#11
Mitty wrote:
WeÂ*doÂ*notÂ*flyÂ*aÂ*lotÂ*ofÂ*hardÂ*IFR That's good. My "scary thought" about the precise-flight is losing vacuum pressure on the missed approach. - Andrew |
Jose wrote
I would not remove the T&B. If you add another AI, put it in a nearby hole, but not the T&B. No other instrument provides turn rate information. After 47 years of civilian, military, and airline flying, I have yet to see a reason for "turn rate" as long as I have a functioning attitude indicator. Bob Moore |
Mitty wrote:
Airplanes: We have 4 different flavors of PA-28s, six total, plus a Cherokee Six. The two being upgraded right now are Archers. Type of Flying: We do not fly a lot of hard IFR, panel space is limited as is money. Hence, we are not looking at backup horizons, etc. Also, one of the airplanes will be getting an S-TEC 2/ or 30, which replaces the TC. Hence, something like the Precise Flight at $400-500 kind of numbers is the candidate. Possibly an electric pump, though I don't know anything about the cost. I once owned an Archer that was leased to a flying club, and I installed the Precise Flight system. I wouldn't do it again. I *might* feel differently if I were the only pilot, but probably not. Pilots need to understand how it works and be prepared to accommodate its peculiarities. The peculiarities can be explained in a few paragraphs, but won't be appreciated by the pilots unless they have actually experienced the way it works. You can't experience the way it works unless you physically disconnect the vacuum pump, cap it off, and go flying. You can't do that kind of training for every pilot in the club. If you think just pulling out the knob is sufficient to experience how it works, you are mistaken. The result of pulling out the knob is quite different when the vacuum pump is operating and when it is not operating. Unless you preflight the system before takeoff, you can't be sure it will work when you need it. If you don't exercise the shuttle valve often it can get stuck, rendering the system inoperative and requiring extra maintenance. You exercise the shuttle valve every time you do the preflight checks, *if* you do the preflight checks correctly. I found most pilots didn't understand how to do the preflight checks correctly, didn't follow a written checklist, and often failed to preflight the system at all. If they did preflight it, they didn't understand how to do it correctly so that the shuttle valve is exercised and you know it's working. In operation, at best, you must reduce engine power (thereby reducing manifold pressure, or, put another way, increasing manifold vacuum) in order to make the system work. So if you need to climb, or at some altitudes, even maintain altitude, you are going to require more power than the reduced amount that will keep the gyros spinning. So in that circumstance you are going to be partial panel anyway. In the high workload environment of say, a missed approach, as you add power, the gyros start to spin down. That adds another work item to your already high workload: recognizing that the backup vacuum has "failed". Operating under the stress of a vacuum pump failure and a missed approach, you might forget that will inevitably happen as soon as you add power. In short, IMO you might as well just learn to fly partial panel. Dave |
Interesting that you pointed that out. I was thinking the same thing when
I posed the question but thought that two tumbling AIs would pretty much guarantee that the pilot would not recover. I agree with you - with two tumbled AI's and no TC, recovery is impossible. With a working TC, it is merely highly unlikely. Therefore, if the panel space is there, it might make sense to keep the TC. Not much sense, mind you, because if you manage to screw up badly enough to put the plane into an attitude that would cause both AI's to tumble, well, I'm willing to give very good odds that you're not going to recover on the TC. However, let's say having both the TC and the second (electric) AI is not practical (probably due to space considerations). Would I rather have an electric AI, or the TC? I would still prefer the electric AI. First off, with dual AI's next to each other, I believe that following a dying AI into an unusual attitude becomes far less likely, and thus while the chances of recovery from the unusual attitude are reduced slightly, the chances of encountering it in the first place are reduced dramatically. Not so with a backup vacuum - you