BOEING CO. has tested an electric motor that could allow commercial jets to taxi around airports without using their engines or ground-based towing vehicles, the company said. Boeing said its Phantom Works unit had used the nose-wheel motor, built by Chorus Motors Plc, to move around an Air Canada Boeing 767 jet in tests simulating various runway conditions in June. The system could offer a glimmer of hope to U.S. airlines, which have been scouring for ways to boost economies amid record fuel prices, by directing pilots to taxi with single engines, among other steps. It was unclear how soon the motor would be ready or how much it would cost. Boeing said the companies are working to overcome various technical issues that had surfaced during the tests. The motors could save airlines money by eliminating the use of airport tow tugs and boost efficiency by running their jets less, as well as reduce emissions, the companies said. (Reuters 11:44 AM ET 08/01/2005) Mo http://q1.schwab.com/s/r?l=248&a=111...a&s=rb050 801 ---------------------------------------------------------------- |
So... do you still log the taxi time as PIC? : )
Ben Hallert PP-ASEL |
Sure. There are no regs on what is supposed to be powering the aircraft. ![]() What I wonder is which weighs more - the fuel that would have been used, or the motor that the airplane has to carry around for the whole flight. Jose -- Quantum Mechanics is like this: God =does= play dice with the universe, except there's no God, and there's no dice. And maybe there's no universe. for Email, make the obvious change in the address. |
"Jose" wrote in message
t... [...] What I wonder is which weighs more - the fuel that would have been used, or the motor that the airplane has to carry around for the whole flight. Doesn't really matter. The weights are probably comparable (and the fuel may well weigh more), but more important is that the airline has to keep buying the substance that makes up the weight of the fuel (that is, the fuel itself), while they can buy the electric motor once (or some very small number of times over the lifetime of the airframe). Unless the electric motor were vastly heavier than the fuel (and that seems unlikely), this seems like a pretty good idea to me. It wasn't clear at all from the press release what the nature of the motor would be. Is it a permanent installation, or is it attached to the airplane only while at the airport? Does it have an internal battery, or does it run off of some kind of external power source (like the airplane's APU). I don't think the answers are all that critical to the success of the device, but they are things I wonder about. Ironically, the link Larry labeled as "More" simply repeats the exact text he posted. Duh. I guess "More" just means "more formatted and other extraneous crap". Pete |
"Peter Duniho"
"Jose" wrote in message What I wonder is which weighs more - the fuel that would have been used, or the motor that the airplane has to carry around for the whole flight. Doesn't really matter. The weights are probably comparable (and the fuel may well weigh more), but more important is that the airline has to keep buying the substance that makes up the weight of the fuel (that is, the fuel itself), while they can buy the electric motor once (or some very small number of times over the lifetime of the airframe). Unless the electric motor were vastly heavier than the fuel (and that seems unlikely), this seems like a pretty good idea to me. It wasn't clear at all from the press release what the nature of the motor would be. Is it a permanent installation, or is it attached to the airplane only while at the airport? Does it have an internal battery, or does it run off of some kind of external power source (like the airplane's APU). How many kilowatts does a passenger jet consume to run all the other stuff that must be powered whilst taxiing? A/C, lighting, avionics etc. Batteries seem an unlikely solution for all that. Additional batteries plus the power from an idling engine? Third rail? moo |
Happy Dog wrote:
How many kilowatts does a passenger jet consume to run all the other stuff that must be powered whilst taxiing? A/C, lighting, avionics etc. Batteries seem an unlikely solution for all that. Yeah, I agree. Maybe the engines drive an alternator, which powers the electric motor. |
"Happy Dog" wrote in message
. .. How many kilowatts does a passenger jet consume to run all the other stuff that must be powered whilst taxiing? A/C, lighting, avionics etc. Batteries seem an unlikely solution for all that. Additional batteries plus the power from an idling engine? Third rail? IMHO, the most likely solution is to simply run it off the APU. Or maybe just the regular generator on the engine (which can probably produce enough power with the engine at idle, which is still a savings over taxiing with all but one engine shut down). Someone at Boeing was probably driving their Prius to work and had an epiphany. My point was simply that the press release is incredibly vague; we really have no idea *what* this device is, how it works, or how practical it will be. I suspect it will turn out to be a good idea, but it's hard to know without any actual information. Pete |
It's probably some kind of ultra high voltage DC pancake motor that
would require it's own special APU to power it. It would have to develope on the order of three to four hundred horsepower to be able to reliably move a fully loaded jet around under all the taxi conditions that a jet might see. In addition it would either have to be able to spool up at a fast enough rate as to not rip the nose gear tires off the rims on landing or be disconnected from the nose wheels on landing. Either way it's a lot of extra crap to carry around on the aircraft as well as go through the certification process over using a tug. Craig C. |
I wonder what the cost is gonna be in battery life over time. Dave |
Happy Dog wrote: How many kilowatts does a passenger jet consume to run all the other stuff that must be powered whilst taxiing? A/C, lighting, avionics etc. Batteries seem an unlikely solution for all that. Additional batteries plus the power from an idling engine? Third rail? APU. -- Eduardo K. | Some say it's forgive and forget. http://www.carfun.cl | I say forget about forgiving just accept. http://e.nn.cl | And get the hell out of town. | Minnie Driver, Grosse Point Blank |
| Thread Tools | |
| Display Modes | |
| Is a Turn Coordinator an electric motor or powered by fan? | kickinwing | Piloting | 5 | June 11th 05 01:25 PM |
| Cherokee Electric Pitch Trim | Jonathan Goodish | Owning | 4 | November 18th 04 03:43 AM |
| Piper Arrow electric fuel-pump | MC | General Aviation | 7 | June 3rd 04 03:50 AM |
| taxi in reverse? | Malcolm Teas | Home Built | 10 | February 21st 04 01:26 AM |
| More on the electric verses turbojet | cdubya | Soaring | 8 | September 25th 03 10:16 AM |
