Schweizer 1-35 and other flapped sailplanes
Old August 19th 05, 08:52 PM
Jeffrey Banks
Hi All,
I have a 1/5 share in a 1-35 here in Alaska. I find
this glider a delight to
fly and the flaps seem to work just fine for approach
control. Once at 30
degrees I can modulate between 30 degs and full without
much trouble just
as I do with spoilers. The nose needs to be pointed
down when adding flaps
and this is quite normal in any aircraft with flaps
that I have flown.
I am amazed at how small an area this glider will land
in. And again how
far it will float at flaps 30. Seems like it has great
spot landing control.
If one is a first timer with flap use there might be
a learning curve that
could best be handled with some dual time in a Cessna
practicing some
power off landings. (I love the older Cessnas with
the manual flaps)
Jeff Banks
N2JY
Old August 19th 05, 09:07 PM
Eric Greenwell
Maule Driver wrote:
But I've landed in extremely gusty/wind shear conditions on several
occassions. That is, with T-storms over or on the airport (stupid?
Yes.) Flying with spoilers and flaps saved the day. Upon reflection if
given a choice between the 2, it would have to be spoilers. In those
admittedly extreme conditions, airspeed excursions are not entirely in
one's control and spoilers-only are better than flaps-only no matter the
level of pilot proficiency.
A couple HP owners told me that spoilers are preferable to flaps when
flying fast under clouds with strong lift:
* if the lift suddenly increases and threatens to suck you into the
cloud, spoilers can be quickly deployed keep you below the cloud.
* flaps will first increase the lift as you begin to lower them, and
take you into the cloud. Increasing speed to stay out of the cloud may
put you over the speed limit for the flap setting you need avoid the cloud.
Have other HP owners encountered this situation, and how do they cope
with it?
Eric Greenwell
Washington State
USA
Old August 19th 05, 09:55 PM
Maule Driver
I've never flown an HP. Getting sucked into a cloud seems to primarily
be a strong conditions (e.g. Western US) problem. Happened to me in an
LS6... have no idea what I'd do with a flaps-only ship except exceed
redline. Deploying the spoilers at close to redline scared the stuff
out of me as it was, but it worked.
with it?
Old August 19th 05, 10:31 PM
Bob Whelan
"Maule Driver" wrote ...
cloud.
with it?
Having flown an HP-14 for 195 hours and a much-weenier-flapped Zuni for
several thousand, all of it out west, and having in both been concerned
about getting sucked into strong cloud streets, here's what I did:
1) immediately slowed down (to some speed below which full flaps could
easily/safely be put down);
2) put down full flaps;
3) changed course to the nearest cloud edge.
4) gave thanks I was flying a flapped ship!
Low stress, structurally safe. Even if one was so
foolish/bold/situationally-unaware as to go into the cloud immediately upon
the pull-up to slow down, who among us canNOT simply provide a stick input
until the stall, prior to losing control in the cloud? If a pilot can do
that, s/he can put down the flaps after the speed bleeds down. (Individual
mileage may vary. Not approved by the Insurance Institute of America or the
American Bar Association.)
Short of having the magic fairy wave a magic wand, I've a hard time
imagining anything simpler and safer in glider/cloud-avoidance terms. If -
for the sake of limiting this discussion - we ignore *how* one comes to be
in the situation of realizing cloud avoidance is (thought to be) a
necessity, and consider only the (forced) choices of either a) opening
spoilers at high speed for the first time beneath a cloud AND successfully
staying out of said cloud (e.g. Maule Driver!), or b) pulling on full flaps
at low speed AND unsuccessfully NOT staying out of said cloud (not me!), the
coward in me opts for "b)" in a heartbeat. Even with the Zuni's wimpy
large-deflection flaps, there is ZERO risk of exceeding maneuvering speed
and pulling the wings off in a spiral dive, because one must *hold* forward
stick w. full flaps to maintain flying speed.
And, yes, the above was tested and incorporated in a plan long before
needing it in both ships...
Regards,
Bob - gliders can never have too much disposable drag - W.