have to engage it. And even if you do, half the time (in my experience more) the problem is the AI, not the power source, so backup power for the AI does you no good. The problem with this analysis is the reliability (or lack of same) for electric AI's. I've heard the affordable ones are not good, and the good ones are not affordable. Finally, there is the issue of training. If you have dual AI's with independent power sources, it makes sense to skip partial panel training. If you have only a single AI, even with redundant power sources, that's not the case. In that case, a standby vacuum system seems to be an unjustified expense - the money spent on it is probably better spent on recurrent training. Michael |
Bob Moore wrote:
After 47 years of civilian, military, and airline flying, I have yet to see a reason for "turn rate" as long as I have a functioning attitude indicator. As a recreational pilot of a simple IFR aircraft, I've recently discovered a great role for the T&B; staying on heading. After a few years of struggling to keep my non-AP equipped flivver on a MH, I've re-discovered what many must know. The T&B is the best instrument to go straight with. The AI gives you good info, and the heading gyro does too, but the best way to keep it all centered in my Maule is definitely the T&B. Especially in calm conditions. |
I have the precise flight setup. I've never had the failure where I had
to use it but it gives me peace of mind. So does a new pump. I'm not familiar with typical IFR setups but do most a/c have a vacuum failure light to tell you when the vac pump fails? I believe that the vacuum failure light that was installed with the Precise Flight system is as valuable, or perhaps more valuable than the actual backup function. That series of tests where the vac was failed while filming pilots reactions seem to indicate that the main problem was detecting the failure and slow roll over of the AI in time. A red light beaming at you from the center of the panel seems to be to be pretty damn valuable. But like I said, I haven't had the failure so I just don't know. Mitty wrote: Our club is looking at upgrading a couple of airplanes to Garmin 430s, etc. It seems to me that standby vacuum would be a good thing to add, too. 1) Good idea? Do these systems really work? 2) Recommendations on type/brand/model? TIA |
![]() Scott Moore wrote: Mitty wrote: Our club is looking at upgrading a couple of airplanes to Garmin 430s, etc. It seems to me that standby vacuum would be a good thing to add, too. 1) Good idea? Do these systems really work? 2) Recommendations on type/brand/model? TIA Electric attitude. Vacuum pumps are going away. But, can't an electric attitude indicator fail? Bearings wear out. I've suffered that on a hard disk. Are there any MTBF numbers for the two systems? |
keep the TC. I know that FAR 91.205 requires a rate of turn indicator for IFR (except for airliners with three attitude indicators). Is it common for this requirement to be waived to allow substituting a second AI for the TC? |
airliners with three attitude indicators). Is it common for this requirement to be waived to allow substituting a second AI for the TC? In a manner of speaking. No waiver is actually necessary. Advisory Circular 91-75 details the conditions under which this substitution is acceptable. Note that 91.205 states: no person may operate a powered civil aircraft with a standard category U.S. airworthiness certificate in any operation described in paragraphs (b) through (f) of this section unless that aircraft contains the instruments and equipment specified in those paragraphs (or FAA-approved equivalents) 91.75 Details what constitutes an FAA-approved equivalent for a rate-of-turn indicator. Michael |
![]() Seems that the best redundancy is a rate based autopilot (read STEC). Since it is based on, and runs on, a turn indicator the issue of whether yo have a good one is solved. However I still have an electric backup vacuum pump in my C172. |
Wet vs Dry Vacuum Pump | Fastglasair | Owning | 7 | December 17th 04 11:46 PM |
Wet vs Dry Vacuum Pump | Fastglasair | Home Built | 1 | December 15th 04 05:17 PM |
Backup vacuum pump system STC'ed for Cherokee 180 | Chuck | Owning | 6 | September 18th 04 02:30 PM |
Reverse Vacuum Damging to Instruments? | O. Sami Saydjari | Owning | 8 | February 16th 04 04:00 AM |
Can vacuum AI be removed if a certified electric one is installed?? | Dave | Owning | 11 | January 12th 04 06:08 PM |
