#21
![]() Seth Masia wrote: Okay, but look at the Picture 6 in the sequence at http://www.thedenverchannel.com/news...57/detail.html Look carefully at the prop blades, then tell me whether this engine was making power at touchdown. I have no idea. What I do know is you can't look at a prop that hit the ground, see the blades are bent back and conclude it wasn't making power. I have proof to the contrary. Quite a conversation piece. Also, no fire. Fuel status? Selector closed? Mine didn't burn either, but then I didn't rip a wing off. |
Plane reportedly from Green River WY area.
Ron Lee |
Interview with the passenger on the local TV stations (pilot still
in serious condition at the Vail hospital). They were flying from WY to Leadville, plans were to fly over Copper Mtn (about 20-30 miles east of Vail) to check out a motorcycle rally. Pax said that they realized they were too low and the valley too narrow to get out. Aircraft landed in a clearing on the side of the hills (not a flat area, but less steep than most of the stuff other than the golf course and the road). I return to my original comment -- why over the mountains in a single engine aircraft with no easy out? |
#24
The vast majority of back country airplanes are single engine...
From my seat in the cockpit I say he did good in a tough situation... I'll fly with him any day... denny |
#25
in a single engine aircraft with no easy out? I do it with no problem but I have taken the mountain flying course and I usually have beaucoup distance between me and terra firma. Unless some mechanical problem caused this incident odds are it was pilot error. Ron Lee |
#26
Denny wrote:
The vast majority of back country airplanes are single engine... From my seat in the cockpit I say he did good in a tough situation... I'll fly with him any day... I'm not denying the pilot did an incredible job landing the plane in light of the geography in the area. However.... ceiling on a non-turbo PA32 is 14-16K. At the time of the accident, the ground temps at Vail put the density altitude at 13-15K on the ground. I still don't know if the aircraft was turbo or not. If turbo, ceiling goes up to 20K. So, assuming flying at 1-2K AGL (and ground is 10-11K) then the aircraft was at the published ceiling. Not surprised they couldn't get out of the valley. |
#27
Ron Lee wrote:
I return to my original comment -- why over the mountains in a single engine aircraft with no easy out? I do it with no problem but I have taken the mountain flying course and I usually have beaucoup distance between me and terra firma. Unless some mechanical problem caused this incident odds are it was pilot error. Ron -- we agree that yes, it can be done. And I've taken the mountain flying course (more than once - never hurts) but as you pointed out, big air between you and ground. Based on the density altitude, doesn't seem that there was that much space between the aircraft and the ground. Fortunately, no fatalities, the pax is in very good humor (according to the interviews yesterday) and the pilot is improving. |
#28
![]() Ron Lee wrote: and I usually have beaucoup distance between me and terra firma. Then you're not mountain flying. |
#29
It appears to be a 1969 PA32-300 with a TIO-540.
RisingUp.com says its ceiling would be 16,250'. Pretty large half page color picture of it in todays local paper. Chris |
#30
Newps wrote:
Ron Lee wrote: and I usually have beaucoup distance between me and terra firma. Then you're not mountain flying. OK, you fly over the mountains your way....I will fly mine ![]() Why fly through passes when you can fly several thousand feet over them? Ron Lee |
My first lesson | Marco Rispoli | Aerobatics | 3 | May 17th 05 08:23 AM |
Navy sues man for plane he recovered in swamp | marc | Owning | 6 | March 29th 04 12:06 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | September 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | August 1st 03 07:27 AM |
