ADF in Europe
Old August 26th 05, 11:32 AM
Ron Rosenfeld
On Fri, 26 Aug 2005 11:18:19 +0200, Thomas Borchert
Ron,
Is it a true statement
that, so long as I have the required equipment, I can exercise my FAA IFR
privileges in Europe so long as I am flying an N-registered a/c?
Yes.
Thank you for that information.
Old August 26th 05, 02:19 PM
No, they were steam gauge models. The DA42 (european diesel version)
with the G-1000 does have an ADF box - JAA IFR certification was
delayed a bit because of it.
Steve
Old August 26th 05, 02:39 PM
gwengler
Are those long range tanks factory installed or do you need a ferry
permit? I am amazed about the range! With 160KTS you can fly 2400NM
in 15 hrs. by using 8.7gph (no reserves). Is that realistic?
Gerd
Old August 26th 05, 07:08 PM
Ron Rosenfeld
Gerd
The standard tankage is around 102 gallons. With the long-range tanks that
is increased to 130 gallons. They are an integral part of the wing --
basically an extra fuel tank bay outboard of the normal fuel tanks. I
believe the STC for this is held by Monroy, but the factory will do the
install on a new airplance; or it can be done aftermarket. In neither case
is a ferry permit required.
The longest trip I could see myself planning would be CYYT-LPL which is
about 1232 NM. However, once factoring in the distance to possible
alternates; and possible headwinds; it'd be nice to have the extra fuel.
A local surgeon took his O2 around the world. He had both the long-range
tanks as well as a ferry tank. He did require the permit for the ferry
tank.
Old August 26th 05, 07:18 PM
Julian Scarfe
"Thomas Borchert" wrote in message
In Germany, ADFs are required for IFR training aircraft. This is
different from the UK, as Peter posted.
DMEs are required for IFR flying. No substitution by GPS. Yes, I
know...
Related question then...
Some German airports (with class F) appear only to have GPS approaches,
which, according to the plates, require some sort of qualification. Is
there a practical way for a foreign pilot not based in Germany to get that
qualification?
Julian
Old August 27th 05, 01:50 PM
gwengler
Wow! What a great airplane!
Gerd (T182T)
Old August 27th 05, 05:50 PM
Thomas Borchert
Julian,
qualification?
Excellent question. I'm just starting on my German IR, so I don't know. I
believe it is a simple check out/endorsement from a CFI.
Thomas Borchert (EDDH)
  #28
Old August 27th 05, 11:21 PM
Ron Rosenfeld
Gerd (T182T)
And if I only had a spare $500,000 USD ...
Barometer Setting in Europe question... Piloting 19 April 3rd 05 09:43 PM
Flying Holiday in Europe Udo Rumpf Soaring 17 March 23rd 05 03:08 PM
USA armed URSS to keep down Europe IO Military Aviation 9 October 21st 03 07:19 AM
Airmen in Europe may go back to three-month rotation schedules Otis Willie Military Aviation 0 August 22nd 03 11:47 PM
Could it happen he The High Cost of Operating in Europe Larry Dighera Piloting 5 July 14th 03 02:34 AM
