Soundwaves Boost Wing Lift
Old August 21st 05, 12:31 AM
Default Soundwaves Boost Wing Lift
Here's some news that recently came out:
http://www.newscientist.com/article.ns?id=dn7867
http://abc.net.au/science/news/stories/s1439827.htm
Apparently, soundwaves can help airflow stay near the wing and increase
lift. This can help smaller aircraft to avoid stalling at lower
airspeeds. Is this a technology that could be usefully applied to
existing small aircraft? Or would it require some totally new design
thinking?
Old August 21st 05, 12:42 AM
Dave Kearton
" wrote in message
ups.com
| increase lift. This can help smaller aircraft to avoid stalling at
| lower airspeeds. Is this a technology that could be usefully applied
| to existing small aircraft? Or would it require some totally new
| design thinking?
It would also require heavy metal music.
Well _somebody_ had to say it.
Cheers
Dave Kearton
Old August 21st 05, 03:32 AM
I was thinking perhaps at least drones could benefit from this
technology, since they tend to be smaller and might have to travel at
lower speed to do ground surveillance.
Hmm, or what about at least toy RC hobby aircraft?
Comments?
Old August 21st 05, 07:02 AM
Charlie Springer
On Sat, 20 Aug 2005 16:31:43 -0700, wrote
(in article . com):
thinking?
I have some of the piezo polymer film they were probably using (from SONAR
experiments, and a steel plate target that tells you where the bullet hit).
The amplitudes would be very small, but covering a wing on an RV or Bonanza
would be less than five pounds in weight, including the high voltage
electrics needed for the piezoelectric material.
But New Scientist is not the most reputable source (called New Age Scientist
by some, ignored by the rest) and I would have to see this confirmed by
another lab. It smells a lot like the kind of signal that screws up your
instrumentation. The drive for the film is likely 800 to 1,200 volts and at
400 Hz running on a little model in a wind tunnel with sensitive detectors of
various sorts. I'll just say I'm skeptical.
-- Charlie Springer
Old August 21st 05, 07:15 AM
Smitty Two
In article . com,
thinking?
Here's a quote from the article in New Scientist (first reference above):
"In wind tunnel tests, Salmon stuck sections of plastic piezo-electric
film to wing segments. This film vibrates when an electrical signal is
applied, producing sound."
This sure sounds (no pun intended) like aftermarket stuff to me. It
might find its way into production eventually, but it sounds like you
could go stick some tweeters on your Cessna tomorrow and start landing
at 35 knots. That'd raise a few eyebrows among the line judges.
Of course, the best way to avoid stalls is to learn how to fly. No
technology in the world is going to render pilot error obsolete. OK,
I'll make one concession, for wind shear on final. It would be nice to
stay airborne when dropping through the bottom of a 20 knot headwind
layer.
Old August 21st 05, 08:26 AM
On Sat, 20 Aug 2005 20:05:57 -0700, Richard Riley
On 20 Aug 2005 19:32:02 -0700, "
:I was thinking perhaps at least drones could benefit from this
:technology, since they tend to be smaller and might have to travel at
:lower speed to do ground surveillance.
:Hmm, or what about at least toy RC hobby aircraft?
He he he. It'd drive the people writing the requirements nuts.
I just read an RFP for UAV's. One requirement was that it couldn't be
detected by the human ear from directly below at 4000 AGL. But
another was that it have all the necessary equipment to operate in the
airspace. And THAT meant strobes and position lights. So when the
bad guys can see strobes in the sky and can't hear it, they know for
sure it's one of the drones.
The Stealth Fighter and the Stealth Bomber both have position lights, strobes,
and landing lights. This isn't to say they leave them on all the time....
Ron "Activate cloaking device" Wanttaja
Old August 21st 05, 07:07 PM
Jim Carriere
Richard Riley wrote:
In the airspace for this program, they had to leave them on all the
time, along with their transponder - which had to have a mode that I'd
never seen before, mode 3. This program wasn't for a battlefield, it
Um, serious question: are you being serious that you have never seen
Mode 3? You probably have, but by a different name. Mode 3 is your
plain vanilla 0000-7777 transponder (if it has altitude reporting
technically is is Mode 3/C).
Modes 1,2 and 4 are military systems (in the free world anyway). 1
and 2 are similar to 3, and 4 is also known as IFF (identify friend
or foe, although in function it is more like identify friend and
everyone else is a regular radar blip).
Old August 21st 05, 07:36 PM
Well, could this technology be used to augment the performance of
canards? We know that aerobody designs that are optimized for
high-speed supersonic flight may unfortunately not be so efficient for
low-speed flight around takeoff and landing. Could this sonic lift
technology be used instead of canards, or maybe to boost the lift from
canards? Then maybe you could have smaller canards at least, although
I'm not sure liability canards pose to begin with. Also I don't know
what you'd do in the event of an unpowered landing.
I was also thinking about how stubby-winged re-entry vehicles like the
old X-15 or even the new SpaceshipOne might benefit from that 20%
increased lift.
What about using this technology for something more exotic, like a
martian aeroplane? With the thinner atmosphere producing less lift,
perhaps this sonic boost might make a crucial difference.
Old August 21st 05, 08:37 PM
Rich S.
"Richard Riley" wrote in message
I can see it now, Threshold numbers - 140 kt dash speed, 16 hours
endurance, 1500 AH available power, 300 lb payload, 500 watt surround
sound system, 5g flash memory with Ozzy Ozborn's Greatest Hits.
Oh Lord, let it be so. Let Thy lift elevate that *&^%$ in the Mitsubishi,
with the 16" bass speaker, that drives by my house at 2 am, unto Thy bosom
and keep him forevermore. Selah.
Rich "Ever hopeful" S.
Old August 21st 05, 09:16 PM
There is one other significant fact not mentioned. Turbulent drag,
basically a fluid flow is highly unstable. There is the classical
statement of the butterfly in Japan causing a hurricane in the Gulf.
This represents the control of chaos. Stalling represents the complete
breakdown of laminar flow. So it will not only improve stall
performance, it will (potentially) reduce fuel consumption. Turbulent
drag is caused by vorices in an unstable fluid flow. Fewer vortices =
more kilometers, fewer liters.
Who does flight plans? Michael 182 Piloting 158 July 4th 05 02:50 AM
Lift Query Avril Poisson General Aviation 8 April 21st 05 07:50 PM
Tamed by the Tailwheel [email protected] Piloting 84 January 18th 05 04:08 PM
A Level 1 AOA clarification Ramapriya Piloting 64 January 9th 05 01:19 AM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 03:40 PM
