Passing out at high altitudes / the Greek ailrliner crash
Old August 16th 05, 04:51 PM
Bob Gardner
I was reading 91.211.
Bob
wrote in message ...
Bob Gardner wrote:
Based on my experience in a USAF altitude chamber, after the chamber has
been pumped up (actually down...it is a vacuum) to 25000 feet and the
pressure suddenly dumped as would be the case in a decompression,
whatever
air you have in your lungs comes out forcefully...no way do you have any
control over it. Gotta get that mask on and get it on in a hurry, because
time is fleetingly short.
In US regulations, the magic altitude is flight level 350 (more or less
35000 feet, depending on ambient atmospheric pressure). The Cypriot plane
was reportedly at FL 340, if we can believe the media. Under US rules,
above
FL 350 both pilots must be at the controls and each must have a
quick-donning mask at hand. If one pilot has to leave the cockpit for any
reason, the other has to put on and use oxygen until he returns.
It's FL 250 (121.333 I believe). Above 250 one crewmember must be on O2
when
the other leaves the flight deck.
As to decompression of an aircraft the size of the 737, there is rapid
decompression and explosive decompression. It the packs both trip off or
a
window blows out it results in rapid decompression, which is quite
different
than an altitude chamber experience. The cabin ascends at perhaps 10,000
feet
per minute. But, if there is some type of structural failure resulting in
a
whole larger than a window, then the cabin can explosively decompress,
similar
to your experience in the altitude chamber.
Old August 16th 05, 08:18 PM
I wasn't aware that the feds relaxed such a critical safety standard for a
non-commercial turbine aircraft. If anything, because of the smaller pressure
vessel, the rule should be more restrictive than the commercial rule.
Dead is dead ala Payne Stewart.
Bob
whatever
above
when
a
different
feet
a
similar
What's minimum safe O2 level? PaulH Piloting 29 November 9th 04 07:35 PM
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! Bruce A. Frank Home Built 1 July 4th 04 07:28 PM
High Flight NOTAM Kirk Stant Military Aviation 1 September 10th 03 03:31 AM
