
Old August 12th 05, 01:32 PM
kontiki
You can't be serious to expect anyone to download and install this
program on their computer in order to answer your question do you?
Grandss wrote:
Hi All,
I need a pilot help
thanks
Old August 12th 05, 02:39 PM
Grandss
Grandss wrote:
Hi All,
I need a pilot help
thanks
it's zip file, which contains a MS Visual C++ project and a .exe if you
don't have directx SDK on your computer.
you can check url, it's come from o'reilly website (a book editor)
homepage is www.oreilly.com
if you're not sure with that I explain, files come from this site and
you can find their in ressource center, game devellopement, Physics for
Game devellopers (http://www.oreilly.com/catalog/physicsgame).
And you don't need to install it. Just run it and press escape when you
want to quit.
Old August 12th 05, 03:32 PM
Grandss
Grandss a écrit :
Hi All,
I need a pilot help
thanks
About increment of angle for flight command, is it fixe or not
in this programme, if i use left rudder, angle become 16.
I think it should be increase slowly to 16 (or more i don't know) and
not to go from 0 to 16.
if Someboby can tell me which are the angle possibilities for flight
control (note: i try to simulate a little cessna)
thanks
Old August 12th 05, 04:29 PM
Tim Epstein
Please understand that this is not an IT discussion forum. Many people here
would not know what to do with a .zip file, much less understand what C++,
SDK or even .exe mean.
I suggest you post your request for help in a physics or programming forum,
or post in a completely non I.T. technical way - for example: In a single
engine Cessna is it normal to stall at 60 knots with 10 degrees of flaps?
It may help you to find a forum in your first language.
Regards,
Tim
"Grandss" grandss@nospam wrote in message ...
Hi All,
I need a pilot help
thanks
Old August 12th 05, 05:29 PM
Grandss
Regards,
Tim
Hi All,
I need a pilot help
thanks
OK I try to do it.
But I just think it's more explicit with this small simulator.
My english is not very good and i know nothing about aviation.
Only that I learn with my project.
merci quand meme
Old August 12th 05, 06:15 PM
Andrew Gideon
want to quit.
I think I've just learned why so many MSFT machines are exploited.
- Andrew
Old August 12th 05, 07:13 PM
Peter Duniho
"Andrew Gideon" wrote in message
online.com...
And what did you learn? Please share.
How many "MSFT machines" (whatever that is) are exploited? Out of how many
installed? How many non-"MSFT machines" are exploited? Out of how many
installed? And I presume your statement means you not only know these
numbers, but you have an explanation for them?
It's unfair to tease us with just a mere hint of your astounding insight.
Please let us in on the secret.
Old August 12th 05, 07:34 PM
Steve Foley
OK,
I downloaded the program and tried running it.
It did, in fact, indicate a stall as soon as I pitched down. There appears
to be a problem with the program. My plane does not react this way. I was
unable to get it indicate a stall while pitching up, however it does
actually stall, as is clearly demonstrated when the nose pitches down, even
though I was still pitching up.
I guess I'll have something for my son to play with this week. I suppose
I'll have to go get him the 'Physics for game developers' book too.
here
C++,
forum,
single
flaps?
Regards,
Tim
Hi All,
I need a pilot help
thanks
OK I try to do it.
merci quand meme
Old August 12th 05, 09:27 PM
grubertm
I need a pilot help
Actually I think you need programming help, and this is probably the
wrong newsgroup.
I have that book on my shelf and it has a LOOONG list of errata which
can be found on O'Reillys website. My recommendation: don't use it.
Instead take a look at Palmer's "Physics for Game Programmers" which
has an excellent section on airfoils (incl. some scans from the C-172
manual). There's also a brief article on aerodynamics in "Game
Programming Gems 5".
- Marco
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP vvcd Rotorcraft 0 September 22nd 04 07:17 PM
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP vvcd Home Built 0 September 22nd 04 07:16 PM
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP vvcd Piloting 0 September 22nd 04 07:13 PM
Microsoft Flight Simulator and Garmin aviation handheld GPS John Bell Simulators 4 March 25th 04 11:56 AM
Real World Specs for FS 2004 Paul H. Simulators 16 August 18th 03 09:25 AM
