Running dry?
Old August 24th 05, 02:18 PM
Dylan Smith
On 2005-08-23, john smith wrote:
Dylan Smith wrote:
Many high wing planes have a method of checking the fuel without a
ladder (many provide a small step). The other great thing they provide
is the ability to check the fuel sumps without crawling on wet, dirty
ground and the ability to tie down without having to crawl on the ground
too :-)
Spoken like a true trike-driver! :-))
If you're having to crawl on the ground to tie the tail down, you're
doing it wrong :-)
[for reference, the plane I currently fly the most has a free castoring
tailwheel, so take that you steerable tailwheel weenies!]
Dylan Smith, Castletown, Isle of Man
Flying: http://www.dylansmith.net
Frontier Elite Universe: http://www.alioth.net
"Maintain thine airspeed, lest the ground come up and smite thee"
  #242
Old August 24th 05, 02:30 PM
john smith
too :-)
doing it wrong :-)
This thread is denigrating nicely!
BTW, there are now available locking devices for free castoring
tailwheels, you know?
  #243
Old August 24th 05, 04:17 PM
Matt Barrow
"Newps" wrote in message
Matt Barrow wrote:
Starting out with partial fuel means you are starting with the C/G
already partially aft.
I always calculated both the takeoff and landing C/G when I flew the
Bo
I had access to.
All you need do is NOT overload the rear seats/baggage area.
On a 1300 foot strip I will be all alone and will have removed the rear
seats.
I assume he's getting a V-tail; CG is much better with a straight tail
(yet
still a bit narrow).
It is better with the A36, not with the 33's.
It is, but the 33 is still 2 1/2" wider than the 35, yet still more
The 33's envelope goes two inches farther aft but starts two inches
farther aft too because the tail weighs more.
Gotcha...I was thinking of something else and did a reference fart.
  #244
Old August 24th 05, 10:20 PM
Jay Honeck
Since running a tank dry in the air is optional,
Flying itself is optional...
Take-offs are optional. Landings are mandatory.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
  #245
Old August 24th 05, 10:23 PM
Jay Honeck
I had a tank run dry unexpectedly on me; I've never seen myself hit the
mixture, carb heat, fuel selector, fuel pump, and have my hand on the mags
so fast! It was =way= different from the simulations my CFI pulled.
Same here. I didn't think it was possible to change tanks as fast as I
did -- but a little adrenaline goes a long way!
Jay Honeck
Iowa City, IA
Pathfinder N56993
  #246
Old August 24th 05, 11:49 PM
john smith
I tend to remember what I read in The Blue Sheet a few years ago.
An airliner was flying along when suddenly an alarm sounded and a light
began to flash. The first officer looks over at the pilot, ready to
respond to his commands. As the seconds tick by, the FO observes the
pilot sitting there, winding his watch. Finally, the FO cannot stand the
wait any longer and queries the captain, "Shouldn't we do something? Why
are you just sitting there winding your watch?"
To which the captain replies, "I never killed anyone winding my watch."
  #247
Old August 24th 05, 11:51 PM
Icebound
"Thomas Borchert" wrote in message
Icebound,
*Life* is optional.
Once having embarked upon it, however, we would like to get through it as
safely as possible. :-)
  #248
Old August 25th 05, 12:10 AM
Brian
One of my instructors told me about a time when he and another
instuctor were flying a 206 and inadvernatly ran a tank dry.
They about knocked each other silly as their heads collided as the both
reached for the Fuel Selector.
He says the were so focused on changing fuel that if they had hit
little harder they probably would have knocked themselves out and still
got the fuel selector changed. In which case no one would have ever
figured out why the crashed.
Brian
  #249
Old August 25th 05, 07:03 AM
Dale
In article QbHOe.2349$IG2.1697@trndny01,
George Patterson wrote:
john smith wrote:
Have you ever looked inside an old, straight-backed Cessna 182 jumpship?
I would wager that they have 1600 pound useful load EASY!
Max gross - 2,950. Empty weight - 1,595.
Gross weight on the 182 is 2550 pounds, the 182A and 182B gross at 2650.
Gross didn't get up to 2950 pounds until they put the girlie swept tail
on them.
Dale L. Falk
  #250
Old August 25th 05, 07:41 AM
RST Engineering
With NO changes in engine horsepower, NO changes in wing design, NO changes
in nothing else except a net NEGATIVE CHANGE in rudder area ...
How (in an engineering sense) did they do that?
"Dale" wrote in message
on them.
Dale L. Falk
Time, running out of fuel and fuel gauges Dylan Smith Piloting 29 February 3rd 08 07:04 PM
Engine running again, the good, bad and ugly Corky Scott Home Built 34 July 6th 05 05:04 PM
It's finally running! Corky Scott Home Built 19 April 29th 05 04:53 PM
Rotax 503 won't stop running Tracy Home Built 2 March 28th 04 04:56 PM
Leaving all engines running at the gate John Piloting 12 February 5th 04 03:46 AM