Old August 19th 05, 11:44 PM
Mark Dickson
Zuni for
both been concerned
what I did:
full flaps could
If a pilot can do
down. (Individual
of America or the
It would be a lot easier with airbrakes - just open
them.
Old August 19th 05, 11:50 PM
Udo Rumpf
I have not encountered a situation where this would be an issue near the
clouds. I would just speed up.
I would not mind having spoilers on occasions, when it is necessary to
insert one self into a pattern after many gliders return at the same time in
a contest setting. Even then when I am finally committed to land after I
have given way because I was not able to quickly get into on opening. The
landings are most civilized even
if some one is worse off then I in terms of squeezing in there is always
enough space for gliders to land. One does not always have to land near the
trailer.
Regards
Udo
Old August 20th 05, 12:18 AM
Bill Daniels
"Udo Rumpf" wrote in message
in
trailer.
Regards
Udo
This whole thread says a lot about glider flight training. Airplane pilots
are trained with flaps so they are comfortable with them. Glider pilots are
trained with spoilers, since there are no flapped trainers, so that's what
they are mostly comfortable with.
In fact, a skilled pilot can handle any situation with either.
If there's a situation where a pilot feels uncomfortable, talking with an
instructor skilled in flapped gliders is advisable. (ASK first whether the
instructor has any time in a flap-only glider.)
I have flown both and, although most of my experience is in spoiler equipped
gliders, I prefer flaps for all the reasons the pro-flap folks have listed.
I'll add another. Spoilers, even when closed, disrupt the upper wing
surface in the most critical area - flap only wings are cleaner.
Bill Daniels
  #28
Old August 20th 05, 12:52 AM
Eric Greenwell
And yet, on a well built glider, you can carefully smooth and seal the
spoilers so there is no leakage or surface unevenness, test the glider,
and it isn't any better. My recollection from Johnson's tests is the
most critical area on the wing is the first few inches of the nose (bug
problems), and that the boundary layer is thick enough at the spoilers
that they do not affect the flow on the typical racing glider.
One might also consider how much "disruption" in air flow a Holighaus or
Waibel would tolerate! Even if I'm right about the airflow disruption,
it doesn't negate the principal advantages of flaps, but I think most
pilots would prefer a combination of the two.
There may also be performance issues related to designing a modern flap
only glider: because modern airfoils use such narrow control surfaces, a
flap only glider might not have enough glide path control. I was
astonished at the difference in glide angle between my ASW 20 and my ASH
26 E, even though they employ the same flap system for landing: the ASW
20 descended much more steeply than does my ASH 26. Even though part of
that is likely due to the higher wing loading on the 26, the flap chord
on the 20 is almost double that on the 26.
Eric Greenwell
Washington State
USA
  #29
Old August 20th 05, 02:34 AM
Udo
Eric Greenwell
Washington State
USA
True,
I am building a new wing and I was hoping to include landing flaps
only.
The airfoil was not given me the results I desired with the larger
flaps. I had to reduce the flap size to 16% and install spoilers. The
flap/aileron arrangement will similar to the DG800,
May real preference would be the ASW20/26/27 set-up but I decided to
keep it simple
As for surface aerodynamics the spoilers are always past the laminar
transition. Smooth and sealed spoiler boxes have no ill effect.
In my case the max transition on the top surface will be at 66% and
that is where the box will be installed.
Regards
Udo
  #30
Old August 20th 05, 02:50 AM
Ray Lovinggood
One question for 'flaps only' glider drivers:
On a cross country aero tow, do you ever feel a need
for some type of draggy things to help keep you in
tow position?
If you need a tow speed fast enough to get you home
before the sun sets but that makes it too fast to deploy
flaps, what procedure do you use, if and when necessary,
to keep the towrope tight? Yea, yea, yea, I know:
Fly it properly and you won't need to worry. But
what about when the tuggie snoozes a little and starts
a slight descent and gains speed. (Hey, I'm not even
sure spoilers could help out here.)
Popping spoilers out sure works nicely and easily.
And by the way, I don't like cross-country aerotows.
Sometimes, I think I would rather have the trailer
instead of the towplane.
Ray Lovinggood
Carrboro, North Carolina, USA
LS1-d (No flaps. Spoilers only)
