Soundwaves Boost Wing Lift
Old August 22nd 05, 07:40 PM
LCT Paintball
As with sound canceling headphones, this would only work locally - as in
needing different cancelation waveforms for each side of the head. The
film
would have to be a checkerboard of detectors and generators.
This has been modified for your right ear.
Old August 22nd 05, 07:41 PM
LCT Paintball
film
-- Charlie Springer
This has been modified for your left ear.
Old August 23rd 05, 12:15 PM
No reason why not a piezoelectric material will both tramsmit and
receive. In fact intelligent skin is very biological. It has evolved
independently many times. Dolphins and sharks have intelligent skin.
So, presumably, did Ichtheosaurs, although skin is not in the fossil
record.
Old August 24th 05, 10:17 AM
True. However we can divide our material up. There is clearly a lot of
room for research. To illustrate the potential benefits of research let
me make a biological statement. Water is 1000 times denser than air (at
2,000m altitude). Dolphins and sharks swim at up to 70km/h. Putting
ther same energy in in air would = 700km/hr. Just a bit slower than a
passenger jet.
The Dolphin/Shark at pek energy will probably rougly equal a modern
250cc motobike engine. This is typical of microlight propulsion.
700km/h - Think about it.
I also feel that aircraft of all types would benefit, not just
microlights although for reasons of cost they make the best
experimental machimes. An airliner would have a lower optimal operating
altitude as induced drag (caused by the fact that the plane has got to
impart 9.81M m/s momentum downwards to fly. Induced drag goes down
with air mass swept.
Old September 5th 05, 03:37 AM
Jim Rodgers
Makes one wonder what the technique could do for prop performance. Any
thoughts?
" wrote in message
Here's some news that recently came out:
http://www.newscientist.com/article.ns?id=dn7867
http://abc.net.au/science/news/stories/s1439827.htm
Apparently, soundwaves can help airflow stay near the wing and increase
lift. This can help smaller aircraft to avoid stalling at lower
airspeeds. Is this a technology that could be usefully applied to
existing small aircraft? Or would it require some totally new design
thinking?
  #28
Old September 5th 05, 04:58 AM
ORVAL FAIRAIRN
thoughts?
" wrote in message
thinking?
It would be really difficult to mount the equipment inside a prop's
blades!
  #29
Old September 5th 05, 03:12 PM
niceguy
Why not add a canard to all small A/C?
" wrote in message
thinking?
  #30
Old September 5th 05, 05:18 PM
I don't see why not. Chips have been fired out of guns. Shells are now
intelligent. The chips would go into the hub and there would be a
printed circuit on the prop. No I don't see anything impossible.
Who does flight plans? Michael 182 Piloting 158 July 4th 05 03:50 AM
Lift Query Avril Poisson General Aviation 8 April 21st 05 08:50 PM
Tamed by the Tailwheel [email protected] Piloting 84 January 18th 05 05:08 PM
A Level 1 AOA clarification Ramapriya Piloting 64 January 9th 05 02:19 AM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 04:40 PM
