O2 and Cypriot airliner crash
Old August 15th 05, 04:07 PM
Shawn
In accounts of the crash of the Cypriot airliner in Greece, all I've
read say that loss of cabin pressure could not, by itself, incapacitate
the pilot. Yet, I was once told by an ATP that at 40k feet (admittedly
this plane was at 35k) O2 supply by itself will not suffice to keep you
conscious and that the drop down masks only give a false sense of
security. He said that the ambient pressure is so low that even 100% O2
does not provide enough to keep you conscious without a pressure
breathing mask. If he's right, that could explain the crash, especially
given that all it would take is 20 seconds of distraction (i.e., not
donning the mask) to knock out the pilot as indicated in the table
below. On the other hand, I checked and a standard atmosphere at 35k
feet is 7.0 in of Hg, which is more than the partial pressure of O2 at
sea level (6 in = 20% of 30 inches), which would seem to contradict the
info given by the ATP. Any thoughts or corrections to my reasoning?
Tlme of useful
consciousness
Altitude (ft) without oxygen
40,000 15 seconds
35.000 20 seconds
30,000 30 seconds
28,000 1 minute
26,000 2 minutes
24,000 3 minutes
22,000 6 minutes
20,000 10 minutes
15.000 Indefinite
Sure pp is 6" at sea level, but at 35 k ft (using your numbers) the pp
O2 is 20% of 7" or 1.4" Hg. At that pressure only about 50% of the
hemoglobin in your blood is saturated, and it hangs on to that O2 pretty
strongly, so it's not available for use by your brain (or anywhere else).
Shawn
Old August 15th 05, 04:12 PM
Shawn
Peter Duniho wrote:
"Bucky" wrote in message
I don't get it. Can't a person stay conscious for longer than 30
seconds without breathing? Most people can hold their breath for over
a minute.
When they do that, they are using up a small reserve of oxygen-filled air
contained in their lungs. Exhale as much air from your lungs as you can,
and THEN see how long you can hold your breath.
At high altitude you breath out the oxygen bound to the hemoglobin in
your blood. Your blood gives up its O2 to the air. Hold your breath or
just stop breathing and you may last longer (never done the experiment
though ;-) ).
Shawn
Old August 15th 05, 05:24 PM
Happy Dog
"John Kirksey" wrote in message
news:cZ0Me.4596$H_4.4209@trnddc07...
Tlme of useful
consciousness
40,000 15 seconds
35.000 20 seconds
30,000 30 seconds
28,000 1 minute
How, then, can someone like Ed Viesturs repeatedly climb the tallest
mountain peaks in the world without supplemental oxygen? Is it because of
the slower ascent and the time spent acclimating to the higher altitudes?
That and by breathing like he's running a marathon. Sleep and you die.
mo
Old August 15th 05, 06:08 PM
Stefan
This is just plain bull****. It's all about partial pressure.
Stefan
Old August 15th 05, 06:11 PM
Scott Migaldi
Ash Wyllie wrote:
Seems to me that astronauts use 3psi of pure O2 during EVAs.
-ash
Cthulhu in 2005!
Why wait for nature?
Correct and 3psi of pure O2 is about the same as the ppO2 in Air at Sea
Level.
Scott F. Migaldi
CP-ASEL-IA
N8116B
PADI MI-150972
Join the PADI Instructor Yahoo Group
http://groups.yahoo.com/group/PADI-Instructors/
Old August 15th 05, 06:32 PM
Happy Dog
"Bert Willing" wrote in
message ...
If the pressure drop is rapid, they need to exhale, otherwise their lungs
will burst. Just like surfacing in scuba diving.
I don't believe there's ever been a case of pulmonary barotrauma (absent of
prior lung pathology) from decompression in commercial aviation. The
differential between 50,000' and 8,000' is less than that typically involved
in scuba incidents. May be possible though.
moo
  #28
Old August 15th 05, 06:33 PM
Happy Dog
"Jack" wrote in message
Partially crap. Learn how lungs work.
Your post is complete crapp. Why don't you spend five seconds and tell us
all you know in the subject?
Adorable. In five seconds. Below a minimal partial pressure of O2, (40mm
Hg is the typical partial pressure in tissue / 100mm is pO2 in the lungs) an
exchange won't occur in the lungs. Period. Exhaling to the best of one's
ability, as the previous poster suggested, isn't analogous. Lungs work just
fine in reverse.
For more, Google +oxygen +"partial pressure" +respiration 39,500 hits.
moo
  #29
Old August 15th 05, 07:01 PM
Happy Dog
"Stefan" wrote in message
Breathing technique is crucial to high altitude activity. The technique is
very similar to that used by joggers.
moo
  #30
Old August 15th 05, 07:54 PM
George Patterson
a minute.
If the aircraft loses pressure at 35,000', you cannot hold your breath. The
pressure difference will force you to exhale. Nothing you can do about it.
But that's not the biggest deal. The biggest problem is the fact that the
ambient pressure at that altitude is too low to keep oxygen in your bloodstream.
All the oxygen immediately begins to flow out of your bloodstream into your
lungs and out into the surrounding air. It doesn't matter whether you breathe
or not.
George Patterson
Give a person a fish and you feed him for a day; teach a person to
use the Internet and he won't bother you for weeks.
