Descent below MDA -- what would you do?
Old August 14th 05, 03:54 PM
Doug
Click the mic and turn the lights on.
Old August 14th 05, 04:46 PM
A Lieberman
Doug,
No PCL per Duat.
Allen
Old August 14th 05, 05:09 PM
Ron Rosenfeld
On Sun, 14 Aug 2005 10:46:09 -0500, A Lieberman
Doug,
No PCL per Duat.
Allen
PCL on 122.8 per the Jepp approach chart
Old August 14th 05, 05:25 PM
Gary Drescher
wrote in message ...
The reason I ask about the phone is because you could have opted to cancel
IFR
and then do whatever you wanted to do to get in and land.
In the absence of radio or phone contact, can you unilaterally cancel IFR
and inform ATC after you land?
--Gary
Old August 14th 05, 06:02 PM
Doug
Go MISSED! It is descending below the MDA like this that caused the
Gulfstream crash at Aspen. Trying to "stuff it in" they discovered the
visibility blocked the runway and they CRASHED and DIED.
Old August 14th 05, 06:04 PM
IFR
--Gary
For non-commercial operations I don't see why not. But, it's not clean and
someone may say it was wrong to hold the airspace when you had "cancelled" as a
state of mind. Or, some might argue that a cancellation does not take effect
until ATC acknowledges its receipt.
Murky waters but I suspect the not-for-hire pilot would prevail in any
enforcement proceeding. It's more of an issue of ATC policy as opposed to
regulations, per se.
Old August 14th 05, 06:34 PM
Gary Drescher
cancel
IFR
--Gary
and
as a
state of mind.
But if the alternative were to not cancel at all, then the airspace would be
just as held-up.
Yup, that's what I'm unsure about. Also, if you did cancel unilaterally,
would you then squawk 1200 in case ATC still had radar contact?
--Gary
Old August 14th 05, 06:54 PM
Matt Whiting
IFR
How do you "unilaterally" cancel IFR?
Matt
Old August 14th 05, 07:38 PM
That was a night approach into an airport that is marginally (at best) an
IFR airport. And, it was a jet airplane.
A single-engine light aircraft going to a relatively flat-land CAT A/B
only airport in the daytime, and with pretty good weather is a very
different set of circumstances than what happened at Aspen.
Old August 14th 05, 07:54 PM
Newps
IFR
No.
ASW19b best descent rate on approach (full airbrakes) Robert Sharpe Soaring 1 April 30th 05 11:41 AM
descent below minimums hsm Instrument Flight Rules 82 January 11th 05 06:33 PM
BRS and descent rate Roger Long Piloting 21 May 7th 04 05:34 PM
Avoiding Shock Cooling in Quick Descent O. Sami Saydjari Owning 32 January 21st 04 04:32 AM
Minimum rate of climb or descent Aaron Kahn Instrument Flight Rules 3 July 25th 03 03:22 PM
